Thinnest Spyderco model
redrider736
Post by redrider736 »
New member.
I have been edc a PM3-LW and have enjoyed its simplicity & overall size.
What is the thinnest spyderco model?
Looking for something comparable to the PM3-LW just was curious to know if they're is a thinner option?
Michael Janich
Re: Thinnest Spyderco model
Post by Michael Janich »
Dear redrider736:
Stay safe,
Mike
riclaw
Post by riclaw »
Double post.
- Richard
riclaw
Post by riclaw »
Sticking with the Compression Lock in that size range, the Watu might be an option and it is still readily available.
https://www.nationalknives.com/spyderco ... -laminate/
The Sage 5 is the natural alternative to the Para 3 and it has thinner blade stock.
https://www.nationalknives.com/spyderco ... te-handle/
The Sage 5 Lightweight might be the best option.
https://www.bladehq.com/item--Spyderco- ... ght--97437
- Richard
Watu.
Chaparral has a slightly thinner blade, but is quite a bit smaller than the P3.
Michael Janich
Actually, stainless models are even slimmer than the Chaparral and Watu. They are typically between 0.25 and 0.30 thick, versus 0.32-0.34 and 0.41, respectively. Despite their slimness, they are heavier.
Stay safe,
Mike
Welcome to the forum Red Rider.
If you’re asking about a thinner blade, I’d checkout the Chapparal and Dragonfly. They’re both smaller, but very slicey out of the box.
Hopsbreath
Post by Hopsbreath »
Don’t overlook the Centofante 3; it’s hollow ground 2mm blade stock is about the size of a Delica.
You could almost miss a stainless steel Police while patting someone down. Almost..
Ryder
Post by Ryder »
Then Chaparral is thinner than the Dragonfly and I have both and am a huge Dragonfly fan. However I’ve found that even the much thicker Native 5 is very slicey. It’s the blade geometry and how they grind the edge thin. That’s why I am a Spyderco fan or one of the main reasons at least. But the Chaparral is nice and thin and the lightweight version is very portable in pocket and secure in hand. It’s also the most smooth action that really rivals custom folders. For me it took some experimenting to see what floated my boat. I’m locked in tight now. Good luck on your journey.
Actually I was thinking more blade stock thin but overall the Chaparral is a very slim overall piece. Dragonfly is slim overall.
Welcome Red Ryder, I believe the Delica has a thinner blade stock and it’s a classic 👍
northvanbamboo
Post by northvanbamboo »
You can also consider getting your blade reground, ie. Tom Krein does fantastic regrinds
SpyderEdgeForever
Post by SpyderEdgeForever »
Hopsbreath wrote:
Mon Jul 22, 2024 12:59 pm
Yes, I am glad you posted this. I hesitated on the Centofante 3 at 2mm because I'm generally into 3 mm and thicker but I received this model and it is great.
The Catcherman deserves mention, at least.
Airlsee
Post by Airlsee »
Not thinnest, but at 2.5mm and worth considering is the Ikuchi.
So it goes.
Ric
Post by Ric »
Catcherman should have a pretty thin blade as well.
horzuff
Post by horzuff »
Ryder wrote:
Mon Jul 22, 2024 5:18 pm
The Native 5 is pretty far from being slicey ;). Even the Native Chief has a much slimmer geometry and it's no slicer itself. There are plenty other Spydies that straight up flow through material, but the native family (in the latest generation) isn't it.
The japanese backlocks would be my first stop - great price point, K390, lightweight and really good geometry, especially on the delica, though most are really slim.
The Kapara is also a really slim blade and hasn't been mentioned yet
Thin handled - stainless lockbacks
Thin blade - catcherman and z cuts are both under 2mm.
Ryder
Post by Ryder »
horzuff wrote:
Tue Jul 23, 2024 3:08 am
No doubt about it, it’s slicey. However I never use a factory edge and i actually use the knife so I this is easy to ascertain. Probably sharpen different than most giving mine a very acute and still very durable convex edge. Anything that will slice a carrot without breaking it is slicey. I’ve sliced many things with this blade.
tzirconia
Post by tzirconia »
According to the 2024 Amsterdam Meet thread, the upcoming Charisma has 1mm blade thickness, so that should be pretty thin and slicey.
Copied from that thread:
Approximate Specifications
Overall Length: 6.73 inch / 171 mm
Blade Length: 3 inch / 76 mm
Blade Thickness: 0.04 inch / 1 mm
Steel: CTS-BD1N
Weight: 0.8 oz / 23 g
Grind: Full-flat
Handle: FRN
