Elastic Ceramic. Wow!
- cabfrank
Re: Elastic Ceramic. Wow!
I don't have any Mules because the fixed blade laws in CA are stupid. I rarely get to carry my Jumpmaster, or even my ARK. I am very tempted by this one though.
Happy Happy Joy Joy! One of the coolest Miles is going to drop in just days!!!!
Mule Team Army 001 (patched)
MNOSD 008
Stable Mules; Z-Max, Z-Wear, Magna Cut, Magna Max, SRS13, Rex 76, Rex T15.
MNOSD 008
Stable Mules; Z-Max, Z-Wear, Magna Cut, Magna Max, SRS13, Rex 76, Rex T15.Re: Elastic Ceramic. Wow!
Really uncertain about this’s one. Might just get me another K294 and/or AEB-L. Can’t really think of a way I’d use the ceramic knife outside of a kitchen setting. Extremely uncertain and open to suggestions. FOMO really sucks though.
Greg
MNOSD member #0054
* EDC - UKPK Magnacut, Salt 2 SE LC200N
EDC fixed blade -
MNOSD member #0054
EDC fixed blade -
Hi Vandyman,
Getting an opportunity to work with a new material in a new format. That's the purpose of the Mule Teams in general and this one in particular. With effective sharpening, we can raise the bar.
Problem solved I’m going to try and get one when they drop. Thank you Sal for the reminder of the purpose of the mule team, I needed that.
Greg
MNOSD member #0054
EDC fixed blade -
MNOSD member #0054
EDC fixed blade -
I noticed that all the sheaths for the HIC mule are sold out. Will the sheaths be restocked? I own a bunch of the leather sheaths and they don’t seem like the best option for this new mule. I want to max protect the HIC mule and get the boltaron sheath for it.
Greg
MNOSD member #0054
EDC fixed blade -
MNOSD member #0054
EDC fixed blade -
I may be wrong, but maybe they just have not been put up for sale yet. Best call the factory. Maybe flipping the sheaths will be where the real money is
MNOSD 008
MNOSD 008
Stable Mules; Z-Max, Z-Wear, Magna Cut, Magna Max, SRS13, Rex 76, Rex T15.-
crazywednesday
Im guessing they made a lot of these. I was allowed to put 3000 in my cart. It was only $450,000.
Justin
- legOFwhat?
Maybe a silly question, but will the black color go throughout the blade or is just the outer part that is black? If grinding on the spine while fitting handles changes the color it might look odd...
-Larry
MNOSD #0049
MNOSD #0049
As far as I understood, it's a injection molding process therefore color should be solid throughout the entirety of the blade.legOFwhat? wrote: ↑Wed Feb 07, 2024 10:53 amMaybe a silly question, but will the black color go throughout the blade or is just the outer part that is black? If grinding on the spine while fitting handles changes the color it might look odd...
- legOFwhat?
Thanks, that's good to hear.vanka wrote: ↑Wed Feb 07, 2024 11:09 amAs far as I understood, it's a injection molding process therefore color should be solid throughout the entirety of the blade.legOFwhat? wrote: ↑Wed Feb 07, 2024 10:53 amMaybe a silly question, but will the black color go throughout the blade or is just the outer part that is black? If grinding on the spine while fitting handles changes the color it might look odd...
-Larry
MNOSD #0049
MNOSD #0049
I could be wrong though. There's more knowledgeable people here that may shed some light on the matter.legOFwhat? wrote: ↑Wed Feb 07, 2024 11:10 amThanks, that's good to hear.vanka wrote: ↑Wed Feb 07, 2024 11:09 amAs far as I understood, it's a injection molding process therefore color should be solid throughout the entirety of the blade.legOFwhat? wrote: ↑Wed Feb 07, 2024 10:53 amMaybe a silly question, but will the black color go throughout the blade or is just the outer part that is black? If grinding on the spine while fitting handles changes the color it might look odd...
But did you hit the UPDATE QUANTITIES button, for the website to adjust to the actual number available? Doesn't sound like.crazywednesday wrote: ↑Wed Feb 07, 2024 9:17 amIm guessing they made a lot of these. I was allowed to put 3000 in my cart. It was only $450,000.
This paper claims to have created a deformable ceramic similar to metal:
https://www.nature.com/articles/s41586-024-07036-5
Maybe this will be the mule in 2040.
S90V: Nirvana Military 2 CF Native 5 Fluted CF Manix XL CF Yojumbo CF Shaman CF Sage 6 CF Native Chief CF MagnaCut: Native 5 Fluted Ti PM2 Crucible CPM-154/S90V: Manix 2 CF 15V: PM2 Marble CF 4V: Manix 2 Marble CF 3V: Tuff REX 121: Sage 5 CF 20CV: Subvert CF ZDP-189: Dragonfly 2 Nishijin S30V: Sage 4 Damasteel: Native 5 40th Anniversary VG-10: Delica 25th Anniversary N690Co: PITS XHP: Chaparral Birdseye Maple
CasperFatone
The color definitely goes all the way through. I’ve drilled two holes in mine and can say this with 100% certainty.legOFwhat? wrote: ↑Wed Feb 07, 2024 10:53 amMaybe a silly question, but will the black color go throughout the blade or is just the outer part that is black? If grinding on the spine while fitting handles changes the color it might look odd...
Amateur maker of folding knives and addicted to modding Spyderco knives
Folding Mules- m398 liner lock, Rex76 compression lock flipper, 15v liner lock flipper, 15v LW compression lock flipper
hollowt1pz
This stuff is far from a new technology ladies and gentlemen.. it's sintering zirconia and alumina essentially like PM steel. It's an oxide ceramic. Mostly for kitchen knives, which most people who have experience in kitchens tell me they prefer high alloy steel due to chipping. I do not have any experience in a kitchen whatsoever. I'm sure the Internet has enough information on ZTA ceramics and this I believe, is a modification of that somehow.
MNOSD 008
MNOSD 008
hollowt1pz
Type of material yes. Same no, different companies, they're in a class called zirconia toughened alumina. Most all work though that chemical process that I don't know myself!.Fireman wrote: ↑Fri Mar 08, 2024 1:56 amhttps://www.bladehq.com/item--Benchmark ... ack--39848
Is this the same ceramic material?
hollowt1pz
How we class say.. stainless steel. Or duplex ferritic and austenitic grades. That's the only similarly to my knowledge but I am far from an expert on this.
I had a funny thought about making a cork handle so it floats. Could be a good salt water fixed fish knife.
MNOSD 008
MNOSD 008
