CPM 15v Manix 2
Josh Crutchley
Re: CPM 15v Manix 2
#361
Post by Josh Crutchley »
Librarian wrote:
Thu Oct 13, 2022 2:03 pm
I would like to answer at the same time.
Do not forget what you pay for it. bonded stone are much more expensive than galvanic stones. The resource of the plate with galvanic coating is very large, when they stop working, you can just buy a new one. Analogy: Imagine that 5 (figure from the head, you need to watch prices, approximately) of galvanic stones cost like one bonded stone.
It's a matter of taste.
You can only say that this one cannot be called a plus or minus.
For example, naniwa superstone are sold with a thickness of 10 mm and 20 mm. If I need a stone of 8000 grit, a stone with a 10 mm thick will be enough for me not only for me, but also to my grandchildren. Why do I need a 20 mm stone?
How often do you change the plates of diamonds on the galvanic plates? I think they are not too often.
Again, this is an economic factor.
Bonded stones are not expensive when compared to quality diamond plates. For the size of stone I use DMT plates are 10usd cheaper. So for 10 bucks more I get a stone that lasts longer. Atoma plates are almost twice as much.
Every diamond plate I've used has lost effectiveness after a few months. Once that happens there's no way to make it cut like new. Bonded stones go through the same process but you can dress them to make them cut like new. You can dress a bonded stone multiple times which increases their value.
In the end if your happy with the effectiveness of SiC and diamond plates that's all that matters. We're all here to enjoy knives and sometimes have to agree to disagree.
BIGSTRETCH
Re: CPM 15v Manix 2
#362
Post by BIGSTRETCH »
I’ve googled to the best of my abilities and am unable to figure out where any of you are getting diamond or cbn plates of any type (bonded, vitrified, sprayed on or whatever) at grits 2k and above. Feel free to PM me if this is too off topic. I’ve been out of knife and stone shopping for a few years now and this stuff was just starting to show up back then. Thanks!
dlum1
Re: CPM 15v Manix 2
#363
Post by dlum1 »
Ah, nice catch on the aluminum oxide vs silicon carbide. However, given that sharpening is abrasive action of one material wearing on another, I would argue here that hardness is still king. If we find the average hardness -- by summing the carbide volumes weighted by their hardness and the steel matrix (again weighted by its hardness) and divide by the total volume, we'll find the average hardness is less than either aluminum oxide or silicon carbide -- which I believe is why we can use it for sharpening. I'd be interested to see at what point the carbide volume pushes the average hardness over the limit. --> A quick back-of the envelope calculation yields 87% vanadium carbide volume is needed for the average hardness of each material (vanadium carbide in a soft steel vs silicon carbide) is equal. This has been fun.
Josh Crutchley
Re: CPM 15v Manix 2
#364
BIGSTRETCH wrote:
Thu Oct 13, 2022 3:44 pm
Dmt makes an extra extra fine 3 micron plate. I have one but the plating is flaking off.
https://agrussell.com/knife/DMT-Extra-E ... --DMT-A4EE
https://www.sharpeningsupplies.com/DMT- ... -P125.aspx
This is where I get bonded stones.
https://cgsw.us/shop/
Ramonade
Re: CPM 15v Manix 2
#365
Post by Ramonade »
Resin bonded diamond stones and electroplated stones do not only differ in lifespan. As Shawn said, since the diamond are IN the bonding medium, they are not showing all the way. The grit stays the same, they cut as efficiently as electroplated stones for the same grit.
However, there's a difference in how deep the electroplated diamonds go in the steel, and this is the case for every grit. When your using 220 grit it's not that important, but at very high grits and given the choice, you'd prefer a resin bonded diamond stone for a cleaner edge (= sharper)
Librarian
Re: CPM 15v Manix 2
#366
Post by Librarian »
First I would like to quote words from this article (I recommend reading it all)
https://scienceofsharp.com/2016/12/21/a ... t-vs-grit/
In the study and literature on the topic of grinding and wear (tribology) the terms “sliding, ploughing and cutting” are commonly used. There is a critical pressure required for an abrasive to cut into the workpiece, otherwise it will simply slide without removing metal. Efficient grinding occurs when the particles are cutting. If the exposed abrasive becomes worn, the contact area increases and the effective pressure decreases (for a given applied force) and we will move from cutting to sliding.
dlum1 wrote:
Thu Oct 13, 2022 2:45 pm
Something doesn't sound right here. You're forgetting pressure. With it, a round object can definitely cut. Press a metal ball bearing against a sheet of drywall and drag it. It can definitely leave a gouge mark. With such a small surface area near the edge of a blade, a light force can result in some significant pressure.
I tried to do this and I did not succeed. A small metal ball simply slows down from my hands when I begin to move it along the sheet. ;)
Newton's third law - To every action there is always opposed an equal reaction
In your example, you missed that the ball is not fixed motionless. Your example would work if the ball had a comfortable handle to hold, so that you could create a pressure on the ball, to move along the sheet.
The grain of abrasive in the stone is not fixed motionless, it is kept due to "glue". Glue can be strong(norton india) and weak(king stone). There will be some kind of pressure on the abrasive when the abrasive will break out of the stone. The more round abrasive (dumb), the more it must be pressed on the stone, so that he again begins to cut the metal. This pressure can be so large that the whole stone will destroy, or it will not work to do anything.
Josh Crutchley wrote:
Thu Oct 13, 2022 3:36 pm
I would not want to greatly discuss the issue of price, otherwise I will have to consider a large assortment.The price depends on the concentration of an abrasive, for example, Venev diamonds (25% vs 100%). Some can be just expensive, like Naniwa Diamond.
When you are talking about reusable, it is difficult.
Problems in details and trifles.
For example, the density of abrasive per unit area is important. For example, we have 1 cubic millimeter of diamonds, we can pour them onto the plate, or can knead with a filler and get 1 millimeter of diamonds with a filler. Is it correct to compare and say that one is better than the other and more durable?
Diamond plates lose their aggression after small use. But we can say that this is their nature and a feature. They become a little aggressive, but they still work very well. Supported that they go to the operating mode.
You need a stone for some kind of work, and not for it to be like new.
Ultimately, the speed of the stone is important to us. The volume of the metal that is removed in one movement at a given pressure on the square. I'm talking about the experiment, the link to which I gave at the beginning of my message.
If we had these values, we could easily compare abrasives, but we don’t have them.
Ramonade wrote: Resin bonded diamond stones and electroplated stones do not only differ in lifespan. As Shawn said, since the diamond are IN the bonding medium, they are not showing all the way. The grit stays the same, they cut as efficiently as electroplated stones for the same grit.
This is a very very controversial statement.
I drew a small picture, this is a type of abrasive stone, depending on the depth of immersion of an abrasive into the matrix.
For comparison, I suggested that the density on the surface of the abrasive is the same in all stones
I do not know what you mean by the word - effectiveness. But the following logic (The grit stays the same, cut as efficiently same, difference in how deep), the best stone will be the one whose abrasive will be deepened to maximum depth (Perhaps even the one from which the abrasive will not stick out? :thinking ). Since the effectiveness does not depend on the depth of the adjustment. And the scratches from abrasive will be less, the more abrasive is immersed in the matrix.
Do not you think that what is wrong here?
If I misunderstood you, please draw you as you imagine these two cases.
JRinFL
Re: CPM 15v Manix 2
#367
Post by JRinFL »
You know, all of the last many posts belong in the sharpening thread (or a new thread) and not here in the CPM 15v Manix 2 thread. Please keep on subject, thanks.
WilliamMunny
Re: CPM 15v Manix 2
#368
Post by WilliamMunny »
Librarian wrote:
Fri Oct 14, 2022 4:13 am
Nice explanation.
Re: CPM 15v Manix 2
#369
JRinFL wrote:
Fri Oct 14, 2022 7:10 am
I was just thinking the same thing. It is very interesting and deserving of a separate thread. Just not the 15V Manix Sprint thread.
Re: CPM 15v Manix 2
#370
I was hoping this thread would be an alert kind of thread. It's gone quite scientific! I'm knife nerdy...just not this nerdy :nerd
Re: CPM 15v Manix 2
#371
Great information, have to agree a thread dealing with sharpening specifics would be ideal . MG2
legOFwhat?
Re: CPM 15v Manix 2
#372
Post by legOFwhat? »
How good would this look all blacked out?
-Larry
MNOSD #0049
WilliamMunny
Re: CPM 15v Manix 2
#373
legOFwhat? wrote:
Fri Oct 14, 2022 8:31 am
Not a huge fan of blade DLC but black hardware and liners would be great. Even though I am not a huge fan of DLC, having it on a corrosion prone blade wouldn’t be a bad thing.
Re: CPM 15v Manix 2
#374
WilliamMunny wrote:
Fri Oct 14, 2022 8:49 am
I typically prefer satin blades, but I agree, black hardware especially the liners would look great and add some corrsion resistance to the liners where I have actually had corrosion in the past. Right where all the skelonitization is.
Would be cool to try out blacked out hardware and satin blade for future sprints.
Re: CPM 15v Manix 2
#375
Ehhh, my OCD gets all whacky when there's 3 different colors going on. Gotta stick with two. All satin blade and hardware or all coated.
William, I thought you've said you've never tried DLC? Can't knock it til ya try it!
Also a side note to remember, this blade is actually stonewashed and not satin.
WilliamMunny
Re: CPM 15v Manix 2
#376
Fri Oct 14, 2022 9:23 am
I do need to take the jump into DLC. I still have the bad taste in my mouth from 20-30 years ago and those old painted blades. I was going to get the REC 10V Manix in DLC but with this one I probably won’t now.
Re: CPM 15v Manix 2
#377
Spyderco DLC is nothing like those painted blades, not even from the same planet.
Re: CPM 15v Manix 2
#378
I was hoping there would be a black and stone wash but will go with the flow . MG2
Re: CPM 15v Manix 2
#379
Some great conversation going on here. I'm proud to be part of the group.
FYI, Spyderco is making a CBN 2 sided stone.
Re: CPM 15v Manix 2
#380
Has this manix been shipped out yet?
