What will Magnamax corrosion resistance look like?
bladesandbeverages
Post by bladesandbeverages »
We’ve all heard that magnamax will have wear resistance similar to K390 and toughness on par with S35VN. We know it’s stainless, but I am curious how stainless. I have not been able to find anything regarding that and was curious if anyone knew. Could we be dealing with salt levels of corrosion resistant, or something more along the lines of s30v, or any other stainless?
Synov
Re: What will Magnamax corrosion resistance look like?
Post by Synov »
Larrin has said the production version from Erasteel will have similar corrosion resistance to MagnaCut.
S90V: Nirvana Military 2 CF Native 5 Fluted CF Manix XL CF Yojumbo CF Shaman CF Sage 6 CF CPM-154/S90V: Manix 2 CF 15V: PM2 Marble CF 4V: Manix 2 Marble CF 3V: Tuff MagnaCut: Native 5 Fluted Ti REX 121: Sage 5 CF 20CV: Subvert CF ZDP-189: Dragonfly 2 Nishijin S30V: Sage 4 Damasteel: Native 5 40th Anniversary VG-10: Delica 25th Anniversary N690Co: PITS XHP: Chaparral Birdseye Maple
Fireman
Post by Fireman »
Synov wrote:
Thu Aug 21, 2025 3:51 pm
Holy Popemobile Batman! 😮😮😮😮😮😮😮😮😮😮😮
Mule Team Army 001 (patched)
MNOSD 008 :usflag
If the wear resistance, toughness, and corrosion resistance properties of MagnaMax prove true in real world use, is there any application where a user would still be better served by MagnaCut?
I already have a handful of MagnaCut knives, and I just want to know if I should stop buying more and instead wait for MagnaMax.
Synov
Post by Synov »
mikey177 wrote:
Thu Aug 21, 2025 8:30 pm
MagnaCut is tougher and MagnaMax has more edge retention. They will have similar hardenability and corrosion resistance. One is not "better" than the other unless you have a specific goal in mind. MagnaMax will be close to where 10V is on this chart:
Thank you for the information, @Synov.
For my uses, perhaps MagnaCut would be more suited for larger fixed blades while MagnaMax would be more at home in folders.
I hope I am able to get one of the MagnaMax Mules for testing.
kobold
Post by kobold »
If corrosion resistance is not an issue, is there a reason to buy Magnamax when I already have enough knives in Maxamet?
Synov
Post by Synov »
kobold wrote:
Fri Aug 22, 2025 5:39 am
If Maxamet isn't chipping in your use, probably not. But if you find yourself babying your knives, you should try something a bit tougher.
kobold
Post by kobold »
Synov wrote:
Fri Aug 22, 2025 5:50 am
Thanks!
They are microconvexed to prevent exactly that. :clinking-mugs
