30 degree angle on 204 for para milly?
CRS
Post by CRS »
The scary sharp edge on the para milly out of the box looks to me to be at thirty degrees instead of forty.? If I want to maintain the scary sharp edge, would i be better off using the 30 degree angle on the 204 instead of the 40?
Note: I also have a pair of the ultra fine stones.
thanks
CRS
An invitation to visit my Photography Galleries at:
http://www.pbase.com/crs
Capt. Carl
Post by Capt. Carl »
yes
CRS
Post by CRS »
Capt. Carl wrote:yes
Thanks Carl :) A man of few words :D
Cheers
CRS
A. Stanton
Post by A. Stanton »
Go to the Chris Reeve Knife Site. They make $500 pocket folders and recommend a 40 degree edge for their knives: case closed.
CRS
Post by CRS »
OK...one vote 30...one vote 4:confused: Anyone else??.... Sal? :) You out there?
:spyder: CRS :spyder:
Thanks in advance
Texas guy
Post by Texas guy »
A. Stanton wrote:Go to the Chris Reeve Knife Site. They make $500 pocket folders and recommend a 40 degree edge for their knives: case closed.
That is some flawed logic there :rolleyes:
I think I will stick with Sal's recomendation of 30 degrees :spyder:
Bassman
Post by Bassman »
My thoughts too... just because they're expensive doesn't mean they have the best blade angles. 30 degrees is what I run on the Yojimbo, and my Para, but I guess if you want the usable edge to last longer between sharpenings you *could* go to 40. 30 works great for me, and s30v is plenty wear resistant to run the thinner edge, and still take a while between sharpenings.
gunmike1
Post by gunmike1 »
Bassman wrote:My thoughts too... just because they're expensive doesn't mean they have the best blade angles. 30 degrees is what I run on the Yojimbo, and my Para, but I guess if you want the usable edge to last longer between sharpenings you *could* go to 40. 30 works great for me, and s30v is plenty wear resistant to run the thinner edge, and still take a while between sharpenings.
Actually, it should have better edge retention at 30 than at 40. That isn't the traditional view of edge retention, but a lot of people have proven that acute edges will have better edge retention than more obtuse ones, assuming the steel can handle the thinner angle.
Mike
dalefuller
Post by dalefuller »
30 degrees. S30V is strong enough to handle a more acute edge angle under normal usage (a very broad range, BTW) and it's pretty easy to maintain that edge with the Sharpmaker.
At least, that's what I do with my PM and I've had no edge problems or sharpening problems. The PM is what I usually carry when I'm not at work, so it sees a good bit of use.
Regards,
Dale
"If there are no dogs in Heaven, then when I die I want to go where they went."
~ Will Rogers, 1879-1935
jimbo@stn24
Post by jimbo@stn24 »
CRS, I think you'll do just fine at 30 degrees. I don't have a para but I do have the millie (tomorrow may be the day I can add one more :) ) and I believe it came narrower than 30 degrees out of the box. It has only needed the occasional touch up.
Some folks like 40 degrees as they find it works well for them, to each their own. Not to argue, but despite what CRK recomends, I run all my CRK's at 30 degrees as well and am quite happy with edge retention and cutting ability. Best of luck.
WTC #1455
From this and past threads, I've gotten the idea that 15 per side/30 inclusive is preferred for S30V and ZDP189. What about VG10? Can it handle 15/30 as well? Or does it need 20/40?
bowarrow2000
Post by bowarrow2000 »
VG10 works very well at 15 per side. I sharpen all of my knives at 15 per side.
154CM,VG10, S30v and the good ole carbon steel blades.
gunmike1
Post by gunmike1 »
Bolstermanic wrote:From this and past threads, I've gotten the idea that 15 per side/30 inclusive is preferred for S30V and ZDP189. What about VG10? Can it handle 15/30 as well? Or does it need 20/40?
VG-10 handles 15 per side with ease. I actually go much thinner on all of those steels (10 per side or less with a 15), especially the ZDP.
Mike
CRS
Post by CRS »
Thank you to everyone for your input :)
