How did you tap the clip holes?CasperFatone wrote: ↑Mon Feb 27, 2023 6:14 amHere is how I modify mine. I love the knife in this size!
Manix Modifications. What have you done? What do you want to do?
Re: Manix Modifications. What have you done? What do you want to do?
"Some call me...Tim?"
That looks great!
CasperFatone
I drilled the holes on a drill press and tapped them by hand with a 2-56 tap using a pin vise. You just have to go slow and use a cutting lubricant.Paraguy wrote: ↑Thu Mar 09, 2023 2:32 pmHow did you tap the clip holes?CasperFatone wrote: ↑Mon Feb 27, 2023 6:14 amHere is how I modify mine. I love the knife in this size!
Amateur maker of folding knives and addicted to modding Spyderco knives
Folding Mules- m398 liner lock, Rex76 compression lock flipper, 15v liner lock flipper, 15v LW compression lock flipper
CasperFatone wrote: ↑Fri Mar 10, 2023 2:03 pmI drilled the holes on a drill press and tapped them by hand with a 2-56 tap using a pin vise. You just have to go slow and use a cutting lubricant.Paraguy wrote: ↑Thu Mar 09, 2023 2:32 pmSo the tap was compatible with the original screws?CasperFatone wrote: ↑Mon Feb 27, 2023 6:14 amHere is how I modify mine. I love the knife in this size!
CasperFatone
The stock clip screws are 2-56 thread. You just need to drill #51 size holes in the right spots, then thread them carefully by hand using a tap in a small pin vise (like a mini screwdriver). I drill and tap for one screw first, then use that to attach the clip. That lets you use the clip as a guide for the other holes.Paraguy wrote: ↑Fri Mar 10, 2023 3:45 pmCasperFatone wrote: ↑Fri Mar 10, 2023 2:03 pmI drilled the holes on a drill press and tapped them by hand with a 2-56 tap using a pin vise. You just have to go slow and use a cutting lubricant.Paraguy wrote: ↑Thu Mar 09, 2023 2:32 pmSo the tap was compatible with the original screws?CasperFatone wrote: ↑Mon Feb 27, 2023 6:14 amHere is how I modify mine. I love the knife in this size!
Not saying I want to do this...but...interesting! Found on Etsy.
— AWT aluminum linerless scales…..awesome…slimmer profile, lighter weight, deleted lanyard barrel in favor of a standoff, easier to disassemble and service the knife.
— brass ball cage….notably better purchase with jimping (scale contour also helps), better cosmetics
— Ceramic ball….changed out first, felt no effect but needed $8 peace of mind, LOL
— Medium spring….changed OEM spring out, obvious difference with medium spring….perfect tension for ease of manipulation without being too soft (also tried the “light” spring and it was too soft)
Yep, knife got >$300, but it runs perfect now….much more fun and sweet to put thru it’s paces 1-handed. I won’t do THAT again….but once was great
Manix 2 15V BBB Sprint Run. Black grooved micarta scales. Flytanium titanium cage lock. Upgraded to a ceramic ball bearing. Also added a Glow Rhino tritium lanyard hole insert. Its my user.
- Brock O Lee
I am for the most part content with most Spydies as they come from the factory, but I made an exception for the Manix. These AWT scales elevate the Manix to another level for me, with numerous improvements over stock. While I was in there I replaced the steel BB's with ceramics too. The springs are standard. The M4 has a MXG spoon clip and a brass cage.
freebird610
How did you go about the carbon fiber lightweight Manix? That’s awesome!abbazaba wrote: ↑Thu Dec 29, 2022 6:36 pmI used to consider myself a Manix guy, before I fully came around to the PM2. At one point I had commissioned a CF LW, originally a Brown XHP exclusive:
The whole process made me think that I should just do it myself next time, so I made a set of Cocobolo scales, which I all but finished because I couldn't decide if I wanted to drill them for a stock clip, or try to machine out some grooves for a wire clip. I plan to finish them for the 15v, but here's a teaser pic from 2017:
Adding a metal cage to the knife didn't really excite me the way I hoped, but it does look pretty sweet IMO:
I'm really temped by the linerless scale mod as well, but I just never really carry a Manix anymore, other than a LW in one of my hiking kits.
I keep posting pics of my tip-down mod, because it's the only thing that makes it carryable to me. And I got a blurple Manix 2 coming next
ImHereForTheMilitary2
I really want to put a titanium cage in but after seeing some of the videos I'm kinda terrified. Not gonna lie
- apollo
Its not that difficult. Patience is what you need and do not forget to look what side of the cage is up and what is down (for the place the ball rests in ) and you will be alright.ImHereForTheMilitary2 wrote: ↑Wed Aug 23, 2023 5:04 amI really want to put a titanium cage in but after seeing some of the videos I'm kinda terrified. Not gonna lie
changing the cage out isn't that bad. you can just lift and rotate the scales and liners out of the way. to switch it out. changing out the scales is the hardest part of customizing the manix because the lanyard tube makes it very difficult to remove and replace scales.ImHereForTheMilitary2 wrote: ↑Wed Aug 23, 2023 5:04 amI really want to put a titanium cage in but after seeing some of the videos I'm kinda terrified. Not gonna lie
I just noticed that on one of my Manix 2's that the lanyard tube is flared out at the end making it impossible for me to remove the liner (I'm replacing the lanyard tube with a Glow Rhino tritium plug) without damaging it or the liner itself. I'm getting frustrated. I've never run into this before. I have had them real tight, but never flared to the point that they cant be removed.lanyard tube makes it very difficult to remove and replace scales.
This product helps a lot with the lanyard tube removal.
https://www.sharpdressedknives.com/lanyard-cube-1
I have the Black DLC S30V G10 Manix 2.
Tan TeroTuf Scales (these were left handed, I drilled my own right handed holes)
Green and purply TI Clip from Etsy
Green hardware / pivot from Etsy
Aluminum Ball Cage
Ceramic Ball
1 step down spring
Only the blade, lock bar, liners and lanyard tube are original.
Aluminum Ball Cage
Ceramic Ball
1 step down spring
gotta ask... how is the slotted cage? is there any advantage to it, or is this just a looks thing?
i'm already familiar with the flytanium cages... specifically asking about the slotted version. thanks!
I like it. It's comfortable for me. I can grab it easily and not slip off. It was primarily a looks thing for me. I think the 1 step down spring plays more of a factor tho.
all the aftermarket cages are for aesthetics. they don't change the function.
