Native Chief to Native 5 blade swap shenanigans
Time to answer the question that nobody wanted an answer for....what do you get when you blade swap Native 5 with Native Chief?
You get these horrible scenes that you can't unsee.
The victims, a St Nick's Chief and a MagnaCut Salt:
Unfortunately for some reason I couldn't get the Salt lock bar pivot pin to fit into the St Nick's lock bar so I couldn't assemble them together at the same time. The lock bar on the Chief is actually a bit longer in the back than the Salt so it couldn't be assembled into the Salt handle.
Don't laugh he ran out of hot water.
Ok so that's actually practical. It will close properly and the blade doesn't hit anything inside just like it normally should. If you really wanted a full size handle but maybe are limited by blade length laws, this could be a real thing.
Then there's this monstrosity..
0/10, can not recommend. Can't decide if tip up is worse than tip down or visa versa.
I'm sorry for this thread but now I can't undo it :winking-tongue
Enactive
Re: Native Chief to Native 5 blade swap shenanigans
Post by Enactive »
Nice one, D!
Also available on video, courtesy of Robin.
Ramonade wrote:
Wed Jun 26, 2024 3:04 pm
I have even been able to put a Native 5 blade in a Native Chief's handle and vice versa ;)
Dave we needed this information! Thank you ! 🤓 Dan
Enactive
Post by Enactive »
It may be possible to build a safety hunter pattern from the Chief blade/ N5 handle combo. :thinking :winking-tongue
https://www.bladeforums.com/threads/bla ... t-22649654
Now I’m curious to know if the Lil Native backlock blade would swap into a Chief handle. :grin-squint
Enactive wrote:
Sat Jul 27, 2024 4:14 pm
Nice one, D!
I should have known I wasn't the first to think of this. I'm truly among my people 🤣
JoviAl
Post by JoviAl »
Oh momma - that chief blade in 5 handle is quite the thing 🤤
- Al
Home: Chap LW SE.
Currently searching for:
Ayoob SE Cruwear
GB2 Cruwear
Ramonade
Post by Ramonade »
Evil D wrote:
Sat Jul 27, 2024 4:55 pm
Nice one, D!
Ahahah, you could not have said it better ! I called the big handle small blade Native Chive, what should we call the small handle big blade one ? Native Ratio ?
ChrisinHove
Post by ChrisinHove »
I’m just glad it wasn’t the Lil Native….
Jesla
Post by Jesla »
This is a German solution…. Just a thought.
Still plays with knives…
ChrisinHove wrote:
Sun Jul 28, 2024 5:50 am
I don't have one but I wonder if they really kept the pivot/lock area the same on those too? It seems smart if they did, why do more R&D on a shortened version if you can get away with not? Knowing Spyderco though they probably did, we can see that the Chief is not just simply a longer Native, given their choice to change the lock bar length.
😅😅 that’s amazing! Thanks for sharing!
I’m sure someone could 3D print a blade cover for the protruding blade that could attach to the lanyard hole or clip screw holes… 🤔
Tristan_david2001
Post by Tristan_david2001 »
^im sure someone could. But why?
:bug-red-white:
cabfrank
Post by cabfrank »
This is why Spyderco discourages disassembly. 🤣
Tristan_david2001 wrote:
Sun Jul 28, 2024 7:46 am
Haha if for no other logical reason than continued shenanigans 🤷‍♂️
Enactive
Post by Enactive »
Nice one, D!
...indeed you are among your people. Fortunately for us all and you too.
VashHash
Post by VashHash »
The little native lock back blade fits in the n5 handle. At least on the rocks glass. Couldn't see if it folded up right.
Ramonade
Post by Ramonade »
VashHash wrote:
Mon Jul 29, 2024 11:36 am
I like being able to choose my glass handles. That's a good find !
kobold
Post by kobold »
JoviAl wrote:
Sat Jul 27, 2024 10:41 pm
Just make a kydex sheath for it and enjoy the best of all worlds.
chronovore
Post by chronovore »
Very fun. For the longer blade, chops are an option. Remember, you don't need an accidentally broken or damaged blade to do a chop. =P
