Which Delica 4, is the right Delica?
Re: Which Delica 4, is the right Delica?
Ryder wrote:
Fri Mar 10, 2023 4:22 pm
cjk wrote:
Fri Mar 10, 2023 1:15 pm
Ryder wrote:
Fri Mar 10, 2023 12:11 pm
The Delica is the finest EDC pocketknife in the world....
Cool picture Ryder!
Thanks. There are seven major canyons I can walk to from home leading from desert to mountain peaks. Trails connect 400 square miles of wilderness and National Forest. It would be folly to venture in here without a Delica 4 as part of the 10 Essentials. :smlling-eyes
That photo is phenomenal Ryder👏 and I’ve got to try k390 in a delica…do us all a favor and post that pic on “photo of the week “👊
Ryder
Post by Ryder »
Yes Cycleguy we are indeed Wildcats down here.
Thanks Salty!
SchoonerBum
Post by SchoonerBum »
I love the 20CV Delica with either blade shape. Corrosion resistance is a significant concern for me, so I if want something fancier than LC200N I likely have my 20CV Delica in my pocket. It's a great steel that I very much enjoy using. I can't speak to the M4 as I have no experience with it.
Wandering_About
Post by Wandering_About »
The standard Delica is screw construction with steel liners.
MNOSD member #0035
sethwm
Post by sethwm »
Is the hollow ground (is that what it is) worth a try?
cjk
Post by cjk »
Sherer19 wrote:
Fri Mar 10, 2023 2:35 pm
One thing, I assume all Delica 4 are screwed construction with steel
Liners under the FRN?
Mostly. There are some specific variations of the Delica 4 that are different. They are very few. You probably won't buy one by accident.
The FRN Delica 4 has screw construction and nested stainless steel liners.
There's a stainless steel handle Delica 4 which is pinned and has no liners.
There's a titanium Delica 4 with screw construction with no liners.
There's a pakkawood Delica 4 (knifecenter exclusive) which has full liners under pakkawood scales.
There used to be G-10 Delica 4s with G-10 scales and full liners.
sethwm wrote:
Fri Mar 10, 2023 6:50 pm
There is no hollow grind on the Delica, as far as I know, except of old (not current) versions of the ss handled one.
There will be one again with the sprint "high performance" Delica.
So I guess you're looking at the sabre grind Delica?
Well, imo no match for the ffg Delica when it comes to cutting performance - but boy, a real hard use knife as it should be! Though the bladestock is just 2.5 mm, the rather low sabre grind, very stout tip and the steel liners make it pretty indestructible! And that for a weight of a Para 3 LW.
Hi Jesse,
Welcome to our forum.
Bill1170
Post by Bill1170 »
The standard flat-ground VG-10 Delica is for me the best all-rounder in the Delica line.
standy99
Post by standy99 »
The knifecentre pakkawood is the best Delica going in my book
tonijedi
Post by tonijedi »
Fri Mar 10, 2023 10:38 pm
Correct, but there is on the H1 Salt2.
A really hard use knife.
For everyday carry the LC FFG is probably a better fit.
MNOSD member 0011
#32
tonijedi wrote:
Sat Mar 11, 2023 4:40 am
Oh man... how could I forget! You are right 100% and thanks for correcting me! (Yes, I know, technically the Salt 2 is not a Delica, but still)
elena86
#33
Post by elena86 »
Sat Mar 11, 2023 4:45 am
The stainless steel(handle) Delica is hollow ground.
Marius
( Rabindranath Tagore )
aicolainen
#34
Post by aicolainen »
elena86 wrote:
Sat Mar 11, 2023 5:39 am
I have no idea, but the product page says saber
tonijedi
#35
Post by tonijedi »
SS was HG, as wWartstein already pointed out, but currently is SG.
Correct me if I'm wrong.
MNOSD member 0011
#36
standy99 wrote:
Sat Mar 11, 2023 3:08 am
I agree, and it's currently in stock and on sale and you get 2X rewards points at KnifeCenter this weekend...no brainer decision!
https://www.knifecenter.com/item/SP11WD ... -exclusive
twinboysdad
#37
Post by twinboysdad »
All of the Delicas.
sethwm
#38
Post by sethwm »
What makes it so ?
#39
Not any more, I think.
As said in my previous post: At least the ss Endura is no longer hollow ground for quite some time now, but sabre grind. I am pretty sure this is true for the ss Delica too - ?
#40
Added to my post above: SS Delica, current version, sabre- not hollow grind indeed...
https://www.spyderco.com/catalog/details/C11/210
