It's a base kit that's always in the car and would of course be supplemented by appropriate gear for each specific trip and season. Winters are long and harsh around here and the population density is low compared to most other countries, so any road trip in excess of 3-4 hours would most likely involve passing through desolate areas ond/or exposed mountain passes. Though I've hardly ever run into problems, some level of preparation and planning ahead could greatly impact comfort level and outcome if something unintended were to happen.
The kit has evolved naturally over many years through a multitude of failures and embarrassing moments, as well as some foresight and learning from the mistakes of others. As any other kit it undergoes constant evaluation and tweaking, commonly known as CQI around here, but the rate of changes drop off significantly as the kit has matured over the years.
Glove box:
![Image](https://i.postimg.cc/xTT87PX5/image.png)
band aids, instruction manual, mandatory paperwork, pen, notebook, LM Supertool 300, 17mm socket and extension for the wheel bolts, tick removers, padlocks for the dog cage and barely visable in the back..
![Image](https://i.postimg.cc/gjyhDcB0/image.png)
Resilience S35VN CE and Hultafors OK4
Center console:
![Image](https://i.postimg.cc/hPcHYMSv/image.png)
assorted USB cables for device charging, Astrolux FT03 thrower flashlight, Lumintop TLF/BLF FW3T titanum flood flashlight, Olight Nova CR123 headlamp, spare CR 123 cell and hand lotion.
Under passenger seat:
![Image](https://i.postimg.cc/m2FJTv1g/image.png)
Ice scrape/snow brush and..
![Image](https://i.postimg.cc/W3wrmby1/image.png)
telescopic pipe socket wrench
luggage compartment:
The luggage compartment is completely filled by a custom made, double dog cage. This leaves very little accessible storage for my kit - much less so than my previous 4WD, but there is enough accessible and semi accessible storage to make due.
Side compartment:
![Image](https://i.postimg.cc/90476tMr/image.png)
med kit, work gloves and tool kit with:
![Image](https://i.postimg.cc/MGT3nN34/image.png)
screw driver kit, pipe socket kit, adjustable wrench, 10 and 13mm fixed, ratcheting wrench, paracord, box of assorted screws and vinyl gloves (in zip pocket).
Under floor compartment:
![Image](https://i.postimg.cc/cHccTczY/image.png)
TP, cork screw dog leash attachment, jacking strap, ESEE Darien machete, telescopic snow shovel/hatchet, Fiskars X11S axe, tire repair kit, luggage net and collapsible storage box.
I'd probably move the snow shovel to the roof top rack (as it was in the old car) when I have it fitted to the new car, but there's still a few pieces missing before that can happen.
Although a motorized vehicle impose fewer restrictions on size and weight, I still try to keep it lean and clean and try to avoid unnecessary clutter by assessing the relevance of any item I add to the kit.
Another principle I try to adhere to is not to buy items specifically for this purpose, but rather repurpose items I already own or for items I would own anyway, I just store them in my car if the car is typically near by when I need them.
I did not bother to snap photos of disposable items like paper towels, wet vipes, poo bags etc. as well as mandatory safety equipment like high viz vests and warning triangle. Otherwise that's pretty much all.
Note: This kit is finely tuned for my personal needs, so this is not meant as a recommendation or to start a discussion on the ultimate car kit, it's just a practice that has served me well and proved very useful, so if anything it's just meant as inspiration to make your own kit, for your needs - before you actually need it.
