Show your Mule
- legOFwhat?
Re: Show your Mule
Beautiful Robin!
-Larry
MNOSD #0049
MNOSD #0049
- standy99
Re: Show your Mule
Another nice one Robin….
Got to pull my finger out on one or two I have in stages of completion
Re: Show your Mule
Thanks guys @legOFwhat? @standy99
Can't wait to see what comes next then !
I have to admit that even if it is time consuming and I'm deep into folders now, going back to something that is known is nice, and I have new tools in my skillset that are fun to apply to this
MNOSD member 004* aka Mr. N5s
Re: Show your Mule
I like how you keep the handle further back from the ricasso, and give it the clearance chamfer.
- Manixguy@1994
Re: Show your Mule
Love the sculpture of the handle , looks comfortable. Dan
Re: Show your Mule
Thanks, I've moved these lines a lot through the past versions and for the last ones It has setteled. I think I forgot to post some but my aim is now to have the handle clim the nub just a bit at the bottom and stop before the flat ends at the top. Since I often pinch grip for many things I like to give a steep (60+°) angle to go into the blade too
@Manixguy@1994 That's the best thing about it according to the people who now have one at home or come play with my Mules
When I started working on it I immediately ordered another AEB-L for myself, can't live without this one
Re: Show your Mule
Ramonade wrote: ↑Sat Nov 15, 2025 3:27 amThanks, I've moved these lines a lot through the past versions and for the last ones It has setteled. I think I forgot to post some but my aim is now to have the handle clim the nub just a bit at the bottom and stop before the flat ends at the top. Since I often pinch grip for many things I like to give a steep (60+°) angle to go into the blade too![]()
Keeping a copy of one of your photos for my next build. Agree with the shape and position of the front of the handle. Both functional and aesthetic. I would be proud to own the mule in your pictures. My one desire would be to reduce the "pregnancy" of the handle's belly a bit (would require re-shaping of the blank) but that's just a personal preference for a slightly more neutral handle.
Re: Show your Mule
Bolster wrote: ↑Sat Nov 15, 2025 12:40 pmRamonade wrote: ↑Sat Nov 15, 2025 3:27 amThanks, I've moved these lines a lot through the past versions and for the last ones It has setteled. I think I forgot to post some but my aim is now to have the handle clim the nub just a bit at the bottom and stop before the flat ends at the top. Since I often pinch grip for many things I like to give a steep (60+°) angle to go into the blade too![]()
Looking forward to see how you apply it to your taste ! I personally love the palm swell in the tang, but it works mostly for small/medium hands, if your hands are larger, it might not be as comfortable.
Re: Show your Mule
I don't know how to explain my relationship with palm swells, but I'm not the biggest fan of them. I wear either L or XL gloves but hand size doesn't seem to explain it. For some reason I like a more neutral handle, even though they look boring.
But one thing I must admit: Palm swells LOOK cool! Sexy, even.
barnaclesonaboat
Re: Show your Mule
Mule appreciation from the sharpening bench, the venerable K294 in @FullScaler scales. What a workhorse this knife has been, and it's back to being extra crispy:
- standy99
Re: Show your Mule
The old trusty Magnacut Ultem mule in some kitchen prep.
Steelearner
Re: Show your Mule
Spine work done. Modified CPM SPY27 mule 2
Greg
MNOSD member #0054
* EDC - PM2 S45VN, Canis S30V, Salt 2 SE LC200N
MNOSD member #0054
Re: Show your Mule
Really it’s just a vine like pattern. It is also a different way to add jimping which I wanted because I added a finger choil to choke up on the knife. When I choke up I place my thumb on the spine. In addition to that the spine now strips wire pretty well
- Attachments
Greg
MNOSD member #0054
MNOSD member #0054
Re: Show your Mule
Oh, cool cool. Good looking Mule.
Re: Show your Mule
Thanks. I still need to sand the Kirinite scales a little more but I need to get more sandpaper first. The stuff clogs up sandpaper pretty quick. Not sure I’ll use it again.
Greg
MNOSD member #0054
MNOSD member #0054
Re: Show your Mule
Hey Jeb,
File work on the spine of a knife is pretty common with custom makers, just for show.
Scandi Grind
Re: Show your Mule
I'd love to see some more pictures of that sheath and one with the knife in it. That looks pretty neat!
-- Old Norse proverb
Re: Show your Mule
Actually, it's quite impressive the way you all have picked up and breathed life into the whole Mule Team project. We were concerned that offering the "blank" with no handles or sheaths might be a deal breaker, but seeing the skills and sharing that has resulted is refreshing.
