Sage 5 in REX 121 + burnt orange
Re: Sage 5 in REX 121 + burnt orange
Hi Dustylse,
Welcome to our forum.
weeping minora wrote: ↑Fri Aug 30, 2024 3:11 pmabbazaba still wants to know: is there confirmation of the CQI pivot in the G-10 variant?
Thank you sir! I have more than a couple Sage5 FRN, and the Sage5 in G10 would be a welcome change so I'm officially on the hunt.Cletus wrote: ↑Fri Aug 30, 2024 3:23 pmWell the blade has zero side to side play or lock play, and it freely swings open and closes with the compression lock depressed. It is exactly like a newer Para 3 g10 and Para 2 in that regard so I suspect it does have the CQI pivot. As an aside, the bevel grind is perfect and the blade is perfectly centered.![]()
Just got my LW in the mail today. Seems great!
- Buddafucco
those are some very clean grind lines on that blade.
Got my G10 version a few days ago, finally got a chance to swap the pocket clip to left hand carry and give it a good look this morning. I have to say this is one of the best examples of Spyderco fit and finish I've ever seen. I do like the burnt orange color myself. Behind the edge it measures about .018" thickening to about .025" at the tip. It will be interesting to put my own edge on this one.
MNOSD member #0035
MNOSD member #0035
Please post your findings/experience when you do!! You have some of my absolute favorite edges around here.Wandering_About wrote: ↑Sun Sep 08, 2024 6:10 amGot my G10 version a few days ago, finally got a chance to swap the pocket clip to left hand carry and give it a good look this morning. I have to say this is one of the best examples of Spyderco fit and finish I've ever seen. I do like the burnt orange color myself. Behind the edge it measures about .018" thickening to about .025" at the tip. It will be interesting to put my own edge on this one.
Thank you,
Daniel
Spyderco's in Rotation: Sage 5 Rex-121 G10, PM2 CPM-15v BBB, Native 5 LC200N.
Spyderco's wanted: Police 4 K390 in G10 PlainEdge (NOT-lightweight)...discontinued :-(
I received my lightweight version yesterday and agree - best fit and finish I’ve seen from Spyderco. Grinds are high and even, lasering of logo, scales, and action are flawless. Really amazing when you consider how difficult this steel is to work with. Kudos to Spyderco for taking their time and getting things right rather than rushing this to market several years ago when REX121 started to get a lot of hype. Worth the wait. Excited to finally test this steel out.Wandering_About wrote: ↑Sun Sep 08, 2024 6:10 amGot my G10 version a few days ago, finally got a chance to swap the pocket clip to left hand carry and give it a good look this morning. I have to say this is one of the best examples of Spyderco fit and finish I've ever seen. I do like the burnt orange color myself. Behind the edge it measures about .018" thickening to about .025" at the tip. It will be interesting to put my own edge on this one.
I've had a custom fixed blade in REX 121 for a couple years, I think. Unfortunately I haven't used it a ton. But the edge on that (which is still as it came from the maker) reminds me of the stock edge on the Sage so far. Not the screaming sharpest edge ever but aggressively cuts cardboard. I will have to sharpen both these knives up and see what happens. The fixed blade is ground thin, about .015" on the entire edge, and I do happen to know that one is 70-71Rc, which is pretty wild. A folder will be much easier for me to use day in day out so I'm interested to see how this steel does. I do think it will be a bit too extreme for me (Maxamet is borderline, 15V seems to be the sweet spot for high hardness/high carbide volume steels for me) but gotta use it to find out.TkoK83Spy wrote: ↑Sun Sep 08, 2024 6:58 amPlease post your findings/experience when you do!! You have some of my absolute favorite edges around here.Wandering_About wrote: ↑Sun Sep 08, 2024 6:10 amGot my G10 version a few days ago, finally got a chance to swap the pocket clip to left hand carry and give it a good look this morning. I have to say this is one of the best examples of Spyderco fit and finish I've ever seen. I do like the burnt orange color myself. Behind the edge it measures about .018" thickening to about .025" at the tip. It will be interesting to put my own edge on this one.
MNOSD member #0035
MNOSD member #0035
- Makunochimaster
we need more photos of this )
Here are a few quick photos of the knife:
MNOSD member #0035
MNOSD member #0035
I like the way you think!
Because I think it looks like baked beans and not a burnt orange
MNOSD 008
I like baked beans.
Fireman: "Can I get, "When life gives you lemons, give it the beans." engraved on my Sage Rex-121?"
Knife Dealer: "Sure thing"
MNOSD 008
Wanted to test a mirror edge on the Bean knife. I think a low grit of 220 would be good from my going through the grits. Next I will test a two grit finish of 11,000 mirror on one side and 220 on the other.
MNOSD 008
