Spyderwrench-An easy Modification
v34
Post by v34 »
Sal
On the adjustable wrench how about you etch a mm scale with an indicator point on the moveable part.Ideal for measuring nut/opening size. Also, as the moving jaw comes out all the way if you serrate the underside and reverse it becomes a pipe wrench. This is used in Sandvik-Bahco adjustable wrenches.
Hi V34. Good idea. We'll consider this for future changes.
Tom Percy
Post by Tom Percy »
Sal,
If you consider a MM scale, how about an Inch scale for those that don't know the metric sysem...
Heyns van der Merwe
Post by Heyns van der Merwe »
Hi Tom,
isn't the SpydeWrench only sold in the civilised world? ;-}
Just could not resist!!
Tom Percy
Post by Tom Percy »
If that's the only place you can purchase one, then where is the civilized world ? <img src="smile.gif" width=15 height=15 align=middle>
gadfly
Post by gadfly »
I like the idea of markings, but what I could use would be the correct size (in sixteenths or metric) of the bolt head, e.g., the 8th and 9th marks would be 1/2" and 9/16" bolt sizes respectively.
