Show your Mule
Re: Show your Mule
#1641
standy99 wrote:
Sat Feb 25, 2023 3:57 pm
For me it’s just from lanyard brass tubing, set like pins. (Which is available at most knife suppliers)
Thanks...so for setting the tubes, do you just get a tight fit between tube and scales, and epoxy in place? Or are you flaring the tubes so they "lock in" to the scales? Is there any flaring/squishing/deforming the tops of the tubes that occurs, to make the fit more secure? And if so, does that raise the risk of cracking the scales?
standy99
Re: Show your Mule
#1642
Post by standy99 »
Bolster wrote:
Sat Feb 25, 2023 7:45 pm
No flaring, squishing needed as epoxy is good enough in my book. I use slow curing epoxy and never had a issue with pins or tubes in any of my knives and I make some hard working hunters outside of mules
standy99
Re: Show your Mule
#1643
Post by standy99 »
Connman
Re: Show your Mule
#1644
Post by Connman »
Beautiful wood there Standy , reminds me of Mesquite scales I have on a Swick
standy99
Re: Show your Mule
#1645
Post by standy99 »
Connman wrote:
Wed Mar 01, 2023 9:27 pm
Australia Ringed Gidgee
Making a knife for US Marine friend at the moment with a beautiful piece.
legOFwhat?
Re: Show your Mule
#1646
Post by legOFwhat? »
Andrew that's gonna be beautiful! Will it go on a MT?
-Larry
MNOSD #0049
standy99
Re: Show your Mule
#1647
Post by standy99 »
legOFwhat? wrote:
Fri Mar 03, 2023 7:31 am
No one of my knives
Sent you a PM
ImaCutSumSchitt84
Re: Show your Mule
#1648
Post by ImaCutSumSchitt84 »
This was completed in 2019. MT27 PD#1 with Amboyna burl scales and full custom Sheath. I really wish I would've bought a couple more sets of the Amboyna because the blanks available at that time were unlike any other I've seen since.
PM2 TripleB 15v, PM2 BB K390, Shaman TripleB 15v, Shaman BHQ DLC M4, Shaman Cru-Carta, Para 3 DLT DLC Cru-Wear, Para 3 BB K390, Para 3 FL Elmax, GB Folder 2 M4, Slysz Bowie M390, SpydieChef LC200N, Native Salt LC200N, Domino BB CTS-204p, Delica 4 K390, Dragonfly S30V, Manix 2 s110v, Manix 2 LW Maxamet, Mule Team 27 PD#1 Amboyna burl
Wishlist: Chaparral TripleB 15v, Chaparral blue denim Micarta Rex121, Sage 5 blue denim Micarta Rex121
tcarltonw
Re: Show your Mule
#1649
Post by tcarltonw »
ImaCutSumSchitt84 wrote:
Fri Mar 03, 2023 8:39 am
Are you familiar with Greenberg Woods? He has all sorts of ridiculousness.
ImaCutSumSchitt84
Re: Show your Mule
#1650
tcarltonw wrote:
Fri Mar 03, 2023 11:42 am
No sir, I mainly used a dealer named Island Woods from Hawaii because he had a huge selection of exotic species. I'll definitely look into them though.
tcarltonw
Re: Show your Mule
#1651
Post by tcarltonw »
Fri Mar 03, 2023 12:30 pm
Good deal I'll check them out as well.
Greenbergwoods.com & greenberg_woods on Instagram.. he post more on Instagram than there is on his site. His stuff is pricey but it's all absurd.
TTFulltimer
Re: Show your Mule
#1652
Post by TTFulltimer »
My Sexy Rexy. Rex 76 camp knife. Zebrawood with integral guard. Shaped on a Wen oscillating drum sander. Polished with scotch brite wheels, then put on a burnished carnauba wax finish with felt wheel. Old pipe maker taught me that finish 65 years ago and gave me a big piece of wax. I still have 90 percent of that wax. The carnauba makes a squeaky kind of grippy finish very secure.
I used four power tools, a drill press, a table saber saw, a belt sander and the oscillating drum sander. All of those and the tools needed for them will easily fit in a 2 foot on a side cube with room to spare. Have to be resourceful when you travel full time and live in a travel trailer.
This is the first knife handle I have ever made, made lots of handles for fishing rods. Knife will get a leather lace lanyard. I have a temporary no frills leather sheath.
Just a crotchety old curmudgeon who has seen a thing or two
tcarltonw
Re: Show your Mule
#1653
Post by tcarltonw »
Here are a cpl amboyna he posted today
COSpaceMarine
Re: Show your Mule
#1654
Post by COSpaceMarine »
Bolster wrote:
Fri Feb 24, 2023 10:07 pm
COSpaceMarine wrote:
Thu Feb 23, 2023 4:43 pm
One more mule, this time in SPY27 with Maple and blue epoxy scales
Dialed in shape of the scales a lot more on these and feels much better in hand.
Tried setting the brass inserts and pushed a little harder than necessary, cracked the rear... still learning, but enjoying the process
So how do those circular brass connectors work? Did you make them yourself from tubes of brass? And how do you "set" them?
Looking really good, BTW.
I found a few 3/8" brass ball bearing sleeves, they were about $2/pc at Ace. I had tried to set them using epoxy an then expanding them into place using a press. However, since i hadn't annealed the brass prior to, one of them did split slightly.
Re: Show your Mule
#1655
Mon Mar 06, 2023 12:55 pm
Sorry I have so many questions. I would do same, I would want to expand as well as epoxy. When you expanded the tubes into place, you used what to do that? I'm thinking, a (turned off) drill press with a 45 degree countersink bit or something like that, and you just press the 45 degree countersink down to spread or to "bell" the outside edge of the tube slightly?
Hadn't thought about the annealing. So in that case, heat either side of the brass tube with a torch beforehand?
ImaCutSumSchitt84
Re: Show your Mule
#1656
tcarltonw wrote:
Mon Mar 06, 2023 12:16 pm
Oh man those are perfect! For anyone who hasn't seen Amboyna in person its covered in chatoyance just like curly species. The difference is the shapes and depth it has due to it being burled makes you wanna stare at it for hours finding new layers and shapes with every little twist in the light.
COSpaceMarine
Re: Show your Mule
#1657
Bolster wrote:
Mon Mar 06, 2023 1:54 pm
I had used a 1-ton arbor press from Harbor Freight
bob-atlatl
Re: Show your Mule
#1658
Post by bob-atlatl »
just finished this SPY27, it was an experiment using M5 SS bolts, with the heads turned down to fit a 3/8" dia countersink.
next time will drill all three dia holes for each bolt, at once, to ensure proper alignment.
first time using olivewood for scales, like this wood a bunch.
... rule #9 ...
Re: Show your Mule
#1659
Mon Mar 06, 2023 3:43 pm
HA! That's the exact same press that I own!! LOL.
TTFulltimer
Re: Show your Mule
#1660
Stet
