First official knife cut out and in progress.
If anyone saw my last design in my design sketch thread. I traced it out in marker on a bar of steel, and used a free hand grinder to rough cut it out and a little thicker of a grinding wheel to clean it up followed by some file work. Here’s how it currently looks.
Current “dream collection” of knives
temperance 1, lil temperance 1 serrated leaf, black micarta calypso jr & calypso, cocobolo kopa, stainless serrated harpy, stainless cricket
Re: First official knife cut out and in progress.
Looks good, what steel did you decide on?
Thanks buddy, 1095
Did some sanding on the face of each side to clean it up a little more,
What are you doing for scales?
I haven’t quite made up my mind on it yet. I got some cherry wood I think would look nice, but my ideal scales would be polished black linen micarta, sourcing and machining those with what tools I got sounds challenging though. If anyone knows, Is sanding and hand filing micarta as simple as wood?
Amazing. I like the design. I assume you will lighten the handle?
The actual work is just as simple.Tristan_david2001 wrote: ↑Sat May 18, 2024 5:52 pmIs sanding and hand filing micarta as simple as wood?
Make sure you have a good breath mask, and preferably also some air filtration running. Micarta dust isn't as bad as G-10 dust, but it's a lot rougher on your lungs than wood dust. Persistent, hacking cough for a week is no fun at all.
Thanks very much for the kind words, and yes the handles gonna get some bigger holes drilled out to lighten the weight as well as pin holes, this steel I’m working on is some stout stock.
Good to know thank you!TomAiello wrote: ↑Sat May 18, 2024 10:58 pmThe actual work is just as simple.Tristan_david2001 wrote: ↑Sat May 18, 2024 5:52 pmIs sanding and hand filing micarta as simple as wood?
- Manixguy@1994
Looks great , nice project . What is the thickness ar spine and do you have a grind you prefer ? MG2
Thanx MG2, it’s coming along better than I expected, I have a little more work to do on the overall profile before I move on to the bevel work, but I’m really satisfied with how clean it’s shaping up. The stock thickness is about 3/16ths, and I’m thinking of doing a high flat saber on this one. Thanks for your interestManixguy@1994 wrote: ↑Sun May 19, 2024 5:35 amLooks great , nice project . What is the thickness ar spine and do you have a grind you prefer ? MG2
Oh yeah, Micarta won't give you trouble. It is just a combination of resin and fabric, to you can saw it, file it, and sandpaper it just like wood. Because it is synthetic, it has a more consistent constitution than wood, and it isn't as fragile, so it can be easier to work in some ways. The only thing you can't do is carve it with a knife.Tristan_david2001 wrote: ↑Sat May 18, 2024 5:52 pmI haven’t quite made up my mind on it yet. I got some cherry wood I think would look nice, but my ideal scales would be polished black linen micarta, sourcing and machining those with what tools I got sounds challenging though. If anyone knows, Is sanding and hand filing micarta as simple as wood?
As mentioned, a mask is important, and the dust can float around even after your done, so many people get a dust collection system. I try to avoid working indoors with such materials because I don't have any dust collection set up.
Looks like it is coming along nicely! Filing the primary bevels are where things will get very interesting. Will you be sending it out for the heat treat?
-- Old Norse proverb
Some progress happening
I think the shape and size of the design came out pretty good. The paper I had drawn the design on from was very thin and flimsy, and I traced on the bar of steel with a thick permanent marker just by holding the paper down on the steel with my hand. Needless to say the drawn design on the steel came out pretty rough and much less refined from my paper design. I’ve got some thicker and sturdier paper and better markers now for future designs. But still this one is coming out pretty satisfying, the ergonomics feel very good for the size, the only thing I wish I could tweak is the blade angle being dropped down just a tad more with maybe slightly less belly. But having a more centered tip angle relationship with the handle can be an advantage, So I’m not overly worried about it.
I’ve got no name ideas
- SpyderEdgeForever
Would or could you use other types of steel, such as Lc200n, or N690?
