What's a Neely lock? Example, por favor.Larry_Mott wrote: ↑Sat Apr 20, 2024 12:08 pmMaybe i should start nagging about a Neely lock Sage again? :)
Sage series collection - What's the next Sage?
Re: Sage series collection - What's the next Sage?
- Richard
I didn't add a lot of detail to my comment, but to clarify, if I'm mostly standing/walking/hiking during the day, Manix-sized tallness/width is fine. Backpacking? Manix is my preferred folder. It's on days when I'm changing vertical positions a lot, sitting, crawling around on the floor, up and down the ladder (contractor work days) that I often move the Manix to a back pocket for comfort (except for sitting, which requires yet more shifting about), or choose a less tall knife to carry. I often carry a Sage on blue collar days, and would even more prefer a slim Caly 3 design if I could get the Caly in a balanced PM steel. Yeah, tallness/width makes a big difference for comfort if there's lots of bending at the waist--for me, at least.
Very much agree about length, as you stated. That's why I prefer the Caly 3 at work over the Caly 3.5, which pokes my leg a lot more. All said, the Sage is a good work knife, IMO. Especially in M4! Long enough to cut up lunch, short enough to give good tip control. Would I like a straighter edge with a lower tip and less belly--what I call a "dropped leaf"? Sure, but the Sage is good as it is.
Hey @Bolster, have you tried the Leaf Jumper yet? Slightly slimmer in pocket than the Manix and the overall edge profile(footprint) is more in line with the Manix. More straight than belly. I know it lacks jimping and a boye dent. However, the extreme hump proves the jimping useless and the ease of use is greater than any other back lock I've used from Spyderco. Not sure what Seki is doing differently on the RJ and LJ, but is is something else. I can even do that trick where you hold the knife (fingers out of the blade path) and shut it like a compression lock.
- Larry_Mott
[googlevideo]riclaw wrote: ↑Sat Apr 20, 2024 4:04 pmWhat's a Neely lock? Example, por favor.Larry_Mott wrote: ↑Sat Apr 20, 2024 12:08 pmMaybe i should start nagging about a Neely lock Sage again? :)
[/googlevideo]
JSumm wrote: ↑Sat Apr 20, 2024 10:10 pmHey @Bolster, have you tried the Leaf Jumper yet? Slightly slimmer in pocket than the Manix and the overall edge profile(footprint) is more in line with the Manix. More straight than belly. I know it lacks jimping and a boye dent. However, the extreme hump proves the jimping useless and the ease of use is greater than any other back lock I've used from Spyderco. Not sure what Seki is doing differently on the RJ and LJ, but is is something else. I can even do that trick where you hold the knife (fingers out of the blade path) and shut it like a compression lock.
Have not! Worthy of investigation, thank you for the nudge. Never seen an inertia close with a backlock before!
You really haven´t ?!
And I thought Vivi and I would actually start to get annoying, cause we´ve shared our clips on that quite a bit already
Here is an old one I made once (closing shown one time slow, two times fast)
I am always glad when others start to realize too: This method works with pretty much every backlock (only model I know where it is a bit harder to do is the Chaparral), so folks who want that "fingers out of the blade path" thing don´t have to shy away from lockback Spydies.
- Steeltoez83
I happen to have the leafjumper in my pocket while I was cut testing the Cinco sage. I'm a big fan of the LJ.
OK, maybe I have, and forgot. I'm pretty sure I watched your vids. It's a neat trick and I'll have to try it.
It is actually not just a "trick" in my view, but more than that and enough so to go off topic sometimes for me.
- There are many who choose a comp.lock over a backlock for that "fingers out of the blade path thing", not realizing that pretty much the exact same thing can be done with a backlock too in a very similar way. With all the same pros and cons that this method of closing brings also with a comp.lock (main con: Knife not very secure in hand with that pinch grip)
- I aways like to take the opportunity and perhaps encourage people to look beyond some of those persistent knife "myths" and just try for themselves. Maybe closing a knife that way takes a bit more getting used to in the beginning with a backlock, but then it works pretty much the same as with a comp.lock.
/ ON topic again
Still the Sage 4 would be MY personal favorite for a re-run... and still don´t know if there is a difference between its front lock and the mid backlock... they look to be pretty much the same - ?
Anyone could educate me?
A Back Lock versus a mid Back Lock is where you press to disengage the lock. A back lock like in the Buck 110 you have to press at the very bottom which is very inconvenient for one-handed closing. The mid back lock like in Spyderco folders has the disengagement in the middle which makes it easy to close one-handed.
- I welcome dialog, as long as it remains cordial, constructive and is conducted in a civilized manner. - Titanic: Blood & Steel
- You can fool some of the people all of the time, and all of the people some of the time, but you cannot fool all of the people all of the time. - Abraham Lincoln
Thanks,RamZar wrote: ↑Mon Apr 22, 2024 1:04 amA Back Lock versus a mid Back Lock is where you press to disengage the lock. A back lock like in the Buck 110 you have to press at the very bottom which is very inconvenient for one-handed closing. The mid back lock like in Spyderco folders has the disengagement in the middle which makes it easy to close one-handed.
but I am aware of that - my question is if there is a difference between the mid backlock Spyderco ususally implements and the front lock of the Sage 4 - I figure "front" only in relation to an old buck backlock (where the lock has to be pressed at the handle end), but actually "just" a mid backlock too.. ?
Yes, they are the same thing. Front Lock is just another name for the Mid-Back lock or Mid Lock.
Thanks, Nick!
Thanks. It looks like the blade pivots on the ball bearing? And pull out on the blade to unlock? Might be a little slow to open and close.Larry_Mott wrote: ↑Sun Apr 21, 2024 2:26 am[googlevideo]riclaw wrote: ↑Sat Apr 20, 2024 4:04 pmWhat's a Neely lock? Example, por favor.Larry_Mott wrote: ↑Sat Apr 20, 2024 12:08 pmMaybe i should start nagging about a Neely lock Sage again? :)
- Richard
applejuice54
Sage 6 in 15V with axis lock.
Followed by
Sage 6 in Rex 121 with axis lock
And then
Sage 6 in Rex 45 - axis
Not to be out done
Sage 7 in back liner lock with button (compression based)
Sal you just got some samples…. And….
Followed by
And then
Not to be out done
- Larry_Mott
[/quote]
[/quote]
Well, it won't be popular among the fidgeteers but then again, neither was the Gayle Bradley but that's a darn good knife regardless. :)
[/quote]
I recently got the Sage 1 Maxamet, the Sage 5 CF/G10 and the REX121. I still think one day I NEED to have a Sage 5 in S90V with textured CF scales (like on the Subvert, but flat).
As I was saying…
So excited to see this becoming a reality in the -I hope- not so distant future.
Any NEW news on the Sage 5 regarding any high end blade steel ? K390 , MagnaMax , Etc...
With the Sage5 already in Maxamet, REX121, Spy27, Magnacut, M4... I'm not sure we'll see another super steel other than possible exclusives, maybe St Nicks in 4v. Most of the focus seems to have moved to the Sage6, which hopefully gets an FRN treatment with various steels too. Grab the S90v sprint while you can.
I'm still carrying a Sage1 most days, and REALLY hope to see a Sage2 reboot in 10v/K390, maybe Magnamax eventually? Adding the ceramic Reeve lock/ball interface would be icing on the cake, and would make it even more different than the original for Sal's collector concerns. Heck, I guess the ceramic integrated interface could warrant a Sage7 depending who you ask? Fluted Ti would also make it different
