Triple B/Spyderco Folder
- WilliamMunny
Re: Triple B/Spyderco Folder
Think I finally found an image of it. Not sure what type of lock it uses though…
-Matt a.k.a. Lo_Que, loadedquestions135 I ❤ Hawkbills
I swore I wouldn’t buy another knife until this one is released.
I’ve only bought 4 spydies so… close enough.
Michael Janich
Dear Irken1er:
Stay safe,
Mike
Stay safe,
Mike
LIES!WilliamMunny wrote: ↑Sun Aug 21, 2022 7:31 pmThink I finally found an image of it. Not sure what type of lock it uses though…
I was promised 15 Vs. I only see 5 there...
There's probably already a name for this model, but in light of recent events, I think it should be renamed the Trevor.
I like BBB Trapper for the name
Mule Team Army 001 (patched)
MNOSD 008
Stable Mules; Z-Max, Z-Wear, Magna Cut, Magna Max, SRS13, Rex 76, Rex T15.
MNOSD 008
Stable Mules; Z-Max, Z-Wear, Magna Cut, Magna Max, SRS13, Rex 76, Rex T15.Re: Triple B/Spyderco Folder
Thank you Mike!Michael Janich wrote: ↑Mon Sep 26, 2022 6:49 amDear Irken1er:
Stay safe,
Mike
- kennethsime
I'm hoping that the BBB/Spyderco folder is a new model.
The announcement of a 15V Manix with a Shawn Houston heat treat has me worried that there will be no new model.
Can anyone confirm or deny?
weeping minora
It has been discussed on page 7 of this thread that the BBB collaboration folder was a liner lock, which the Manix 2 certainly is not:
Perhaps this is a teaser and hint that the BBB collab will indeed be 15V and is a taste for ELU usage so Spyderco/Shawn can get feedback before they pull the trigger and release their knife to a lukewarm market, if 15V in this Manix is sourly received.
Patience seems beyond virtue amongst the lot these days.
Edit to add quotes for reference.
Make Knife Grinds Thin Again.
kennethsime wrote: ↑Tue Sep 27, 2022 11:49 pmI'm hoping that the BBB/Spyderco folder is a new model.
I would think only he or Spyderco could.
I will probably get that Manix 2 just to try out the steel, but I'm hopeful that it at least makes it's way into other models, if not a full on new collaboration model.
Maybe the knife from Shawn Houston should be called “Problem” and when someone asks “Do you have a problem” you say, “Yes, it’s quite lovely and sharp”
MNOSD 008
MNOSD 008
Stable Mules; Z-Max, Z-Wear, Magna Cut, Magna Max, SRS13, Rex 76, Rex T15.- legOFwhat?
-Larry
MNOSD #0049
MNOSD #0049
The 15V Manix 2 is only a heat treat collaboration, not a design collaboration.Evil D wrote: ↑Wed Sep 28, 2022 1:59 amkennethsime wrote: ↑Tue Sep 27, 2022 11:49 pmI'm hoping that the BBB/Spyderco folder is a new model.
This 15V Manix 2 is not the BBB design collab we’ve been hearing about. Spyderco is still producing an actual design collaboration with Shawn Houston as well. It will also use 15V steel and his proprietary heat treat method.
This isn’t some top secret mystery. They’ve literally displayed the BBB collaboration model in their prototype case at trade shows. It’s just in a long production queue because it’s slated for production in Golden.
aicolainen
Nah, depending on its size it should be named Papa/Big-, Mama- or Baby Brown Bear.
Beyond being objectively good names, it immediately opens the door to a small family of great cutting tools
In that scenario… BBB could be, Big Brown Bear or Baby Brown Bear and the “Brown Bear” as the regular model? I like the goldilocks theme, momma, poppa and baby.aicolainen wrote: ↑Wed Sep 28, 2022 8:14 amNah, depending on its size it should be named Papa/Big-, Mama- or Baby Brown Bear.
MNOSD 008
MNOSD 008
It must be only one or two reveals away. I am also not planning to buy anything until this drops sometime next year.
- kennethsime
Thanks Mushroom, I guess I did read at some point about it being displayed at Blade.Mushroom wrote: ↑Wed Sep 28, 2022 7:22 amThe 15V Manix 2 is only a heat treat collaboration, not a design collaboration.
Sorry folks, guess I just lost track!
Anyone have a pic of said prototype they would like to share ?
