I just read this article and thought, "hey, maybe that stuff could be used for a new mule? Or would it only work for handles?"
https://www.nasa.gov/centers-and-facili ... s-economy/
GRX-810
Re: GRX-810
Interesting read. Don’t know the answer to the question. But it got me wondering can you 3D print a quality knife?
Greg
MNOSD member #0054
* EDC - Canis S30V, Leafjumper SE K390,
EDC fixed blade - Mule VG XEOS
MNOSD member #0054
Re: GRX-810
Would be cool if this material could be 3d printed into a knife. Don’t know anything about the subject but that caught my attention when it said this material could be used in 3d printing.
Greg
MNOSD member #0054
MNOSD member #0054
Re: GRX-810
This just seems like sintering?
Re: GRX-810
GRX-810 is in the wrong family of superalloys for use as blade material, and it has no carbides. It would also not make a particularly good handle material. It's about 10% denser than steel, and probably has a HRC somewhere around 40 so would scratch easily.
High tungsten stellites like Stellite 20 (45-50% carbide volume, ~60HRC, very high strength and extreme corrosion resistance) are more in the direction of what should be tried as a blade material. Stellite 20 powder can be HIPed into finished parts, and the PM/HIP parts have about 3x the toughness of cast Stellite 20 (but still only about 1/3 the toughness of Maxamet IIRC). Stellite 6 has seen some use as a blade material, but is much softer and has a much lower carbide volume than Stellite 20.
Stellite 20 is the end of the road as far as wear/abrasion resistant alloys go. To achieve higher wear resistance, you have to go to cemented carbide ceramics.
- standy99
Re: GRX-810
After a bit of google-fu it’s probably best used in a washer for the owner that sits on the couch and spydie-flicks he’s blade opened and closed a thousand times a minute. Will be able to withstand the heat generatedHatuletoh wrote: ↑Sat May 11, 2024 10:26 pmI just read this article and thought, "hey, maybe that stuff could be used for a new mule? Or would it only work for handles?"
But basically a part in a turbine engine that gets extremely hot
