Sage 6 opened in pocket and bit me good :)
navin johnson
Re: Sage 6 opened in pocket and bit me good :)
#41
Post by navin johnson »
Had a Manix light weight open (or was already opened) several times when drawing from from IWB……
Back locks only unless carried in the front pocket tip up against the rear seam fo me
Synov
#42
Post by Synov »
gk4ever2 wrote:
Fri Sep 26, 2025 8:28 pm
Red Leader wrote:
Fri Sep 26, 2025 8:18 am
The button on the Sage 6 does stick out proud from the scales, and I’m wondering if it is possible to have the knife open if you were to lay the knife on a flat surface, button side down, and push the knife flat. It may be more of a ‘2nd detent/single detent’ question at that point.
The button on the Sage 6 contacts the lock bar, and doesn't do anything until the knife is locked open. I think of it as the opposite of a side-opening automatic knife where the button allows the knife to open (and close), where on the Sage 6 pressing the button just allows the knife to close. I still like the Sage 6 and often carry it loose in my pocket, but like many tools caution is advised. If the Sage 6 easily opens (like in your pocket) then the pivot screws are probably too loose.
That's not quite true, the button also unlocks the knife when it's closed, just like a regular compression lock, but the second detent will keep it closed. Many are removing the second detent.
S90V: Nirvana Military 2 CF Native 5 Fluted CF Manix XL CF Yojumbo CF Shaman CF Sage 6 CF CPM-154/S90V: Manix 2 CF 15V: PM2 Marble CF 4V: Manix 2 Marble CF 3V: Tuff REX 121: Sage 5 CF 20CV: Subvert CF ZDP-189: Dragonfly 2 Nishijin S30V: Sage 4 Damasteel: Native 5 40th Anniversary VG-10: Delica 25th Anniversary N690Co: PITS XHP: Chaparral Birdseye Maple MagnaCut: Native 5 Fluted Ti PM2 Crucible
Jesla
#43
Post by Jesla »
Synov wrote:
Sun Sep 28, 2025 7:16 am
That is not true, for any regular compression lock I have, the blade is not locked closed, it has a weak closed dent. If you drop shake them hard enough the blade will swing to full lock having never touched the lock release. Also you can spydie hole open any compression lock without pushing the release. The blade is not “locked” closed.
Still plays with knives…
Aladinsane
#44
Post by Aladinsane »
navin johnson wrote:
Sat Sep 27, 2025 7:28 pm
Good idea! Much better than the “Opti-Grab”😉!
-Jeff-
Synov
#45
Post by Synov »
Jesla wrote:
Sun Sep 28, 2025 8:19 am
That doesn't contradict what I said. Regular compression locks don't have the second detent that the Sage 6 does. That's the only difference besides the button itself.
Jesla
#46
Post by Jesla »
Synov wrote:
Mon Sep 29, 2025 7:51 pm
Yes it does/I do, see a quote from your post below…. The compression locks of any syderco knife does not lock the blade closed, a dent is not a lock. Even the sage 6 can be opened without a ever pushing the button.
#47
Jesla wrote:
Tue Sep 30, 2025 5:54 am
“…the button also unlocks the knife when it's closed, just like a regular compression lock
Am I missing something or are you?
cjk
#48
Post by cjk »
Mushroom wrote:
Tue Sep 30, 2025 8:54 am
A lot of hair splitting and semantics. Compression lock knives don't *lock* closed. Other than that, all parties' points were successfully communicated. We've all learned that lockbacks are still best. Back to your regularly scheduled program!! :cheap-sunglasses
#49
cjk wrote:
Tue Sep 30, 2025 9:49 am
Oh! Unreal but too funny...:grin-squint
cjk
#50
Post by cjk »
Mushroom wrote:
Tue Sep 30, 2025 10:27 am
;) :smlling-eyes
Infinite Zero
#51
Post by Infinite Zero »
This is why I prefer locks with a close bias, such as Back Locks and Ball Bearing Locks.
#52
where would the world be without people arguing over knife locks on the internet?
maybe we'd actually be solving real problems like how to get your spouse to pick a place to eat.
#53
Tue Sep 30, 2025 3:09 pm
be a chef ;)
Synov
#54
Post by Synov »
That was in response to you saying the button "doesn't do anything" until the knife is locked open. It does, it allows the blade to open more easily. Whether this is "unlocking" is just semantics.
raygixxer89
#55
Post by raygixxer89 »
Tue Sep 16, 2025 1:16 pm
All jokes aside. I had a Para 3 LW open in a pair mesh gym shorts. Not sure how it happened but I was digging for my keys. Now I only carry lock back knives when wearing gym shorts. The detents are stronger. I’ve worked with sheet metal for over 20years. Knife cuts are very baby compared to some of the metals cuts I’ve seen and got myself. Not to mention I almost cut my thumb off with a chainsaw 🤦‍♂️. Cuts happen is all I’m saying. It’s what makes a knife not a spoon lol.
Yup. But I've used a knife as a fork! :zany
#56
I just stopped by for some entertainment! 😂 Thank you . 🤪 MG2
#57
Post by Doc Dan »
In some of my dress pants I have a little pocket sewn inside of right front pocket on the leg side. This is for keeping a knife in and so it won't open as there isn't enough room. It also keeps a heavier knife from flopping around. This is the only safe way to carry a knife with a detent based lock.
