stretch 2 compression lock
could it ever happen? @sal
navin johnson
Re: stretch 2 compression lock
It’s called a Paramilitary 2
Been a while since we had a PM2 run with cool blade shape.
- 8th_Note
Isn't there a clip point PM2 that's coming soon ?
Saber grind! There's something about the saber ground version of the stretch that just looks SO good. A saber ground pm2 would be incredible.
- Larry_Mott
Of course i can only speak for myself, but the day every Spyderco comes with compression lock is when i look elsewhere for interesting designs and knives.
I don't hate the compression lock but i don't see it as the second coming of Christ/ best invention since sliced bread either.. :)
Fortunately, Spyderco will be the last company to focus on just one lock or just one steel.Larry_Mott wrote: ↑Sat Jul 05, 2025 11:33 amOf course i can only speak for myself, but the day every Spyderco comes with compression lock is when i look elsewhere for interesting designs and knives.
I'm not wild about the compression lock, but obviously many are. I bet a comp lock Stretch 2 XL would sell well but, as others have said, a comp lock Stretch 2 is probably too similar to the PM2 to warrant a new model.
- 8th_Note
I think a Seki made PM2-like knife priced at about $120 would fly off of the shelves. VG-10 steel and FRN. It would essentially be the Lightweight PM2
Think top liner lock, like the Sage 6. That would catch my interest.
What about the design dont you like? Personally I think its the best overall lock design however comes with the big flaw of having pretty poor closed bias (basically just the detent which is relatively weak). This is only an issue if clipped in a waste band and not in a pocket, and even then very rare to be an issue but still an issue none the less. For instance I have the Salt PM2 which is amazing, but I dont trust the compression lock tip up in my shorts or bathing suit when jumping in and out of the water all day.Larry_Mott wrote: ↑Sat Jul 05, 2025 11:33 amOf course i can only speak for myself, but the day every Spyderco comes with compression lock is when i look elsewhere for interesting designs and knives.
I think a compression lock with some type of way to increase closed bias would be my ideal lock.
A person walks into 101 Flavor Matter Separator shop and asks, "Hey, what happened to the other 27 flavors?" The person behind the bar replies, "They did not taste enough like iron for our licking. - ykspydiefan
- bearfacedkiller
It’s rather difficult to operate with gloves on.Rezimus wrote: ↑Sun Jul 06, 2025 12:26 pmWhat about the design dont you like? Personally I think its the best overall lock design however comes with the big flaw of having pretty poor closed bias (basically just the detent which is relatively weak). This is only an issue if clipped in a waste band and not in a pocket, and even then very rare to be an issue but still an issue none the less. For instance I have the Salt PM2 which is amazing, but I dont trust the compression lock tip up in my shorts or bathing suit when jumping in and out of the water all day.Larry_Mott wrote: ↑Sat Jul 05, 2025 11:33 amOf course i can only speak for myself, but the day every Spyderco comes with compression lock is when i look elsewhere for interesting designs and knives.
- apollo
I think it can only be done if the model is made with dual liners. Eric explained otherwise the handle in that size flexes to hard to ensure the safety of the lock. That is why there is still no Para 2 LW. As its way more difficult then just enlarging the Para 3 Lw.
Red Leader
Interesting. I wonder then how that explains the Stretch 2 XL which does not have any liners. That is a pretty big knife to just have FRN.apollo wrote: ↑Sun Jul 06, 2025 4:20 pmI think it can only be done if the model is made with dual liners. Eric explained otherwise the handle in that size flexes to hard to ensure the safety of the lock. That is why there is still no Para 2 LW. As its way more difficult then just enlarging the Para 3 Lw.
weeping minora
I believe apollo is expressing why the compression lock won't work without two steel liners under FRN in a model of such substantially increased size beyond the Para 3, not that any lock won't work (in the case of the S2XL, the backlock). I could be wrong and apollo is free to correct me if so.Red Leader wrote: ↑Sun Jul 06, 2025 4:23 pmInteresting. I wonder then how that explains the Stretch 2 XL which does not have any liners. That is a pretty big knife to just have FRN.apollo wrote: ↑Sun Jul 06, 2025 4:20 pmI think it can only be done if the model is made with dual liners. Eric explained otherwise the handle in that size flexes to hard to ensure the safety of the lock. That is why there is still no Para 2 LW. As its way more difficult then just enlarging the Para 3 Lw.
With the current S2XL being ~$120 at its base price (and base materials), I'd figure there would be a substantial price increase to implement a compression lock into the model, much like we have seen with the Lil Temperance 3 LW. Again, I could be wrong. This is kind of insane to say, as when I got into Spyderco, the base (Satin S30V) PM2 went for $120.
Make Knife Grinds Thin Again.
- apollo
Lockbacks do not have that problem as the lock helps both scales stay stable.Red Leader wrote: ↑Sun Jul 06, 2025 4:23 pmInteresting. I wonder then how that explains the Stretch 2 XL which does not have any liners. That is a pretty big knife to just have FRN.apollo wrote: ↑Sun Jul 06, 2025 4:20 pmI think it can only be done if the model is made with dual liners. Eric explained otherwise the handle in that size flexes to hard to ensure the safety of the lock. That is why there is still no Para 2 LW. As its way more difficult then just enlarging the Para 3 Lw.
- apollo
Absolutely correct Thx for the help!weeping minora wrote: ↑Sun Jul 06, 2025 4:48 pmI believe apollo is expressing why the compression lock won't work without two steel liners under FRN in a model of such substantially increased size beyond the Para 3, not that any lock won't work (in the case of the S2XL, the backlock). I could be wrong and apollo is free to correct me if so.Red Leader wrote: ↑Sun Jul 06, 2025 4:23 pmInteresting. I wonder then how that explains the Stretch 2 XL which does not have any liners. That is a pretty big knife to just have FRN.apollo wrote: ↑Sun Jul 06, 2025 4:20 pmI think it can only be done if the model is made with dual liners. Eric explained otherwise the handle in that size flexes to hard to ensure the safety of the lock. That is why there is still no Para 2 LW. As its way more difficult then just enlarging the Para 3 Lw.
- 8th_Note
Kunwu just came out with a compression-style lock on one of their larger knives. It has a bar that runs between the scales, and thru the the lock bar tab, to stabilize the lock bar and prevent it from twisting (and releasing) if the knife is torqued during use. This might be the answer to compression locks on larger LW knives. (Images from Metal Complex youtube channel)apollo wrote: ↑Sun Jul 06, 2025 4:20 pmI think it can only be done if the model is made with dual liners. Eric explained otherwise the handle in that size flexes to hard to ensure the safety of the lock. That is why there is still no Para 2 LW. As its way more difficult then just enlarging the Para 3 Lw.
