Would Spyderco fix a screw I ruined on my Lil Native?
paulgvb
Post by paulgvb »
I managed to strip the Torx head of the small screw closest to the Compression lock on the left side scale of my Lil Native Wharncliffe. I was trying to install a new set of beautiful RC Bladeworks scales I just received. All screws came out without issue except for this last one. Since it wouldn’t budge, I just reinstalled the right side scale.
This is totally my fault. I should have first attempted to loosen each screw a bit first rather than replace one scale completely at a time.
Spyderco uses a strong thread locking compound, but I’ve managed to install aftermarket scales on another Lil Native without issue.
Do you think Spyderco would/can drill out the screw and replace the screw and likely the little pipe it screws into and the G10 scale or liner if necessary? I caused the harm so I’m happy to pay for the replacement parts and shop time.
In people’s experience is this a repair Spyderco would even remotely consider doing if paid? Or should I just assume I’ll need to purchase another knife and try again.
Thank you
jdw
Re: Would Spyderco fix a screw I ruined on my Lil Native?
Post by jdw »
I have the exact same issue with a Wharncliff Lil Native. I couldn’t even get the screw to budge before I stripped it. My fault but I am really interested in the reply. Whatever the powdery white stuff they are using is like cement.
--Wovoka
Albertaboyscott
Post by Albertaboyscott »
Ask Spyderco. Everything else is a guess
