Excellent, thanks for the research!
For the record, I get considerable pocket shred on my heavy as well as my lightweight pants. Pockets tend to shred before the knees blow out.
I was speaking specifically in regards to the "pocket bunching" due to the clip placement that was expressed as the issue as of now. I think the model is too new to judge overall pocket wear. All of my pants will wear over time wherever stress/abrasion is present. I suppose time will tell if this model specifically will be worse for the wear.Wartstein wrote: ↑Mon Apr 29, 2024 10:47 pmweeping minora wrote: ↑Mon Apr 29, 2024 11:10 am....
I will say this, if you wear slacks, or thin pants, this may be an issue. I wear thicker pants almost exclusively, and this is a non issue. If this is your primary knife that you will utilize and deploy multiple times per day, this could perhaps become an issue regardless, though I don't always reach for this folder for all of my daily usage. At this rate, I wouldn't see this being an issue for me, and I haven't adjusted the clip to relieve factory tension.
Well, actually ALL of the pants I wear regularily (even the thick and sturdy ones) are/get pretty trashed over time on the right side front pocket from putting my folders in at out of the pocket in daily use... so a design where the clip does not even land on a smooth spot just has to make that worse I guess - ?
Thanks for info Dan . I really like the. The lightweight model and would like an upcoming variant . May have to try out this clip . MG2
I'm tellin' ya, if you try that clip you might end up with a dozen of them!zhyla wrote: ↑Fri May 03, 2024 7:51 amOh dang, should I get the MXG clip and keep this knife? Decisions…
Link to the MXG clip:
https://mxggear.com/collections/native- ... o-knife-10
I’ve had the same issue on other knives with trying to have the clip in tip down. The screws are just slightly too long. I put the ends of them on some sand paper to get a thread or two off. That worked so I was able to carry tip down and the screws wouldn’t protrude through the liners too far.zhyla wrote: ↑Sat May 11, 2024 6:11 pmOk, I was a little worried I was throwing good money after bad, but I ordered an MXG clip. I think it was $27 shipped.
It’s only about an 1/8th of an inch longer but the contact point is way closer to the tip. Huge win. It’s also slightly thicker material so I was hoping I could use the clip tip-down but it still interferes with the blade. So no luck on that.
I like the standard clips but MXG makes a fine clip. Saved this knife from the chopping block… for now at least.
Yeah, I may do that. It’s really unbelievable a knife comes out of Golden and needs the screws ground down. I had this issue with a used Delica and wrote it off as maybe someone swapped another knife’s screws onto it or something.Drubieg wrote: ↑Sun May 12, 2024 6:36 pmI’ve had the same issue on other knives with trying to have the clip in tip down. The screws are just slightly too long. I put the ends of them on some sand paper to get a thread or two off. That worked so I was able to carry tip down and the screws wouldn’t protrude through the liners too far.
It’s annoying for surezhyla wrote: ↑Sun May 12, 2024 8:50 pmYeah, I may do that. It’s really unbelievable a knife comes out of Golden and needs the screws ground down. I had this issue with a used Delica and wrote it off as maybe someone swapped another knife’s screws onto it or something.Drubieg wrote: ↑Sun May 12, 2024 6:36 pmI’ve had the same issue on other knives with trying to have the clip in tip down. The screws are just slightly too long. I put the ends of them on some sand paper to get a thread or two off. That worked so I was able to carry tip down and the screws wouldn’t protrude through the liners too far.
MXG included two sets of screws of different lengths. They’re also too long but I may take them to the grinder for this purpose.
