Community Sharpening Journal
WilliamMunny
Re: Community Sharpening Journal
#1561
Post by WilliamMunny »
R100 wrote:
Mon Oct 24, 2022 2:36 pm
I mainly use DMT diamond bench stones. Whether or not I need them for S110V, S90V, K390 and ZDP-189 they sure do make it easy.
Dan
How are they? I have been looking at their 3 stone kit for awhile now, seems like a lot of product for $100.
Endura AUS-8, Manix 2 S30V, Alcyone BD1N, PM2 Micarta Cruwear, Native 5 Maxamet (2nd), Para 3 Maxamet (2nd), Magnacut Mule, Z-Wear Mule, BBB 15V Manix 2, REC PM3 10V Satin, Dragonfly Salt 2, GB2 M4.
#1562
id avoid those and go with continuous. they work faster than the ones with holes.
:unicorn
#1563
everyone here needs to try one of these. 1mm stock, extremely thin bte, steel takes a razor edge effortlessly. folks out there cutting up food with your 3-4mm thick folders, you're missing out.
I've got a few of these scattered around the house and my restaurant. This one I did a few strokes on the diamond rods at 15 degrees, then medium then fine at 20 degrees. The steel is kind of soft so I use 20 instead of 15 with this brand to help avoid having the edge roll.
Crazy high performance for $5. Really shows off how much geometry matters.
:unicorn
#1564
I bet that's a lot of fun to work with, that's silly thin.
WilliamMunny
#1565
I feel like you could turn that knife over and still cut things with the back.
R100
#1566
Post by R100 »
WilliamMunny wrote:
Mon Oct 24, 2022 4:28 pm
Dan
I think it's easier with bigger stones. I have two DMT duosharp 8" - an extra coarse/coarse and a fine/extra fine. They have seen a lot of use but still cut quite well. If I was buying again I would just get one coarse/fine 8" duo sharp. When I get a new knife I generally start by reprofiling to about 15 dps. The coarse is good for this and I think you only really need a coarser grit for major reprofiling or regrinding. It is not hard to get a shaving edge off the coarse which I then refine with a few passes on a leather strop with 1 micron diamond paste. The trouble with this is that I am an obsessive sharpener and end up removing too much steel. Lately I have been sharpening with the fine DMT which leaves a bit of tooth and then maintaining the edge with the strop until it the real hair popping edge stops coming back. Then I hit it with the DMT fine again and the edge is usually back in under a minute.
Having said all this I have become keen to try a bonded diamond stone and have been looking at a Venev Phoenix 400/800 grit as an affordable starting point. I do like to use different edges on different steels and I think the advantage of the bonded stone for me would be less danger of damaging the edge as I reach the apex with coarse grits. I have had some problems with this with high carbide steels like S110V and have learned to be very gentle at the apex but the bonded stones would probably be better. I am only a journeyman sharpener.
Dan
#1567
I enjoy that Duosharp stone as well. Typically go freehand on that when removing a lot of steel, then set it up on the Precision Adjust to refine it a bit if I feel the need. Nice combo for not that much money.
WilliamMunny
#1568
Anyone use the Atoma diamond stones? The posted video said they were pretty good and were used to flatten Whetstones. Figure if you had a nice big surface to set an edge and to flatten whetstones it’s a win win.
#1569
I've heard nothing but good things about them and would have 100% confidence buying any of their stones. They're very popular with folks into high end kitchen knives for flattening water stones and setting bevels.
chefknivestogo also carries some very affordable diamond flattening stones if you're interested in a cheaper alternative.
:unicorn
Librarian
#1570
Post by Librarian »
WilliamMunny wrote:
Tue Oct 25, 2022 5:06 am
This is not a good idea. This will cause premature wear of the diamond insert. Either level stones or sharpen knives.
It is better to use either very cheap diamond plates for this, or to level the surface of the stone on glass with silicon carbide powders.
Soft water stones such as king can be leveled on their own slurry which will exude from the stone.
You can renew the surface of the stone during work simply with a piece of ceramics, for example.
WilliamMunny
#1571
Librarian wrote:
Tue Oct 25, 2022 7:30 am
Can you level a King water stones with glass and wet/dry sandpaper? I use that when I am doing furniture building, but obviously to flatten small pieces of wood.
Librarian
#1572
Post by Librarian »
WilliamMunny wrote:
Tue Oct 25, 2022 7:36 am
If you are so comfortable, then why not?
I just don't think this stone needs sandpaper, it's a soft stone and an abrasive that comes off the stone easily can be used to smooth the stone.
harpo1
#1573
Post by harpo1 »
Mon Oct 24, 2022 4:59 pm
Do you do the diamond and medium at 15 and the fine at 20?
--Pete
#1574
Nope, set the edge at 15 withh diamonds, then refine at 20 with the ceramics. The whole process only took about five minutes. polishing full bevels is a waste of time IMO, only the apex needs polished for good push cutting.
:unicorn
harpo1
#1575
Post by harpo1 »
Tue Oct 25, 2022 8:12 pm
Perfect, Thanks!
--Pete
AH80s
#1576
Post by AH80s »
I have a serrated Police (VG10) coming. I'm probably going to get a sharpmaker to upkeep it. Should I get diamond or CBN rods to go with it? Does one last longer than the other? It's too costly to get both here.
My current other Spyderco's have K390, M4, S30V. Thanks.
Andrew
#1577
Don't need diamonds / cbn to maintain SE, only to reprofile or repair chips. Stock sharpmaker is all you need to maintain serrated edges.
:unicorn
JRinFL
#1578
Post by JRinFL »
VG10 is fine to sharpen without diamonds or CBN.
AH80s
#1579
Post by AH80s »
Wed Oct 26, 2022 9:05 am
JRinFL wrote:VG10 is fine to sharpen without diamonds or CBN.
Thank you.
Andrew
Steeltoez83
#1580
Post by Steeltoez83 »
Just a quick edge I put on my rex45 pm2. I dulled the edge mostly cutting up some old carpet. Put a 400 grit edge with my sharp pebble silicon carbide stone. The edge is cutting papertowel quite effortlessly right now. Rex45 is probably my favorite steel of all time. Just a real joy to sharpen.
