renosto wrote: ↑Tue Nov 26, 2024 8:29 pm
I am a new user who recently bought my first Spyderco knife. I came to the forum to share my first experience with you. I chose the Spyderco Para 3 Lightweight for a simple reason: it is designed to be lightweight and practical, and I heard that it has a very good reputation.
The moment I received the knife, I was shocked by its workmanship. The CTS-BD1N steel used in the blade is really sharp. I tried cutting paper after unboxing and it was very smooth. In addition, the FRN material of the handle feels light and very comfortable to hold, suitable for long-term use.
As an everyday carry tool (EDC), this knife is very competent. I mainly use it to cut packaging, shave wood chips, and occasionally prepare some food when camping. Every time I use it, I can feel Spyderco's attention to detail, such as the geometric design of the blade and the security of the press-in lock.
The only thing that makes me a little hesitant is that I am still getting used to the way the Spyder Hole is opened. However, after practicing a few more times, I found that this design is actually very intuitive and efficient, and it is stress-free to operate with one hand.
After using it for a while, I also found some minor problems. For example, although the FRN material handle is light, it may slip slightly in cold weather. If there are other material options, such as G-10, it may be more suitable for some special scenarios. In addition, I would like to ask all senior users, how to
maintain CTS-BD1N steel to keep it sharp for a longer time?
Overall, the Spyderco Para 3 Lightweight gave me a very good first impression of the Spyderco brand. Its lightness, sharpness and functionality made me fall in love with this brand. I also plan to buy another one in the future to experience Spyderco's product line more deeply, such as trying the Manix 2 or Endura series.
Finally, I would like to ask everyone: If you want to recommend a second Spyderco knife, which one would you recommend?
Welcome to the forum!
- One remark: I don´t think you´ll find G10 to be grippier (in "cold weather", or when wet...) than textured FRN.
For me it is clearly the opposite.
- Concerning recommendations: Be prepared to get a ton of different ones, mostly based on personal preferences folks here have developed for their own good reasons, so no "wrong or right" here...
Here are mine:
Get a Spyderco sharpmaker as "next Spyderco"
+ It will make it very easy to keep especially the BD1N sharp (a steel that is a breeze to sharpen imo)
+ It will help you with other knives (not only Spydercos), scissors and so on too
+ It makes sharpening serrated Spydercos extremely quick and easy
Try a serrated ("SE") Spyderco
+ To me a good SE Spydie works better in most folder tasks than a plain edge
+ At least with a sharpmaker SE is a bit quicker and easier to sharpen than PE
+ SE stays sharp a lot longer than PE and will still "cut" even when technically dull
Recommended models
+ Affordable option with really great serrations:
Endela SE in VG10 (
https://www.spyderco.com/catalog/details/C243BK/1782)
Compared to your Para 3 it gives you a larger, full four finger handle; a longer blade with thinner stock (so slicier geometry); a backlock to try out (imo better in operation, ergos, safety in pocket than a comp.lock)
+ Superlight but still sturdy and completely rustproof options:
Salt 2 SE in LC200 N ; Pacific Salt 2 SE in LC200n
Your Para 3 LW certainly feels light, but is not a really light knife with its 2.4 oz (not a bad thing, don´t get me wrong)
The similarily sized
Salt 2 (
https://www.spyderco.com/catalog/details/C88FGR2/2083) weighs just 1.9 oz, gives you more grip area on the actual handle and a much thinner, slicier blade.
The
Pacific Salt 2 (
https://www.spyderco.com/catalog/details/C91FGR2/1904) comes in at only 2.6 oz and gives you a much longer blade. Imo more versatile and especially better for the food prep you say you do occasionally.
Manix 2:
Great option indeed! (Just no SE version available).
I prefer its lock (CBBL) over the comp.lock, it has a tall, rather thin blade with still robust tip, and great ergos that offer two full four finger grips.
I´d definitely go with the lightweight (but if you want to try something even more different to your Para 3 LW: Get one of the linered G10 versions)
Edited for spelling
