Two Questions for Sal...
Hey,
Just had a couple of questions for Sal. I was thinking recently about H1. According to the Spyderco website it is "rolled hard without heat treating", what I'm wondering is if this is a necessity of replacing the Carbon with Nitrogen or if it is just a feature of this particular steel? Basically, does steel in which Nitrogen has been used instead of Carbon have to be prepared like this or was it simply something that was chosen to do with H1?
My second question is about the updated Dragonfly. I was wondering what the time frame is on the new Dragonfly if there is one yet and also what changes you guys are looking at implementing in this model if you are able to share?
"A flute with no holes is not a flute. A donut with no hole, is a danish."
Quietly lurking the Spyderco forum since 2003...
And while we're on the subject, how about transforming the current FRN Dragonfly into a "Salt" with a modified, H1 blade? :)ASmitty wrote:My second question is about the updated Dragonfly. I was wondering what the time frame is on the new Dragonfly if there is one yet and also what changes you guys are looking at implementing in this model if you are able to share?
yablanowitz
Personally, I like the flat ground blade of the current Dragonfly too well to give it up for H-1.
From Sal's explanations elsewhere, the steel requires the current working methods, just as the steel precludes full flat grinds. I'm sure he will correct me if I have misundersttod his posts on the subject.
Well, I think Padawan's request was to use the current integral clip model for a Dragonfly Salt once the upgrades are in effect on the actual Dragonfly model. Meaning you'd have the new Dragonfly with a full flat grind and the old style handle with a saber ground H1 blade.yablanowitz wrote:Personally, I like the flat ground blade of the current Dragonfly too well to give it up for H-1.
You have my full support on this idea.Padawan wrote:And while we're on the subject, how about transforming the current FRN Dragonfly into a "Salt" with a modified, H1 blade? :)
Some fine jimping on the choil and cusp like it is on the Lava would make it an even better little knife.
My wife carries and uses an FRN and I the SS D'fly, both are great pocket scalpels.
I like sharp over big.
All your knifelinks, http://www.knifelinksportal.com
Yes, that's exactly what I meant.ASmitty wrote:Well, I think Padawan's request was to use the current integral clip model for a Dragonfly Salt once the upgrades are in effect on the actual Dragonfly model. Meaning you'd have the new Dragonfly with a full flat grind and the old style handle with a saber ground H1 blade.
I figure the existing blade shape could use some tweaking in order to make it more "Salt-like" anyway, so the change in grind would come along with that. I really feel that there's a bit of a hole in the line-up as far as a small Salt goes, and the Dragonfly seems a very logical choice to serve as the platform for one. Just an idea, but thanks for the support ASmitty. :)
only problem with a dragonfly salt is that sal said he can't do flatground H1. i remember seeing some older, hollow-ground dragonflies, though...
i still EDC a SS PE dragonfly almost daily... have been doing so for over a year now. i've found ATS-55 to be extremely rust resistant. i'm very interested in any variation or permutation of the dragonfly, although i'm not sure a hollowground dragonfly salt would be my first choice...
Hold the Sheepsfoot and I'm with you all the way.cobrajoe wrote:I'm all for a little salt based on the D'fly. I'm thinking a little yellow, integral clip, sheepsfoot SE H1 bladed FRN handled knife would be a great thing :D
