Show your mods!
- legOFwhat?
Re: Show your mods!
Those all look great Robin! That Native 5 stands out to me the most, really top shelf! May I ask what type of wood that is?
-Larry
MNOSD #0049
MNOSD #0049
Re: Show your mods!
ThankslegOFwhat? wrote: ↑Sat Aug 05, 2023 3:21 pmThose all look great Robin! That Native 5 stands out to me the most, really top shelf! May I ask what type of wood that is?
MNOSD member 004* aka Mr. N5s
- legOFwhat?
Re: Show your mods!
Definitely looks like it was designed for those scales!Ramonade wrote: ↑Sun Aug 06, 2023 7:40 amThankslegOFwhat? wrote: ↑Sat Aug 05, 2023 3:21 pmThose all look great Robin! That Native 5 stands out to me the most, really top shelf! May I ask what type of wood that is?, I tend to prefer wood to carbon fiber or micarta, but I found out pretty fast that you have to find the right wood for a folder, and "Ziricote" wood just goes so well the the Native 5 !
-Larry
MNOSD #0049
MNOSD #0049
- Manixguy@1994
Re: Show your mods!
Looks fantastic Robin ! Definitely an improvement over original design. Buddy Dan
Re: Show your mods!
Re: Show your mods!
Lightweight cruwear dragonfly with crosscut G3 scales
- DansGearAddiction
Re: Show your mods!
Native 5 LW in Maxamet wearing AWT Scales in Magpul FDE cerakote.
Current Collection
Chaparral LW (CTS-XHP), Dragonfly 2 (VG-10), Mule Team (VG XEOS), Native 5 Salt (LC200N), Stretch 2 (K390)
Re: Show your mods!
My friend Dan (ManixGuy), got me into some heat coloring mods.
First try was the Sliverax clip. Hides better in blue jeans with the dark/bronze color.
Just did the same on my Para 3 LW SPY27 (Thank you for that one Spyderco) and Sage 5. Sage 5 has a Lynch Anodized Bronze clip.
Super easy. Takes about 10 - 15 seconds per screw. A little longer on the clip due to the length. Cup of water near by.
- Manixguy@1994
Re: Show your mods!
Great job Jeff . Nice finishing touch . Dan
Re: Show your mods!
Thanks Dan!
barnaclesonaboat
Re: Show your mods!
Finally decided to take the appearance of my first Manix 2 into my own hands. I'm not a fan of bright polished clips on my pocket knives, as I feel it draws more attention to what I'm carrying. I figured I could try heat-coloring a stainless clip with relatively low risk, and yep: It was super easy and satisfying. Peep the pics below.
I would be interested in understanding how to get the deeper colors like I've seen from a number of you bosses.
I ended up with a bit of a gradient, which is super cool and intentional, but I definitely would like to know how to get the color darker if anyone has tips.
The setup:
The product:
(edited: wrong picture attached first time)
JSumm the bronze on your screws looks seriously awesome!
The setup:
The product:
Re: Show your mods!
Looks awesome!
- Manixguy@1994
Re: Show your mods!
I use a small refillable butane handheld torch found at Menards . My technique is a little different than Jeff’s approach . I thoroughly clean clip and run paper clip through center hole and lock other end of clip to my vise . I only heat the backside of clip , starting at bottom and heat till red and move up the clip as it turns red . I make only three to four slow passes . Jeff does a quench where I air cool the clip . Personally I really don’t think there is a right or wrong way , what fits your comfort zone . Satin does appear to work better than stripped painted , and Salt Ti clips are a chore to do . I did experiment ith a Lynspch and think they go to a higher heat range because I could not replicate their Industrial look . Hope this helps . MG2MNOSD 0002 / Do more than is required of you . Patton
barnaclesonaboat
barnaclesonaboat
Re: Show your mods!
Wow! Awesome details, thanks so much. I was really thinking that my heat source needs considerably more power, and even though my stove is wider I don’t think it’s hitting the temps from a torch. I did just let them air cool like you’re describing as opposed to a quench. Great to have your notes on time/speed/heat - I will explore more. Thanks!Manixguy@1994 wrote: ↑Thu Feb 01, 2024 6:30 pmI use a small refillable butane handheld torch found at Menards . My technique is a little different than Jeff’s approach . I thoroughly clean clip and run paper clip through center hole and lock other end of clip to my vise . I only heat the backside of clip , starting at bottom and heat till red and move up the clip as it turns red . I make only three to four slow passes . Jeff does a quench where I air cool the clip . Personally I really don’t think there is a right or wrong way , what fits your comfort zone . Satin does appear to work better than stripped painted , and Salt Ti clips are a chore to do . I did experiment ith a Lynspch and think they go to a higher heat range because I could not replicate their Industrial look . Hope this helps . MG2
barnaclesonaboat
Re: Show your mods!
Manixguy@1994 wrote: ↑Thu Feb 01, 2024 6:30 pmMan, this one turned out so good, too! Great looking fade on the clip over those scales, like a cub brown. Goals.
Re: Show your mods!
That turned out fantastic Dan!
Re: Show your mods!
Did the quenching or air cooling change the tensile strength or springing strength (?) of the clip?
Re: Show your mods!
Current collection: Lil Temperance G10, Shaman, Lil Native, Massad Ayoob cruwear, Smock, Street Beat, Street Bowie, Para 3, PM2 purple G10 cruwear, Canis, Rhino, Endura 4 K390, Watu, Kapara, Amalgam, Sliverax, Police 4 se K390, Police 4 pe K390, Khukuri, Barong, Ulize, Microjimbo, Smock M4, Lil Temperance 3 K390, Bodacious PE S30V.
- Manixguy@1994
Re: Show your mods!
I have had no issues , And have done both styles of clips . I would suggest to be aware that using an extremely high range may could possibly damage a clip . I use a small refillable torch that uses butane . Apply heat to back side of clip to produce better results . I have found that older , thicker clips are more resistant to the process. Lynch clips are thicker and they actually use a higher heat range to achieve their industrial look from my amateur testing. MG2
