Spyderwebs wrote: ↑Thu Jul 27, 2023 5:50 pmBased on experience, this blade loves strooping. I have been using 4 micron diamond paste on a home made stroop with thick (3-4mm) leather. I loaded up the stroop with paste (both the top and side of the leather), then drag the blade across it almost like a reverse stroke on the sharpmaker, sliding down the leather and the blade simultaneously, with it cocked at the same angle as the tooth grind and downard a 45* so the corner of the leather slides between the teeth.
To finish I lay the non-serrated side flat and pull a couple times. This keeps the Ayoob paper cutting sharp with minimal maintenance. Strooping gets the serrated blade significantly sharper than I can get it off the SM.
Also, the likely flaw is the snaggletooth. If it really bothers you, just reprofile the tip at a steeper angle (like 18-19*) and that will eliminate the snaggle.
Thanks for the advise regarding stropping, I never had to strop H1 SE since I believe it works better with lower grit edges. Maybe I'll try this with Cruwear SE.
