Swick 5 ETA?
Re: Swick 5 ETA?
#261
I feel like the wait between announcement and the first of these hitting dealers was easier than the wait from release to the swick 5 pe coming out, lol.
Spyder & I
Re: Swick 5 ETA?
#262
Post by Spyder & I »
I'd like to briefly summarize my experience with carrying the Swick 6 se for the past three days
Pros: punctures and slices with ease, lightweight and ergonomic, easy to deploy fast and re-sheath securely with one hand
Cons: raises my temperature every time I use it
Thank you
nerdlock
Re: Swick 5 ETA?
#263
Post by nerdlock »
Swick 6 PE and SE both in stock at River's Edge Cutlery:
https://riversedgecutlery.com/search-re ... cehgEVwnJg
Theldraskien
Re: Swick 5 ETA?
#264
Post by Theldraskien »
I have a SE on the way. Now regretting not also getting PE. May end up with both.
Re: Swick 5 ETA?
#265
Hi Spyder & I,
Welcome to our forum.
Spyder & I
Re: Swick 5 ETA?
#266
sal wrote:
Tue Oct 18, 2022 9:12 am
Hi Spyder & I,
Cheers from Montreal, Sal
Spyder & I
Re: Swick 5 ETA?
#267
Additional pinky support
SaintZvlkx
Re: Swick 5 ETA?
#268
Post by SaintZvlkx »
I caved and picked up a Swick 6 as I've been waiting for the 5 ever since its announcement & pestered Sal pre-LC200N about an 8cr or similar budget version for pruning tomatoes and other acidic plants. Perrin's desire for retention from his roofing work translates well to pruning and other agricultural jobs albeit for a very different reason- I'm rarely in danger of dropping the knife onto passersby- but due to the nature of the job I often need the use of both hands between each instance of pruning & need to render the pruning knife safe each time I relocate. Folders need to be easily opened and closed with simple hand movements that can be safely performed out of my line of site & without having to shift grips (ruling out backlocks and compression locks) so by far the best folder I've found for the job has been the beautifully designed UKPK which is both easy to operate one-handed & cannot be accidentally closed due to the choil. Fixed blades that require a sheath are huge liability as this can mean drawing and sheathing hundreds of times over the course of a few hours which is a recipe for disaster if you're not paying attention every single time.
In other words I've really been looking forward to the new Swicks- and my initial impressions of the knife are good. I'll be swapping for a 5 the moment they become available as the larger hole is more convenient for my size hands but that one's on me. The sheath I'm less happy about- I purchased a serrated version and the swick consistently removes material from the inside of the sheath on the draw. Comparing the 4 and 6 side-by-side I can see why the new sheath was and is a huge issue in both design and implementation- the the tip of the wharncliffe blade is parallel to the start of the handle which means anything but a perfectly straight, 90 degree draw- which is difficult to perform as the main retention point is the rounded spine- causes the tip to tilt up & the blade to draw at an angle, favoring the bottom of the sheath as the spine of the handle is forced lower due to the retention point. We'll see how the sheath wears in.
Re: Swick 5 ETA?
#269
bump. swick 5 pe still coming???
Spyder & I
Re: Swick 5 ETA?
#270
SaintZvlkx wrote:
Sat Dec 10, 2022 12:16 pm
Ditto on boltaron shavings when drawing the blade, especially at first. After a few hundred sheathings the fit seems to have settled, though I still get bits on rare occasion. Clicking it back in firmly with a slight twist gives best retention, and it appears to be impossible to shake it out.
Re: Swick 5 ETA?
#271
bump
Re: Swick 5 ETA?
#272
bump.
Re: Swick 5 ETA?
#273
Fri Dec 16, 2022 9:25 am
bump.
:crying-face
i like your focus though.
RamZar
Re: Swick 5 ETA?
#274
Post by RamZar »
Is Spyderco redesigning the sheath for Swick 5? Swick 6 seems fine.
Re: Swick 5 ETA?
#275
bump.
SaintZvlkx
Re: Swick 5 ETA?
#276
Spyder & I wrote:
Tue Dec 13, 2022 6:07 pm
Yeah pretty important to mention that shavings aside the sheath is functional as a means of protecting myself from the blade. Retention on mine is very good, and ditto on the shavings slowing down thus far.
Re: Swick 5 ETA?
#277
bump
aicolainen
Re: Swick 5 ETA?
#278
Post by aicolainen »
I think I know what vivi wants for Christmas…
RamZar
Re: Swick 5 ETA?
#279
Post by RamZar »
In stock Christmas 2023… Maybe…
Re: Swick 5 ETA?
#280
someone must've heard this is the last spyderco vivi wants so they won't release it.
