Spyderco SpydieChef CQI - Linerlock quality
hvarcz
Post by hvarcz »
Dear Spyderco,
is this for exchange?
Its brand new knife. Its not cheap and it schoul be perfect.
Thansk for answer.
eventhorizon
Re: Spyderco SpydieChef CQI - Linerlock quality
Post by eventhorizon »
As far as I know the SpydieChef's lock is designed to be at about 80% from the get-go, pretty much all knives come like that... it's actually astonishing how consistingly they get this dialed in on point, the chamfer line of the lock part almost always alignes with the left edge of the tang.
Mine came exactly like that and hasn't moved a bit since... so no need to worry, your Chef is all good ;)
notorious fidgeteer
hvarcz
Post by hvarcz »
Ok, thx
Albertaboyscott
Post by Albertaboyscott »
It's a frame lock also. Not a liner lock
Same here with my Chef, so no worries 😃. As the previous comment stated around 80% on the dot.
PM2 Crucarta, Manix 2 lw s110v, Manix 2 blackout, Shaman, Tenacious, GB1, GB2, Smock, Kapara, Native 5 s90v, Chaparral cts-xhp faceted Ti, Para 3 blackout flytanium scales. PM2 M390 DLT exclusive, Caly 3 Superblue sprint run, Police PE ATS-55, Mcbee, Caly 3.5 ZDP189 CF, PM2 Maxamet, Millitary CF s90v sprint run, Lil' Native CF s90v sprint run, Mule CPM Rex T15, Spydiechef, Amalgam.
Mine is like that, and has not moved. It is an older model, pre CQI. 👍
GT99
Post by GT99 »
Curious what the issue you have with it is, are you expecting the frame lock to go further to the other scale to be under the blade 100%? is it the angle? not sure what the issue is because it looks normal to me, would have to check mine when I get home but I am pretty sure its just like that as is my other frame lock (swayback)
sovereign
Post by sovereign »
Perhaps his concern is regarding the late lockup leaving little room for wear resulting in vertical play developing. Perhaps his already has vertical play: viewtopic.php?t=91994
DSH007
Post by DSH007 »
Looks just like mine - pre-CQI Jan 2019 manufacture - and it locks up the same today as it did five years ago.
So long as your Chef's lock-up is secure, I wouldn't expend too much energy nitpicking over the percentages.. use the knife; if the lock ever fails, Spyderco will take care of it.
Rick H.
hvarcz
Post by hvarcz »
Ok, i was worried
Checked mine. Looks identical. No blade play either. Glad to hear from those with lots of miles on theirs that it has not moved. Mine is new to me, so only a little experience with it though it has been put through the ringer in a short amount of time.
