If you had to choose only one…
…blade steel to live with for the next five years, what would it be?
Magnacut
24
25%
Maxamet
2
2%
K390
15
15%
VG10
6
6%
15V
9
9%
M390/20CV/204P
3
3%
4V
4
4%
CPM Cruwear
19
20%
LC200N
6
6%
Other (list in a post below)
9
9%
Total votes: 97
jpm2
Re: If you had to choose only one…
Post by jpm2 »
bdblue wrote:
Tue May 23, 2023 6:04 pm
Rex45
Same here, best balance for my use.
prndltech
Post by prndltech »
I picked other: for h1 or s30v
Vg10 is totally doable for me as well, but I’d probably pick that H1. S30v also has great edge retention.
I don’t own magnacut yet and my experience with lc200n is good, just not as advanced as it is with those steels.
MNOSD 0006
Bill1170
Post by Bill1170 »
I chose MagnaCut based on hearing about its properties, despite zero direct experience. I’m waiting to see it offered in a model I really want, a Caribbean Lightweight or a Stretch XL Salt. I can be patient, have plenty of excellent knives already.
JoviAl
Post by JoviAl »
Bill1170 wrote:
Wed May 24, 2023 12:05 am
I’ve been using a Magnacut mule at work for a couple of hours solid each day for the last year. It is pretty much as good as the hype suggests (Spyderco’s Magnacut HT anyway) and is extremely stainless. I just really like k390 even though it literally rusts in my pocket (I live in the tropics) - it is just that nice to sharpen and use!
- Al
Home: Chap LW SE.
Currently searching for:
Ayoob SE Cruwear
GB2 Cruwear
jpm2 wrote:
Tue May 23, 2023 6:56 pm
Rex45
Same also here:
Rex45 (HAP40) for PE.
But VG10 for SE (and an "only one" folder definitely would have to be in SE for me)
DavidNM
Post by DavidNM »
I selected K390. It was a random choice but it sounds good.
elena86
Post by elena86 »
Evil D wrote:
Tue May 23, 2023 12:03 pm
Tue May 23, 2023 11:14 am
lc200n is fine, but i've found it to be lacking slightly to h1 when it comes to toughness in serrations.
Just wondering if you're testing these at the same edge inclusive angle? The H1 Salts I've had were very thick at the edge, especially if you're comparing them to a Caribbean. With the way serrations are ground at different angles it's something to consider when trying to compare steels in SE.
Which SE blade would you say is the thinnest bte ? From those you own of course ... I guess you didn't measure the XL SE Stretch ...
Marius
( Rabindranath Tagore )
elena86 wrote:
Wed May 24, 2023 7:01 am
I guess sadly David actually does not HAVE the Stretch XL SE - would really be interested in his opinion on that one...
Without a doubt the ARK, but folder wise I think the lowest angles I've seen (which micro bevel the edge on the 30 degree slots so they must be ground below 15 degrees) are my MagnaCut Native 5 and Autonomy 2. I don't believe all of the Natives are ground this way though, I think I just got lucky.
steelcity16
Post by steelcity16 »
Cruwear, easy answer
Magnacut but I’d hate to give up H1 and Cruwear
Bill1170
#32
Post by Bill1170 »
JoviAl wrote:
Wed May 24, 2023 1:19 am
Thank you! Field reports like yours that back up the other information are helpful to have.
shunsui
#33
Post by shunsui »
I haven't played enough with magnacut and 15v to make a good comparison. I have used K390 for awhile now and it's very impressive for simple EDC where all you want to do is cut things up or open. We may be overthinking all this, I got by just fine with ATS-55 for years.
BigFishShamu
#34
Post by BigFishShamu »
shunsui wrote:
Fri May 26, 2023 5:20 am
Well said. I appreciate that we have the luxury to pick and choose which steels to EDC and put to work. I also remember my grandpa had used the same Buck 110 for every chore under the sun from when we went fishing to cutting a bunch of cardboard!
#35
My experience with Magnacut is still limited to one knife by a different mfg. So far it's surpassed my expectations even with all the hype, but I voted K390 because it's still my favorite steel I have the most experience with.
#36
CruWear for me until I try a Magnacut folder this has become my favorite steel in the future that could change .
ZrowsN1s
#37
Post by ZrowsN1s »
K390 because it's been more used/vetted by me. 15V has some good potential though. Need more time with it. S90V would be my second choice.
