That photo is phenomenal Ryder and I’ve got to try k390 in a delica…do us all a favor and post that pic on “photo of the week “
Which Delica 4, is the right Delica?
Re: Which Delica 4, is the right Delica?
Yes Cycleguy we are indeed Wildcats down here.
Thanks Salty!
Thanks Salty!
I love the 20CV Delica with either blade shape. Corrosion resistance is a significant concern for me, so I if want something fancier than LC200N I likely have my 20CV Delica in my pocket. It's a great steel that I very much enjoy using. I can't speak to the M4 as I have no experience with it.
The standard Delica is screw construction with steel liners.
MNOSD member #0035
MNOSD member #0035
Is the hollow ground (is that what it is) worth a try?
Mostly. There are some specific variations of the Delica 4 that are different. They are very few. You probably won't buy one by accident.
The FRN Delica 4 has screw construction and nested stainless steel liners.
There's a stainless steel handle Delica 4 which is pinned and has no liners.
There's a titanium Delica 4 with screw construction with no liners.
There's a pakkawood Delica 4 (knifecenter exclusive) which has full liners under pakkawood scales.
There used to be G-10 Delica 4s with G-10 scales and full liners.
There is no hollow grind on the Delica, as far as I know, except of old (not current) versions of the ss handled one.
There will be one again with the sprint "high performance" Delica.
So I guess you're looking at the sabre grind Delica?
Well, imo no match for the ffg Delica when it comes to cutting performance - but boy, a real hard use knife as it should be! Though the bladestock is just 2.5 mm, the rather low sabre grind, very stout tip and the steel liners make it pretty indestructible! And that for a weight of a Para 3 LW.
Hi Jesse,
Welcome to our forum.
The standard flat-ground VG-10 Delica is for me the best all-rounder in the Delica line.
- standy99
The knifecentre pakkawood is the best Delica going in my book
Correct, but there is on the H1 Salt2.
A really hard use knife.
For everyday carry the LC FFG is probably a better fit.
MNOSD member 0011
Oh man... how could I forget! You are right 100% and thanks for correcting me! (Yes, I know, technically the Salt 2 is not a Delica, but still)
Wartstein wrote: ↑Sat Mar 11, 2023 5:45 am
The stainless steel(handle) Delica is hollow ground.
Marius
( Rabindranath Tagore )
SS was HG, as wWartstein already pointed out, but currently is SG.
Correct me if I'm wrong.
MNOSD member 0011
I agree, and it's currently in stock and on sale and you get 2X rewards points at KnifeCenter this weekend...no brainer decision!
https://www.knifecenter.com/item/SP11WD ... -exclusive
15 's in 10 different steels
All of the Delicas.
Not any more, I think.elena86 wrote: ↑Sat Mar 11, 2023 6:39 amWartstein wrote: ↑Sat Mar 11, 2023 5:45 am
As said in my previous post: At least the ss Endura is no longer hollow ground for quite some time now, but sabre grind. I am pretty sure this is true for the ss Delica too - ?
Added to my post above: SS Delica, current version, sabre- not hollow grind indeed...
https://www.spyderco.com/catalog/details/C11/210
