So what is the hardware on the Native5 Salt made out of?
lonerider1013
Post by lonerider1013 »
I love my native5 salt. But... the salt2 has a ti clip. The clip on the native5 salkt is magnetic, which makes me figure it is not ti. But what IS it made from? Is it the same as the other native5 clips or is it some rustresistant material? And is the lockbar regular steel like the other natives or is it lc200n too? Just curious as I intend to make this knife my go to, love the native and wanted a more rust resistant one... but beyond the blade am curious what it is made of?
Lonerider
"A fool's blade may be sharper than his brain"
“Learn to ride a bicycle. You will not regret it if you live." - Mark Twain
Re: So what is the hardware on the Native5 Salt made out of?
Post by Doc Dan »
It’s a secret.
C99c
Post by C99c »
Adamantium. Avoid Magneto and you'll be fine.
Just use the knife, it'll be fine. If you want a titanium clip, add one. I recommend MX Gear. I like the one on my Native Salt.
I have a Byrd Cara Cara 2 CE. It's been in the ocean several times over the past few years, in rivers and lakes often and carried IWB in the Georgia summer regularly while hiking and running. The only thing I've ever done is occasionally flush it with fresh water, put a little oil on the pivot and sharpen it. The liners and inner lockbar nearest the blade show a little surface rust. That's it.
I can't imagine that the hardware on the Native Salt is more fragile than that of the Cara Cara 2.
Support Knife Rights. https://kniferights.org/
Don't buy knives from EBAY or AMAZON. There are plenty of good companies that will appreciate your business and don't sell fakes.
Blayd
Post by Blayd »
A stainless steel alloy, rust resistant, but no formula given and not LC200N....🤔
James Y
Post by James Y »
I believe the info on what it's made of is proprietary.
zuludelta
Post by zuludelta »
If I had to hazard a guess, the hardware is probably made from a highly corrosion-resistant austenistic stainless steel (maybe 304 or 316). I believe the lockbar on the LC200N Native 5 Salt is also made from LC200N. Don't know if the MagnaCut version also has a MagnaCut lockbar.
EDIT: Just read the OP's post about the clip being magnetic... I guess that rules out 304 or 316 for the clip, at least.
My most recent reviews:
Genzow HatchetHawk, Ikuchi, MicroJimbo
RamZar
Post by RamZar »
I don’t know about the back lock itself but I believe the screws and clip are coated to be rust resistant. You’re only as strong as your weakest link. If I recall correctly, this became apparent after rust impeded the operation of an Autonomy under the button.
