I like the solid border outlining the perimeter of the scales. The milling on the Caribbean goes all the way to the edge and catches on anything I pull out of that pocket.
The border up the center of the scales will probably help material slide under the clip more easily.
Magnacut Paramilitary 2
Re: Magnacut Paramilitary 2
- Richard
- nonstainless
Absolutely! Millie salt will have all yellow handle with black streaks!Manixguy@1994 wrote: ↑Sun Oct 22, 2023 6:23 amI agree , I hope the Military 2 will have its own identity and not just repeat the PM2 variants . MG2RamZar wrote: ↑Sun Oct 22, 2023 6:13 amWith MagnaCut I don’t see a need for a Black DLC Blade for extra corrosion resistance but a Blacked Out version does make it stealthier.Manixguy@1994 wrote: ↑Sun Oct 22, 2023 6:00 amMay be just me and just a guess the Yellow / Satin could be a dedicated Salt and for high visibility. Where the blacked out model could considered more of a street / working land variant. I also could be totally wrong . MG2RamZar wrote: ↑Sun Oct 22, 2023 2:15 amPersonally, I don’t like the yellow stripes on the G-10 scales of the satin model (makes it look like a bumble bee). I think they should’ve put a yellow stripe on the side like they did with the Thin Blue or Red Line Delica, Endura, etc. Much cleaner that way.
A few thin streaks of yellow doesn’t give it much visibility. If the entire scales were a hi-vis color that’d be different. However, making it all yellow G-10 would probably make it less attractive for purchase.
Anyway, I hope when they plan for the Military2 Salt MagnaCut with Satin Blade a better option arises.
Take heed therefore that the light which is in thee be not darkness. L11:35
Black and Yellow digi-cam!nonstainless wrote: ↑Thu Oct 26, 2023 9:34 am
That would actually be pretty coolbobnikon wrote: ↑Thu Oct 26, 2023 11:12 amBlack and Yellow digi-cam!nonstainless wrote: ↑Thu Oct 26, 2023 9:34 am
Quia surrexit Dominus vere, alleluia
I fully agree with you man. The black and yellow is so ugly. Looks like cheap tools you buy at a hardware store hehekennethsime wrote: ↑Fri Oct 20, 2023 2:56 pmI wonder, will the new Salt PM2 fit typical aftermarket scales?
I like Maganacut, but don't care for the black and yellow. I'd love to throw some Micarta on there!
Some titanium scales or Micarta would be awesome. Anything a bit more premium looking for such a nice steel. Now ill have to buy it and get other scales anyway. And dont even get me started that the Para 3 is only a lightweight option. Cant even put on n ice aftermarket scales to help it out.
- kennethsime
Honestly, I don’t mind G10, I’m just particular about colors. Micarta is a nice option if im already changing scales.maansleroux wrote: ↑Sun Nov 05, 2023 10:09 pmI fully agree with you man. The black and yellow is so ugly. Looks like cheap tools you buy at a hardware store hehekennethsime wrote: ↑Fri Oct 20, 2023 2:56 pmI wonder, will the new Salt PM2 fit typical aftermarket scales?
I’m pretty stoked on the P3LW. I like the LW model better than the G10, feels like it takes up less space in the pocket.
- dj moonbat
I have to assume that the black/yellow bumblebee look is an attempt to determine just how far they will have to go to keep the PM2 in Magna-Cut from selling out in ten minutes or fewer.
Or to keep selling also other PM2s in the catalog:)dj moonbat wrote: ↑Mon Nov 06, 2023 3:19 pmI have to assume that the black/yellow bumblebee look is an attempt to determine just how far they will have to go to keep the PM2 in Magna-Cut from selling out in ten minutes or fewer.
Recent favourites: Massad Ayoob CPM CRU-WEAR PE & SE, Yojimbo 2, Lil' Temperance 3.
Just wanted to say thanks for info in this thread. PM2 in Magnacut is indeed first Spyderco I ever ordered, but since my post I also ordered a Millie in crucarta, and a endura wharncliff in K390. Only the endura has arrived so far but it is epic! Can’t wait for my PM2 and my Millie! Woohoo!
