stok drop point
stok drop point
this looks like it could be a really great edc fixed blade. i'm curious about the plunge grind and the really narrow portion where the handle meets the blade, but i'll probably still try it out. i like this blade shape a lot and my experience with spyderco's treatment of 8cr13mov has been really positive in comparison with other 8cr13mov knives. the handle looks quite nice too.
while it's not the most competitive pricing for a chinese made knife in 8cr13mov, it's nice to see some more budget friendly fixed blades from spyderco. i can't wait to try it out.
Re: stok drop point
I too am intrigued. Plunge line is not visually appealing but I am a sucker for sheepsfoot- this looks more that style than drop to me
- Manixguy@1994
Re: stok drop point
It reminds me of a Sheepsfoot also , regardless would like to handle one possibly at a show . It looks like it could be comfortable in hand . Dantwinboysdad wrote: ↑Sat Jan 14, 2023 9:22 amI too am intrigued. Plunge line is not visually appealing but I am a sucker for sheepsfoot- this looks more that style than drop to me
Re: stok drop point
i'm not so concerned with visually appealing on the plunge line. i'm more concerned with the way it leans so far forward. it looks like it would get in the way of cutting.twinboysdad wrote: ↑Sat Jan 14, 2023 9:22 amI too am intrigued. Plunge line is not visually appealing but I am a sucker for sheepsfoot- this looks more that style than drop to me
i like sheepsfoot blades too. this one looks very reminiscent of how bradford does theirs. that's the first thing i thought when i saw it. but i really like the lower tip with a slight belly on these blade shapes. it's similar to the caribbean sheepsfoot where it might as well be a wharncliffe for cutting power at the tip, but still gives enough belly to be more versatile than a regular wharncliffe.
if nothing else, at about the same thickness as the delica, i bet it will be a fun little knife to use for whittling around camp.
- Manifestgtr
Re: stok drop point
I’m actually way into these…I’ve been thinkin about a Spyderco neck knife for a while and these fit the bill perfectly for my purposes
This is one of the most significant reveals for me since I’ve been a Spyderco guy. TONS of stuff that’s right up my alley. 15v shaman and pm2, more k390, millie 2, the list goes on
Crucarta: Shaman (x2), Manix 2, Lil Native, Delica, GB2 & PM2
Favorites: Shaman, Sage 5 lightweight, Sheeps Caribbean, Manix, Endela and all things Stretch
Re: stok drop point
While I am still on the fence about the steel, this is actually very high on my list. Like second, right after the ukpk Magnacut and before the enuff 2 in k390.
Love the blade shape, legal to carry, looks like an excellent allrounder.
Re: stok drop point
Visually I like both blade shapes a lot but in use my preference is the drop point by a wide margin. I also like sheepsfoot blades and agree that this Stok does sort of lean more towards that than a drop point. I use the tip of my knife on a surface often and I find a low knife tip more comfortable in that use. I also really like the shallow belly.
In a way the Stok’s blade also reminds me of the Perrin PPT blade, which is my most favorite knife of all time. It has a low tip with very shallow belly that transitions to nearly wharncliffe flat.
One question, does anyone know how the the name Stok is pronounced, “stoke” or “stock?” It is also the designers last name, so I’m sure there is a correct way to say it.
- Nick
Re: stok drop point
I know Sjoerd personally, it is pronounced the same way as ‘stock’Mushroom wrote: ↑Sat Jan 14, 2023 10:59 amVisually I like both blade shapes a lot but in use my preference is the drop point by a wide margin. I also like sheepsfoot blades and agree that this Stok does sort of lean more towards that than a drop point. I use the tip of my knife on a surface often and I find a low knife tip more comfortable in that use. I also really like the shallow belly.
Re: stok drop point
Thank you!Tommie85 wrote: ↑Sat Jan 14, 2023 11:29 amI know Sjoerd personally, it is pronounced the same way as ‘stock’Mushroom wrote: ↑Sat Jan 14, 2023 10:59 amVisually I like both blade shapes a lot but in use my preference is the drop point by a wide margin. I also like sheepsfoot blades and agree that this Stok does sort of lean more towards that than a drop point. I use the tip of my knife on a surface often and I find a low knife tip more comfortable in that use. I also really like the shallow belly.
- Nick
Re: stok drop point
Ever played with a Pingo? Very reminiscent of that model too, sheepsfoot with bellyladybug93 wrote: ↑Sat Jan 14, 2023 9:47 ami'm not so concerned with visually appealing on the plunge line. i'm more concerned with the way it leans so far forward. it looks like it would get in the way of cutting.twinboysdad wrote: ↑Sat Jan 14, 2023 9:22 amI too am intrigued. Plunge line is not visually appealing but I am a sucker for sheepsfoot- this looks more that style than drop to me
Re: stok drop point
i never got a chance at one. they do look cool though.
Re: stok drop point
I will be picking both of these up. Very intriguing designs. My Byrd knives have convinced me that Spyderco's higher heat treat of the steel makes a really big difference. Anyone else see some influence from the Grohmann fixed blades?
Re: stok drop point
You know what, now that you mention it, it does look like a modern take on the classic Canadian belt knife pattern.
Re: stok drop point
Sheepsfoot, Wharncliffe, and Lambsfoot profiles all have their place in my carry options.twinboysdad wrote: ↑Sat Jan 14, 2023 9:22 amI too am intrigued. Plunge line is not visually appealing but I am a sucker for sheepsfoot- this looks more that style than drop to me
I'd be all over a Spyderco Lambsfoot option in the Dragonfly size!
Re: stok drop point
It's a definite maybe for me. I don't usually like choils on fixed blades.
It is an interesting design, but looks maybe too narrow/ shallow at the choil.
I agree that Spyderco 8Cr is pretty darn good.
Re: stok drop point
Yea, the plunge line is the thing keeping me from trying one. I like the overall profile except for the plunge line to keep the Spyder-hole thickness the same as the spine. This general profile looks very camping friendly along with dual use in kitchen prep.ladybug93 wrote: ↑Sat Jan 14, 2023 9:19 am
Re: stok drop point
Definitely one of my favorite blade shapes.
Re: stok drop point
Super interested! Love the blade shape. Definitely see some Pingo vibes. Maybe looks like a fixed blade Roadie as well?? For the record, I have never handled either, just going off of pictures. Can't wait to get a Stok in hand!
Re: stok drop point
Actually one problem with that plunge grind is that it will potentially interfere with sharpening using a guided clamp system. Though Sharpmaker and freehand sharpening system users won't encounter this headache.
Re: stok drop point
I wasn’t impressed initially, even though I’m always happy to see Spyderco fixed blades, but I gave it some thought and ended up finding some good potential uses where the size, shape, and style of these Stok fixed blades will make sense to me.
Could probably work as boot knives, for example, but also as small beater knives that have some decent aesthetics. Might even be fun to throw them, idk.
I was recently thinking of the possibility of budget Spyderco fixed blades too. Overall a nice surprise.
