Seki City back lock quality in 2022? [Update 2025]
cabfrank
Re: Seki City back lock quality in 2022?
#101
Post by cabfrank »
I wonder how long the molds last, and if the Endela ones have been replaced yet. 🤔
Flash
#102
Post by Flash »
If a $15 dollar lock knife doesn’t have lock rock then I expect a $100+ knife to not have lock rock.
If I’m sold a $100 knife with even minimal lock rock, then it goes back to the shop for either an exchange or a refund.
I don’t care if the manufacturer has adorned it with the latest wonder steel - I refuse to accept poor QC at this price point.
Lock rock and blade play might not be safety concern but it concerns me I’ve been mis sold a knife that should’ve been added to the “seconds” QC reject pile.
Hopefully Seki has solved these issues and can assume it’s now safe to buy from the latest Spy27 line up without feeling like you are getting stitched up with a knife that’s skipped quality control?
8th_Note
#103
Post by 8th_Note »
Flash wrote:
Sun May 18, 2025 3:37 am
I have a SOG Twitch II that has zero lock rock, but if you bump the spine with anything beyond minimal force the lock fails. I have never seen or heard of a Seki back lock failing
Would you consider the SOG to be a higher quality knife?
Flash
#104
Post by Flash »
8th_Note wrote:
Sun May 18, 2025 12:18 pm
I would consider a high quality locking knife knife to suffer from neither lock rock nor lock failure.
vvs
#105
Post by vvs »
I have no SOG in possession, but some CS AD-10s - my primary hiking tool amongst ARS folding saw. And this topic is reality: all Seki made backlocks in my possession has vertical blade play while open. I don't care is it lock design or something, CS nailed it. Ultimately I decided not to use them (bunch of endelas, my favorite Spyderco design) for force cutting, set them to something 15dps 80/100 micron CBN finish for those toothy aggressive cutting and leave them as an almost perfect light and (20CV) stainless EDC.
Mat_ski
#106
Post by Mat_ski »
As I said earlier in this thread never had issue using my seki backlocks for hard use.
Also I never noticed any blade play until I read about it on this forum. It is not noticeable in normal use. I have to push down on the knife’s spine near the tip when it is open to observe it. Of all the Seki’s I own Stretch k390 is most noticeable.
However, I find that the salt variants have no blade play that I can notice. I have had dragonfly salt for a while, that is rock solid. Today I took delivery of green salt 2 and it is also rock solid.
#107
just checked my kids dfly salt out of curiosity. no luck.
https://dubz.link/v/995e3c
rock bar moves visibly with 3-4lbs of pressure on the edge.
Jayrod1980
#108
Post by Jayrod1980 »
I have a few Seki City backlocks, and all have a tiny bit of lock rock. My Golden Native 5 has none. I still love the Seki lineup, but curious that after 40 years it hasn’t been eliminated. Perhaps the Native doesn’t have that issue because the bar is much thicker compared to the stock of the blade. I have no idea, still the Stretch 2 XL and Leafjumper in K390 are two of my favorite Spyderco knives I own.
dsvirsky
#109
Post by dsvirsky »
This has been pointed out before, but no one seems to pay attention. From Sal himself, on February 1, 2001:
"A very slight vertical play in lockbacks is fairly common if they are engineered for strength."
viewtopic.php?p=20526&hilit=Engineered#p20526
#110
dsvirsky wrote:
Thu May 29, 2025 6:03 pm
That´s very interesting.
Since this quote is 24 years old now, I wonder what @sal would say today...?
To be clear and again: The slight Seki backlock lockrock does not bother me at all, but I don´t believe that the Golden backlocks - who in my limited experience tend to have less - are "not as strong" resp. would sacrifice strength in order to achieve less lock rock...?
Michal O
#111
Post by Michal O »
Well, as creator of this thread I can do little summary after 3 years. I bought 2*Police 4 K390, Endura 4 K390, older Ulize, sprint of C60. Probably not my last back locks. All are pretty solid, especially Endura, some very small lock rock is there but at acceptable level - it's movement of the blade and locking bar together. I carry most often Endura and Police 4 se, sometimes Ulize and Ayoob. Police pe is safe queen in box. My previous Endura and Police SS had blade play almost like Microtech OTF if someone is familiar with it. Police and Endura in K390 - both saw some serious work and blade play is on same level as they were new.
Current collection: Lil Temperance G10, Shaman, Lil Native, Massad Ayoob cruwear, Smock, Street Beat, Street Bowie, Para 3, PM2 purple G10 cruwear, Canis, Rhino, Endura 4 K390, Watu, Kapara, Amalgam, Sliverax, Police 4 se K390, Police 4 pe K390, Khukuri, Barong, Ulize, Microjimbo, Smock M4, Lil Temperance 3 K390, Bodacious PE S30V.
Actinolite
Re: Seki City back lock quality in 2022? [Update 2025]
#112
Post by Actinolite »
I have a couple Dragonfly 2s, a Salt 2, and a LeafJumper, all from Seki City. The DF2s and the LeafJumper are solid, no issues. But I’m less than impressed by the build quality of the Salt 2. Lock rock is noticeable, and I dislike the way the lock spring anchors into the split FRN handle, bearing right on the split.
By contrast, I have a Byrd Hawkbill. It has inset stainless steel liners which necessitates using an FRN spacer bolted between the two handle halves. No lock rock, and it just feels solid. Is it heavier than the Salt 2? Yes, but barely noticeable.
I also have a couple Native 5 LW. They have no liners, but the lock spring retention slot is designed so the spring does not bear on the handle split. They are both solid with no significant lock rock.
While I am a big fan of lockbacks, I’m unlikely to buy another Delica or Delica-based lightweight because of how they are built.
Oldest: 1974 Buck 110.
Newest: Li’l Native, CPM 15V, G10, Backlock
SE models: Dragonfly 2 Salt, Lil Native, Chaparral, Salt 2, Byrd Hawkbill 2, LeafJumper K390, Mule MT46S, Temperance CruWear
Added a ceramic mug, "The Edge is a Ghost". Great mug!
