Taking apart knives - part 2
B12buddy
Re: Taking apart knives - part 2
#201
Post by B12buddy »
Thanks for the assist and glad to be here. I had a micrometer laying around and I think we're at roughly .500" OD, .250" ID, and 0.010" thick. I ordered the minimum (5 sets) from usaknifemaker.com. We'll see...
Stuck with my 15V Shaman for tonight I guess.
horzuff
#202
Post by horzuff »
Did anyone take apart the Stretch 2 XL Lightweight? Does it have bronze washers or does the blade run on FRN?
Edit: Didn't take it fully apart, so no photo, but I wanted to have all the body screw heads on the same side of the knife (from factory the handle ones are on one side and the pivot and backlock screw heads on the other) so I took the blade out and there were no washers, just a raised FRN disc on both sides
Smaug
#203
Post by Smaug »
I'm late to the party here, but where is Part 1? Perhaps that should be either linked or merged into this thread?
-Jeremy
#204
horzuff wrote:
Mon Jul 10, 2023 2:20 am
It's constructed just like a Pacific Salt 2 on the inside. I took mine a part. If you search you could find photos I posted in one of the Stretch XL threads.
horzuff
#205
Post by horzuff »
Wed Aug 30, 2023 7:38 am
So a Salt version is literally sticking a different steel sheet in the grinders, yellow pigment to the FRN molds and use salty hardware? Can't wait for a MagnaCut Salt then :D
kirilpetkov
#206
Post by kirilpetkov »
A bit of Spydiechef prevention. I have had this knife since 2016. Used as intended and you can see for yourself that there is no wear on the Frame Lock.
https://youtu.be/qbe7SdRM8-Y?si=30S0SKUKLivCtUQ9
#207
Milie sprint run from 2008. Received it today and of course it had to be pulled apart to have a closer look and to do maintenance before putting it to good use. Nice solid T10 pivot and tiny T6 for the scales. Funny detail is the leftover material on the backspacer which you will only see when pulling the knife appart 😉
KJKeyserSoze
#208
Post by KJKeyserSoze »
Hello everyone,
I don't come here unless there is an issue I cannot solve myself.
A friend's knifecenter delica couldn't engage the back lock successfully, and so I took it apart and compared with mine...
now separately, I realised knifecenter's exclusive delica is also missing Sal's insignia. So did my friend get a clone instead ?
- updated my Drop supergold Delica also does not have SG insignia... :grin-sweat
https://photos.app.goo.gl/1c18TxHDKvr7Q3Zy5
the lock part simply is not seated into the cavity on the blade to engage properly... and there is a gap at the tail end of the lock bar. Tolerances aint' fantastic as far as I can tell. Lock bar seems to be a bit longer than the comparison one I have.
Any help is appreciated, and if he should send back to knifecenter, or if this is a clone, well, I will break the bad news to him.
Wesley
horzuff
#209
Post by horzuff »
I don't recall any laminated clones.
But this one looks as if the lockbar's "tooth" chipped away - look at the general shape of the protrusion that catches onto the blade. The working one is basically a rectangle while the KC one is a trapezoid. Are there any signs of a fracture?
KJKeyserSoze
#210
horzuff wrote:
Mon Oct 16, 2023 3:44 am
Thanks for the reply. No , I don’t see signs of fracture. Should we just send back to knifecenter?
horzuff
#211
Post by horzuff »
I wouldn't know how to solve it, so I would :)
alphaneuron9
#212
Post by alphaneuron9 »
KJKeyserSoze wrote:
Fri Oct 13, 2023 11:42 pm
Hello everyone,
Wesley
I would want to know what a spyderco quality inspections representative would say about the missing sal makers mark. That may be a ¨tell-tale¨sign. Anyone know if they are available on the forum? Maybe we can ask them to take a look. Those are good pics.
Alex
Scientia et pax
#213
alphaneuron9 wrote:
Thu Oct 26, 2023 7:19 pm
Hello everyone,
Wesley
Sal’s makers mark was not always included on every one his models. It was only in mid-2019 that Spyderco began using Sal’s makers mark on all of his models.
BLADE_OCD
#214
Post by BLADE_OCD »
Smaug wrote:
Tue Aug 29, 2023 12:59 pm
I found it. Everything makes sense now.
Here you go.
Taking apart knives Part 1
viewtopic.php?f=2&t=78032
NortonT
Location: North Carolina near east coast North Myrtle Beach
#215
Post by NortonT »
I have a problem now. I snapped off a pivot screw in the pivot barrel of a shaman. I was installing RGT micarta scales. I noticed the liners on one side was loose in the scale. Then it I couldn't get all the play out I figured it was due to the loos fitting liner but I snapped the pivot screw trying to get all the blade play out. My dumb mistake. I need to buy a new pivoy screw and a pivot barrel. I can find pivot screws for the shaman but not the pivot barrel. Does anyone know where to get shaman pivot barrels or if PM2 or para 3 pivot barrel would work on my shaman. The end of the screw is stuck in the pivot. Any help would be greatly apprciated. Thank you!
-----Terry :worried
#216
і couldn’t completely disassemble the persistence, the lanyard tube was flared on both sides.
i wanted to remove the thick Victorinox tool oil and lubricate it with Gunny glide
the bolts on the lil native were so tight that i thought i would break the screwdriver
Synov
#217
Post by Synov »
I attempted to scale swap a Rex 121 Sage 5 with the CQI version Sage 5 CF. Everything worked well until I realized the FRN doesn't quite fit the old frame, solely due to the peg to the right of the pivot being slightly too tall. So I'm not going to be able to sell the FRN as a fully successful swap, although the knife does function. I could try swapping just the blade, but I'd rather not.
S90V: Nirvana Military 2 CF Native 5 Fluted CF Manix XL CF Yojumbo CF Shaman CF Sage 6 CF Native Chief CF MagnaCut: Native 5 Fluted Ti PM2 Crucible CPM-154/S90V: Manix 2 CF 15V: PM2 Marble CF 4V: Manix 2 Marble CF 3V: Tuff REX 121: Sage 5 CF 20CV: Subvert CF ZDP-189: Dragonfly 2 Nishijin S30V: Sage 4 Damasteel: Native 5 40th Anniversary VG-10: Delica 25th Anniversary N690Co: PITS XHP: Chaparral Birdseye Maple
Daven82
#218
Post by Daven82 »
I assume this being Part 2 that there is a Part 1? I searched and didn’t find it?
I have never had a need to take a Spyderco apart.
Landshark99
#219
Post by Landshark99 »
another vote for a link to part 1
evil pigeon
#220
Post by evil pigeon »
Landshark99 wrote:
Fri Dec 27, 2024 9:45 am
