Serrated K390 sharpening?
S-3 ranch
Post by S-3 ranch »
Just ordered a serrated k390 endela , any suggestions on how to sharpen it after I put some hard use on it, I have my process & tools for vg10 serrated, but I think K390 serrated will be a different beast? Does it have to have diamond equipment?
Proverbs 21:19 says, "It is better to live in a desert land than with a quarrelsome and fretful woman." :winking-tongue
JayHenMac
Re: Serrated K390 sharpening?
Post by JayHenMac »
Use a Sharpmaker with CBN rods. K390 just takes a little more work, but I don't have any issues keeping my SE K390 sharp using the method Sal teaches in the product video for the Sharpmaker.
RustyIron
Post by RustyIron »
What Jay said.
Generally, I use the regular Sharpmaker rods because they're gentler on the serrations. Occasionally I'll use the diamond rods, but they're rather aggressive.
I don't use Sal's method. Rather than hold the blade vertically, on the ground side, I tip the blade to match the factory grind. On the flat side, I tip the blade just a skosh past the factory grind so I'm still hitting the edge, but not scratching up the whole side of the blade.
Palestrina
Post by Palestrina »
RustyIron wrote:
Tue Jun 10, 2025 10:36 am
What Jay said.
I'm holding the blade vertically on the ground side, but sharpen the back side the same way as you do.
I just needed the CBN rods once to repair a small chip, other than that - as you said - the brown and white stones are sufficient to keep K390 SE sharp.
Native 5 C41PCBL5, C41GP5, C41MPCW5
Delica 4 C11FPWCBK, C11FPBK, C11PBK, C11FPK390, C11FSK390
Lil' Native C230MBGP, C230NLGP, C230MBGPBN15V
Chaparral C152SGY, C152GY
Urban C127PBK
My User Name does not refer to a middle eastern region, but to an Italian composer of the most beautiful masses you'll ever hear. Giovanni Pierluigi da Palestrina, go check him out.
blueblur
Post by blueblur »
I’ve had great success sharpening se k390 with the medium and fine sharpmaker rods.
Bill1170
Post by Bill1170 »
Yes, brown and white rods for maintenance, diamond or CBN for damage repair and reprofiling.
Bill1170 wrote:
Tue Jun 10, 2025 10:00 pm
This is the way.
Also the more you stay on top of touchups the less you'll ever need anything more course until/unless you damage the edge.
