How to fix blade play on steel scales
Drumlooper
Post by Drumlooper »
I have a blade play issue with these two beauties: Image
Given that there are no screws to thighten I was wondering if this problem can be fixed.
Thanks.
yablanowitz
Re: How to fix blade play on steel scales
Post by yablanowitz »
Not if you want to retain that original finish. You may be able to tighten things up temporarily by squeezing the pivot end in a vise with padded jaws, but to make it last, the pivot pin would need to be peened or staked to prevent it from slipping back. That would necessitate refinishing the handle.
RazorSharp86
Post by RazorSharp86 »
I’ve had some luck with using a hammer. I put the knife inside a leather glove, usually, when doing something like that.
Recently, I also had some lucky with a parallel plier wrench. I used my largest Knipex to squeeze it tight. You should make sure, however, to protect the scales by wrapping it in some sort of cloth or better yet leather. As mentioned, the finger of a leather glove worked for me, in the past.
Drumlooper
I’ll try that. It’s what I always do on my straight razors. But there you can an actually see the pin.
