Delica Lego Redux
I still managed to break something, even with this method. :D
There's a little nubby bit of FRN in the area highlighted in red in this picture, but it was covered up with the washer from the screw, and I forced the screw holder too much and it broke that bit of FRN clean off. The knife still seems to work fine and there doesn't seem to be any danger of the sides of the knife becoming separated....
So be aware, although it looks like the screw holder should go all the way through and come into complete contact with the screw, that is apparently not the case for the pivot.
Yeeesh....
Yeeesh....
- Attachments
- Untitled-1.jpg (81.19 KiB) Viewed 2446 times
- krazichinaman
I too love the FG. I find that the perfect knife would be a FFG FG d4wave. I'm pretty close to it...just need to send it off to get the FFG treatment and it would be perfect. I went out and bought a SE d4 FG just to swap bodies with. It made a good donor! :p
________
PUBLIC NUDITY
________
Vaporizer Volcano
________
PUBLIC NUDITY
________
Vaporizer Volcano
- Attachments
- delica.jpg (99.71 KiB) Viewed 2422 times
:spyder: :spyder: :cool: :spyder: :spyder: Man, that is amazing work :eek: :) I know as sure as ****, I am not smart enough to do this stuff......Sooooo Awesome :spyder: Maybe after checkin in here another 1000X's, I'll be able to do some swappin :rolleyes: Thanks for sharing pix Wouter :)
:spyder: :spyder: :cool: :spyder: :spyder: "Spyderco...does a pocket good":spyder:
Spyderco Rocks!!!! "A wise man once said all knives were created equal...Obviously, he meant Spydercos''
As of 1-29-08, I am a proud member of Knife Rights!
pedropcola
swanseajack
- dorfinator
Fred Sanford
Good Info Wouter. I wish I had looked for this before the first time I took my Delica ZDP appart. Had some problems reassembling and had to analyze the situation. I came to the same conclusion Shu did. Assemble everything except the lock and lock pivot barrel then pop it in.shu wrote:As an alternate method, reassemble the knife 'sandwich style' INCLUDING the blade, washers, and blade pivot BUT EXCLUDING the lock and lock pivot barrel.
Put a little extra tension on the blade (via the pivot screw) to prevent it from flopping around, then slip the lock into position (pressure from a couple fingers should be enough) and slide the lock pivot pin into place. Secure the lock pivot pin, adjust the action to your liking, and put it in your pocket.
In other words, steps 2 & 5-7 are included in step 1. Steps 3, 4, & 8 are then performed as described.
That's it. With a little practice, it takes less time to do then to describe.
Kev.
- dorfinator
I use a zip tie around the handle holding the lock down after the handle is assembled without the blade. I don't fully tighten the most forward torq screw so I have some leeway on inserting the blade along with the washers.Kev-Man wrote:Good Info Wouter. I wish I had looked for this before the first time I took my Delica ZDP appart. Had some problems reassembling and had to analyze the situation. I came to the same conclusion Shu did. Assemble everything except the lock and lock pivot barrel then pop it in.
Kev.
I used a tweezer to slide the washers on either side of the blade.
This is how I install the lock, like how Shu also mentioned. No Tweezers required.dorfinator wrote:I use a zip tie around the handle holding the lock down after the handle is assembled without the blade. I don't fully tighten the most forward torq screw so I have some leeway on inserting the blade along with the washers.
Kev.
- Mr Blonde
Man, this thread just won't die!! I started it over 3 years ago!
My first post detail my method from over 3(!) years ago. Thanks to the info from fellow forumites I adapted my method that I detailed in my :D video referenced by Spyderbro.
<iframe title="YouTube video player" class="youtube-player" type="text/html" width="640" height="390" src="http://www.youtube.com/embed/nZu_tiUZU0k" frameborder="0" allowFullScreen></iframe>
