CPM 15v Manix 2
Ramonade
Re: CPM 15v Manix 2
#1341
Post by Ramonade »
I've been cutting a LOT with mine and a 9 micron gunny juice strop have been able to bring it back 99% each time. I'm only losing 1% at a time, very slowly, it's good !
Now that someone mentionned a Native 5 in this steel, I can't get it out of my head.... In G10 please!!!
RustyIron
Re: CPM 15v Manix 2
#1342
Post by RustyIron »
Deadboxhero wrote:
Sat Jan 14, 2023 2:20 am
I'm excited that you guys are going to get more Spyderco CPM 15V. It was really fun getting you guys this Heat Treatment.
1. When someone buys a sheet of CPM 15V from the factory, does it arrive with an "off the shelf" heat treatment that is suitable for making a knife? Or does everyone purchase "raw material" that must be heat treated according to standard "recipes?"
2. When you started your CPM 15V experiments, were you confident you could make it better than what had been done in the past? Is it this way with all "off the shelf" steels, where a dedicated craftsman can improve upon the generally accepted practices?
electro-static
Re: CPM 15v Manix 2
#1343
Post by electro-static »
Ramonade wrote:
Sat Jan 14, 2023 7:54 am
Great to know!
Bemo
Re: CPM 15v Manix 2
#1344
Post by Bemo »
I'd take a linerless G10 even the same brown. Would love to have that BBB logo on it. I can almost see it now.
Ramonade
Re: CPM 15v Manix 2
#1345
Post by Ramonade »
Bemo wrote:
Sat Jan 14, 2023 12:00 pm
Totally ! I don't have a linerless N5 yet so it would make a good excuse :winking-tongue . I try to combine 2 of these factors on each buy : new design, new steel, loved steel, good geometry, new construction, ...
I can see it too, and it would actually look very nice in addition to be a killer of a workhorse (even in LW fashion)
Deadboxhero
Re: CPM 15v Manix 2
#1346
Post by Deadboxhero »
RustyIron wrote:
Sat Jan 14, 2023 8:21 am
That would be a disaster if steel came in the hardened condition, there is a lot of processing done to convert a bar/sheet to a knife blank.
The steel comes in the annealed condition
The steel manufacturer makes into a billet from raw materials.
The rolling mill processes the billet into different size sheets by hot rolling which also improves the structure, afterwards its annealed which further improves the structure and makes it ready to process and further HT into hardened condition when ready.
Of course, I used to work as a freehand professional sharpener and one thing that was noticed is some knives in the same steels but different manufacturers would sharpen differently.
Isn't that odd?
I remember being smitten at the time by the wonderful sharpening experience of Aogami Super, the shop I worked at specialized in Japanese cutlery and water stones.
Tojiro is a mass production japanese kitchen knife company, at the time they had a special run with san mai aogami super for a low cost.
Meanwhile Bladesmith Fujiwara Teruyasu also had knives in Aogami Super and the difference was breath taking.
Isn't that fascinating?
The NAME of a steel on the side of the blade is not universal
While the properties are pretty fixed to the chemistry there is certainly a range of expression, not to say 420HC and be heat treated to Rex 121 or vice versa.
Can't turn lead into gold.
On the Fujiwara, edge came up so crisp and deburred with great elegance (at the the time from what I had experienced prior.)The Tojiro was more stubborn on the burr and also did not hold the front end sharpness as well.
My mind raced
"How is this possible?" "What is going on?" "How does this work?" "I must KNOW!"
My curiosity of what makes the same steel sharpen better and hold the front end sharpness better became an all consuming obsession, an "idée fixe"
That was many years ago and was certainly one of many moments that set me on a curious quest to get answers to my questions.
Well almost 10 years later I have a pretty solid working understanding of how to create what I'm looking for that isn't simply a matter of HRC, it really comes down to the microstructure making up that given HRC.
Some features that make up the microstructure are more desirable than others, because the apex is so small and cannot be seen by the naked eye microstructure is important.
Big Brown Bear
Triple B Handmade Knives
Sharp24/7
Re: CPM 15v Manix 2
#1347
Post by Sharp24/7 »
Deadboxhero wrote:
Sat Jan 14, 2023 12:29 pm
Isn't that odd?
My mind raced
Dude, that stuff is fascinating. Thanks for sharing the knowledge!
Buddafucco
Re: CPM 15v Manix 2
#1348
Post by Buddafucco »
Color Metallography of CPM 15V
I made this micrograph
this is what the structure of the Spyderco 15V looks like at a microscopic level. The circular "blobs" are significantly harder than the surrounding matrix, they are also responsible for increasing the slicing edge retention.
These "blobs" are called carbides, these ones in particular are all vanadium carbides which are the hardest commonly available in knife steel.
The largest ones range from 3 to 4 microns, that's under half the size of a human red blood cell.
These carbides make up 23% of the steel matrix.
Compared to 17% in 10V and 8% in 4V. This increases resistance resistance to wear at the edge and can increase strength.
The problem with IG Stories is that your amazing knowledge bombs will disappear after 24hrs. I'm glad you posted this in places where that's not the case. And thank you very much for posting it here also!
Is there any significance to the different colors in your micrograph? Or am I over thinking it?
•• Beau
inmyhousechillin
Re: CPM 15v Manix 2
#1349
Post by inmyhousechillin »
Made an account to comment on this...
I am also curious as to the coloring. When holding my manix at an angle in natural light, I noticed a rainbow colored hue.
At first I thought it was the oils causing the reflection. But after cleaning, it still exists.
Could this be the result of the heat treat?
Deadboxhero
Re: CPM 15v Manix 2
#1350
Buddafucco wrote:
Sat Jan 14, 2023 6:47 pm
Not on this one, we can definitely geek out and use different etchants and etching protocols to highlight certain and specific features in the future when I'm less busy changing diapers : p
Big Brown Bear
RustyIron
Re: CPM 15v Manix 2
#1351
Post by RustyIron »
Isn't that odd?
On the surface, it DOES seem odd--until you start to think about it. I clarify things in my mind by making analogies. Heat treating is like baking a loaf of bread. You can give flour, water, and yeast to two different chefs, and the result will be two vastly different loaves of bread. And of those two loaves, there is no right or wrong. Each one can be better suited for a specific purpose. How dull would life be if there was only one kind of bread... or one type of knife steel?
Thanks for clarifying a little about the journey from the roller mill to a chunk of steel with qualities that you intended.
awa54
Re: CPM 15v Manix 2
#1352
Post by awa54 »
Mushroom wrote:
Sun Jan 08, 2023 9:41 pm
I haven’t been following this thread too closely but it seems like as good of a time as any to promote the “Random: General Spydie Chat” thread.” It was made specifically for off topic chatter.
Dang! and here I was thinking that this was the place for OT convos: viewforum.php?f=5
-David
Re: CPM 15v Manix 2
#1353
awa54 wrote:
Sun Jan 15, 2023 12:34 am
LOL! You’re right!
I should have been more specific. That thread was made specifically for general chat about Spyderco that is not necessarily worth making its own thread for and for having casual conversations about Spyderco that might otherwise be steering another thread off the original topic it was made for. Enjoy! :discguised
-Nick :bug-red
dullmaker
Re: CPM 15v Manix 2
#1354
Post by dullmaker »
Anybody else want to see a screw constructed Manix Lightweight in 15v?
Re: CPM 15v Manix 2
#1355
hvarcz wrote:
Fri Jan 13, 2023 2:58 pm
Is this sprint run in Europe?
I cant see him.
Ramonade wrote:
It should arrive at Lamnia soon. Also Knives&Tools and Coutellerie Tourangelle should have some, but they haven't said so yet.
As Ramonade says and you can request a notification at Lamnia for when they have the knife for sale
Another smaller, but good to work with online store that in my experience often has Spyderco sprint runs is com2you-biwak.de.
Don´t know if this will also be the case with the 15V Manix though.
Best if luck to all of you European fellow forumites who´ll try to score one!!
Ricey_9
Re: CPM 15v Manix 2
#1356
Post by Ricey_9 »
https://youtu.be/h6DwlT2NDtU
Haven’t seen this posted anywhere figure i would share.
:bug-red-white
para3 lw spy27
Para 2 dlt cruwear
Para 3 maxamet
Manix 2 rec cts204p
Shaman knife joker cruwear
Lil native knife joy s45vn
Pm2 15v
Native 5 lw Magnacut
Knife joy Manix 2 20cv
Enactive
Re: CPM 15v Manix 2
#1357
Post by Enactive »
Ricey_9 wrote:
Sat Jan 28, 2023 1:43 pm
Thanks, man. I hadn't seen that one yet.
Bemo
Re: CPM 15v Manix 2
#1358
Post by Bemo »
I've watched it a couple times now and don't think there was steel left over for a Native run sadly. Really hoping to be wrong. I'd take a Para3 as an alternative.
TTFulltimer
Re: CPM 15v Manix 2
#1359
Post by TTFulltimer »
dullmaker wrote:
Sun Jan 15, 2023 12:47 pm
Even if Spyderco rivets it, you can make it a screw model in about 15 minutes.
Just a crotchety old curmudgeon who has seen a thing or two
electro-static
Re: CPM 15v Manix 2
#1360
TTFulltimer wrote:
Wed Feb 01, 2023 7:03 pm
I would love to see a manix LW in 15V
