I'm sure nearly every forumite old and new and in between and thousands or more not on here would buy one or more.
1 a great stainless blade
2 FRN grip
2 SE and PE and CE versions
Please
Not a Spyderco but I’ve had both CRKT and Kershaw liner-locks fail in the past. Both times were with a bit of wrist torque twisting the frame, widening the gap, and causing the lock to slip. Military, Tenacious, Resilience, Gayle Bradley are all rock solid and not prone to the same issues in my experience.SpyderEdgeForever wrote: ↑Sat Jul 20, 2024 9:08 amSide question on this: has anyone on the forum or anyone you know of had a Spyderco liner lock truly fail during use and/or lead to cuts on finger or not ever?
Never!SpyderEdgeForever wrote: ↑Sat Jul 20, 2024 9:08 amSide question on this: has anyone on the forum or anyone you know of had a Spyderco liner lock truly fail during use and/or lead to cuts on finger or not ever?
For me the issue is liner locks eventually bite… an acceptable alternative for me are assisted opening liner locks that stop them from swinging/slamming shut… then there is the issue of safely one hand closing off-handed.SpyderEdgeForever wrote: ↑Sat Jul 20, 2024 9:08 amSide question on this: has anyone on the forum or anyone you know of had a Spyderco liner lock truly fail during use and/or lead to cuts on finger or not ever?
Never, but I could see how some designs on the market are questionable. Except the Military, the tang where the liner lock interfaces has the most aggressive angle where I could never see it wearing down to the point of failure. The choil ends up hitting your thumb if you let it drop all the way. My hands freeze up working in cold temps in the winter and the Military ends up being the easiest for me to use in those times.SpyderEdgeForever wrote: ↑Sat Jul 20, 2024 9:08 amSide question on this: has anyone on the forum or anyone you know of had a Spyderco liner lock truly fail during use and/or lead to cuts on finger or not ever?
Never failed but i have a nice scar on top of my thumb from closingSpyderEdgeForever wrote: ↑Sat Jul 20, 2024 9:08 amSide question on this: has anyone on the forum or anyone you know of had a Spyderco liner lock truly fail during use and/or lead to cuts on finger or not ever?
