Coarse stones for sharp maker
WyoJon
Post by WyoJon »
https://www.sharpeningsupplies.com/Alum ... -P719.aspx
Here are some nice coarse stones that will fit the sharp maker. Norton makes some in the india stone, but they are only 4"
Superflex
Re: Coarse stones for sharp maker
Post by Superflex »
Congress Tools also has 1/2" x 6" triangulars in may varieties.
I have the moldmaster set. The coarser stone (80 and 120) are a little rough on the edges. The finer stones are outstanding.
https://www.congresstools.com/catalog/c ... ory/?id=72
Bemo
Post by Bemo »
Thanks, that's half the price of the Idahone stones: https://idahoners.com/products/7-triang ... 2238502026
My only concern would be with wear/dishing and trying to lap them.
wrdwrght
Post by wrdwrght »
Evil D wrote:
Sat Jan 28, 2023 10:09 am
What do you use for lapping, David?
Post by JD Spydo »
Thank you "WyoJon" for bringing up this subject. I've been saying that same statement over and over for years now concerning the 204 Sharpmaker not having a set of super aggressive stones. That's the one thing that makes the 204 Sharpmaker slightly less than perfect is the fact that they never made any stones that can remove stock at a faster rate. Oh sure the diamond stones somewhat address that problem but they don't do what a high quality extra coarse stone can do for a really dinged up, damaged blade edge.
I will be checking out this source to see what will work on my 204 Sharpmaker and make it a better sharpening tool. Because the 204 Sharpmaker kit is without a doubt the best kit you can take into the field or in any situation you don't have electricity handy. I tend to like to sharpen manually most of the time. I kind of get a feel for what it takes to make the edge super sharp when I do it the hard way.
Post by JD Spydo »
Just out of routine I tend to replace all my "Medium stones" periodically especially on the Sharpmaker at least every 2 & a half to 3 years. Because as much as I use them I know they dish out and become uneven over time. I've only ever had to replace one set of FINE stones for the Sharpmaker. and I've never had to replace any Ultra-Fine stones ever.
Because the Medium stones on the 204 Sharpmaker are priced low enough that you don't have to lap them. It saves me a lot of time. I've even had to replace one of the medium stones on one set of my Spyderco 302 Benchstones. Even though the medium stones will wear over time it takes a while before they need replacing. Albeit if I could do it really efficiently I would be open to suggestions and time saving methods I may not be aware of.
JD Spydo wrote:
Sat Jan 28, 2023 11:50 am
I replaced my medium stones for the first time last year, and man what a difference 10 years makes.
I’ve also been better about cleaning my stones recently, which helps a lot.
WyoJon
Post by WyoJon »
JD Spydo wrote:
Sat Jan 28, 2023 11:42 am
I held off on a sharp maker for over 15 years because there was no course. Finally bought one recently. Used the stones by hand for finishing edges for years before.
WyoJon
Post by WyoJon »
Superflex wrote:
Sat Jan 28, 2023 9:40 am
How do they compare to sharpmaker brown?
wrdwrght wrote:
Sat Jan 28, 2023 11:39 am
A big diamond plate but I wanna get some glass and SIC powder, I think the plate is the wrong grit for my other stones, they tend to stop cutting as well after I lap.
Deadboxhero
Post by Deadboxhero »
They must have sharpened hundreds of knives at Shot Show, I believe they were using the Diamond/cBN rods which was really handy because they don't load or require any liquid.
They were sharpening knives pretty quickly for people that were waiting.
Big Brown Bear
Triple B Handmade Knives
WyoJon
Post by WyoJon »
Evil D wrote:
Sat Jan 28, 2023 1:07 pm
I think ive degraded a few good bench stones lapping poorly. Im always afraid not matching the stones grit ill end up surfacing the stone to a grit different than the stones partcle size. I surfaced a ceramic stone once and ruined it making it smooth.
wrdwrght
Post by wrdwrght »
WyoJon wrote:
Sat Jan 28, 2023 1:25 pm
Lapping the friable stuff I have on hand is something I’m doubtless “past-due”, but I know nothing about lapping except its concept.
So, the lapping surface must match the grit of the abrasive you’re maintaining, thus the possible need for multiple lapping stones?
wrdwrght
Post by wrdwrght »
Thanks.
The glass plate and “swappable” SIC grit makes budgetary sense, at least.
WyoJon
Post by WyoJon »
Since it will take weeks for Assassins Inc to deliver any stones I order with all the snow storms, I got some sand paper and binder clips as others suggested. The pictures explain the technique.
WyoJon
Post by WyoJon »
WyoJon
Post by WyoJon »
Well my old beater ka bar 1189 that i bought used and beat up when i was about 13 that had no bevel set on it what so ever, which has always been a pain to put a decent edge on, feels like some old 440a stainless, I used the sharp maker at 30 deg, about 15 minutes with 120 grit, 5 minutes with 220, then straight to the brown sharp maker up to the ultra fine. Has a nice perfect bevel that is mirrored and is easily slicing rolling papers.
WyoJon
Post by WyoJon »
This knife is so beat up the chips in the brass are deaper than file work. The wooden scales dont alight with the brass anymore. Yet this thing is still solid, no play at all in the lock up. Bought a buck 110 not long after this, and still carried this one for years, till my first spyderco sometime in college. Its about 40% thinner than a buck 110, has a better blade profile and nice jimping on the blade spine.
WyoJon wrote:
Sun Jan 29, 2023 12:18 pm
I managed to reprofile Maxamet using this method so it absolutely does work. I'd recommend a decent quality silicon carbide sandpaper, I use this pack off Amazon, pretty good stuff for $8.
120 To 3000 Assorted Grit Sandpaper for Wood Furniture Finishing, Metal Sanding and Automotive Polishing, Dry or Wet Sanding, 9 x 3.6 Inch, 36-Sheet https://a.co/d/9Ow4nrS
