Laser hardening
Fireman
Laser hardening
Post by Fireman »
[media] [/media]
Is this the future of cheap heat treatment? Laser and quench?
Mule Team Army 001 (patched)
MNOSD 008 :usflag
zhyla
Re: Laser hardening
Post by zhyla »
Well… heat treatment isn’t necessarily expensive at volume. You can put hundreds of blades in a batch in an oven or… laser them one at a time?
Fireman
Re: Laser hardening
Post by Fireman »
Maybe it can be a way for micro brands to do heat treat on demand
MNOSD 008 :usflag
Ngati Pom
Re: Laser hardening
Post by Ngati Pom »
That is interesting, it looks as if it’s surface hardening rather than full thickness?
It may have a place for lock faces and high wear areas on handles etc.
'The future is already here;it's just not evenly distributed'
William Gibson
Steveng
Re: Laser hardening
Post by Steveng »
Ngati Pom wrote:
Fri Apr 19, 2024 3:46 pm
Or engine cylinders, where you want maximum hardness on the internal wear area, but retain malleability in the structure
zhyla
Re: Laser hardening
Post by zhyla »
Fireman wrote:
Fri Apr 19, 2024 3:02 pm
It's just not much of a problem to heat treat steel. You buy a heat treat oven and do the right temperature cycle. Quenching can be interesting so maybe if you figure out laser quenching that will help.
Re: Laser hardening
Steveng wrote:
Fri Apr 19, 2024 5:17 pm
Wasn't this the idea regarding samurai swords? What if we could get knife blades that were differentially hardened...harder at the edge and softer (tougher) at the spine?
RustyIron
Re: Laser hardening
Post by RustyIron »
Yes! There are many applications where this is an excellent solution.
