I'm not sure how anyone could come to this conclusion after watching these videos:ladybug93 wrote: ↑Fri Dec 22, 2023 6:49 ami've always argued the the two have the same grip profile with just a bit of the hook taken off. you can see this is true in your photos with how the contours on the finger side of the handle line up basically perfectly. i can see though the the extra hook on the manix xl would give a more secure feeling to someone with very large hands.
I've always maintained the grip area on the full sized is larger, and now I have zero doubt in my mind being able to compare them side to side. It isn't just a matter of hook vs no hook. There is more space between the hook and the rear end of the index choil on the full size than there is in the same area on the mini.Here's a little video of me gripping each knife:
Mini Manix - https://streamlala.com/yav3a/
Manix - https://streamlala.com/9qRbG/
Maybe you need to hold them side by side to tell, but they are definitely sized differently there, even if just a few mm. That few mm is the difference for my hand fitting well and not fitting well, so I notice it immediately.
Those differences are admittedly small, but they add up to make the handle fill my grip better.in my comparison, i don't remember noticing the difference in width or thickness of the handle, but it would've been a negligible difference for me because both fit my hands very comfortably.
Like I mentioned, it hasn't been an issue for me. In pants tight enough you can't slide your hand between your leg and the manix, you're going to come up to the full width eventually. If your pants are loose enough to slide your hand between the knife and your leg, width doesn't matter. I carry both a phone and manix in my rfp and it works for me.the clip position looks awkward and makes the knife sit in such a way that the full thickness of the handle is in the opening of the pocket. the manix 2, on the other hand, is clipped at the point of the handle, leaving the opening of the pocket much more accessible. that's one of my favorite things about the design because i also carry my phone in the same pocket. the manix never feels like it's in my way the way other folders sometimes do, and the xl certainly would.
The full sized works great IWB. So does the Military. Knives with about 3/4" to 1" sticking out above the clip work best for me IWB.i would be interested in an xl lw salt though, especially if the clip was relocated. even if it wasn't, i'd still give it a go iwb.
No. The mini is a good knife, but it doesn't meet my particular size preferences. I revisited it on a whim to see if my feelings had changed on it, but to be honest they haven't. The salt version wouldn't offer any advantages for me VS a Pacific Salt, but that's just my preference. I know you've been waiting a long time for one, and it's great you'll finally be able to get one!good comparison. i was surprised to see you go for a m2lw. are you going to get the salt?
