Military 2 Discussion (Merged)
Re: Military 2 Discussion (Merged)
#1181
I did about 30 "reckless abandon" style cuts through this heavy triple wall corrugated today and I'm happy to report the serrations didn't snag one bit and all the cuts were super clean. The grind geometry is definitely thinner than my 2009 SE Military 1, I think before I do anything major with this knife I need to measure the thickness at the tops of the serrations on both knives and see how they differ.
So far I've only sharpened it on the brown rods, 20 degree slot on the front and 15 degree slot on the back, trying to split the difference and keep the inclusive edge as thin as I can. No heavy reprofiling yet, just more or less a touch up from the factory edge.
James Y
#1182
Post by James Y »
Evil D wrote:
Tue Dec 17, 2024 3:13 pm
Thank you for sharing. I've never had S30V in SE, so am curious to see how the serrated edge holds up over time, and if the edge is any more prone to chipping than SE in other (softer) steels.
#1183
May I ask:
If your goal was to "keep the inclusive edge as thin as I can":
Why then 15 degrees on the back and not just removing the burr by putting the blade almost flat on the rod (which would mean an even steeper angle at the back and thus also incl. than with 15 degrees)?
/ The serrations look pretty nice btw!
#1184
Tue Dec 17, 2024 10:47 pm
May I ask:
Because they're ground just a bit steeper than 15 degrees, so when I try the 15 slots the rods hit the shoulder of the bevel. Kinda don't have a choice unless I reprofile it.
#1185
Evil D wrote:
Wed Dec 18, 2024 4:01 am
May I ask:
I think he meant why use 15 degrees on the back side of the blade. Meaning, normally we lay the back side of the blade (back side of the serrations) as flat as possible on the stones. I had the same question Gernot did. Did you mean you were using 15 degrees on the shoulder of the bevel and 20 on the apex?
#1186
JSumm wrote:
Wed Dec 18, 2024 5:37 am
May I ask:
Oh well yeah I guess I could do that, I do it on my Ayoob and Stretch. I have my rods both on the far ends of my Sharpmaker base, so one side is at 40 and the other is at 30.
#1187
#1188
Yes, that´s what I meant indeed
#1189
my millie 2 is the only pocket knife* I feel like carrying since I got it.
*excluding multitools which I use for their tools and not their blades.
Kleon
#1190
Post by Kleon »
My two dolled up Millie 2 fully serrated workers. I posted these on the 2024 Knife of the year thread but should add them here as well. So easily customizable as well as high performing.
IMG_2180 Small.jpeg (35.06 KiB) Viewed 2164 times
IMG_2181 Small.jpeg (34.52 KiB) Viewed 2164 times
IMG_2182 Small.jpeg (32.37 KiB) Viewed 2164 times
cabfrank
#1191
Post by cabfrank »
Those are amazing. I was trying to decide which I liked better in the other thread. Both.
Kleon
#1192
Post by Kleon »
cabfrank wrote:
Wed Jan 01, 2025 2:36 pm
Thanks Cabfrank. They cut so well it’s amazing. I am not sure which I like better. Have to say I am very pleased with Sharp Dresses Knives scales. Good guy to work with as well. His communication was good as well as the product. I had never used his work before this.
cabfrank
#1193
Post by cabfrank »
I thought about it, and very slight edge to the DLC, but a great pair overall.
#1194
Looks great @Kleon!
shunsui
#1195
Post by shunsui »
Scored a 15V Military 2. Was waiting for National Knives, but knivesshipfree.com works well enough for my situation.
If prices go down, I just might buy another later.
Not the worst knife you could buy. Crucible steel too.
SpeedHoles
#1196
Post by SpeedHoles »
I haven't tried a Military 2 yet. Been perfectly content on the original Militarys I have, despite that I generally prefer the comp lock over a liner, but it's so easy to find and operate the liner on the original that it's like second nature, even with gloves.
That said, now with this BBB variant, I figured it was finally time to grab an M2. Let's see
Going back to Caly.
dullmaker
#1197
Post by dullmaker »
shunsui wrote:
Tue Feb 04, 2025 9:54 am
Same here. A Big Brown Bear in the hand is worth 2 in the bush.
Deadboxhero
#1198
Post by Deadboxhero »
We finally did it.
Big Brown Bear
Triple B Handmade Knives
#1199
Congrats! It’s a win for all of us. 🍻
And just in time with the Crucible situation.
#1200
SpeedHoles wrote:
Tue Feb 04, 2025 11:34 am
The Military 2 in general would have been a hard sell for me if steel variants didn't exist or if for some reason they decided to never make it in anything but S30V. I already have some of the best versions of the Military 1 so why bother right? But I think once you get it in your hand and use it a whole you'll see it really is an improvement overall, and that's coming from a Military 1 loyalist.
In other words, if they also released a 15V Military 1 alongside the Military 2, and I could only buy one of them, I'd buy the 2. Of course I'd absolutely get both though lol.
