2022 P.I.T.S Sprint!
wrdwrght
Re: 2022 P.I.T.S Sprint!
#121
Post by wrdwrght »
Buddafucco wrote:
Thu Jul 14, 2022 12:23 pm
Rivers Edge Cutlery... https://riversedgecutlery.com/products/ ... ts-ti.html
Thanks. Just ordered one.
Buddafucco
#122
Post by Buddafucco »
•• Beau
attila
#123
Post by attila »
I dislike the wire clips flexing and rubbing my titanium finishes, so I put stiffer clips on my P.I.T.S.s. The RGT clip has been hanging out on the old version, but matches the stonewash handle, so I fit it to the sprint. I’ll probably get another grossly expensive RGT for the blue P.I.T.S. later this year since the Lynch is also a bit bendy.
The only slight bummer about the sprint is that the edge grind ran slightly into the ricasso.
Want: SPY27, K490, Swick 5
Coastal
#124
Post by Coastal »
First: this is a wonderful knife!
But now that I've handled it, I really wonder what the nubbin is for. :thinking
#125
Coastal wrote:
Thu Jul 14, 2022 3:57 pm
looks like a finger guard.
#126
attila wrote:
Thu Jul 14, 2022 2:34 pm
That RGT clip looks like it was meant to be on the sprint run. You made the right choice!
Coastal
#127
Post by Coastal »
Thu Jul 14, 2022 3:59 pm
I know, and it's possible for me to get my finger up onto it, but not with a normal grip. Probably for people with larger hands than mine. My particular specimen may get modded so that the nub doesn't stick out of the handle when closed. Much to early for that decision, though.
#128
Mushroom wrote:
Thu Jul 14, 2022 4:04 pm
agreed
Coastal
#129
Post by Coastal »
Thu Jul 14, 2022 4:36 pm
agreed
I agree too. I'm trying to decide whether to get that clip. It looks great, but I believe it changes the knife from deep-carry to a carry closer to a typical Spydie clip. Someone correct me if I'm wrong. All that said, sometimes a less-deep carry is preferable, and sometimes a clip looks so good it doesn't matter. I'm going to carry mine for awhile with the OEM clip, and see how I like it.
JRinFL
#130
Post by JRinFL »
The nub does work as a finger guard for me and I don’t think I have overly large hands.
Coastal
#131
Post by Coastal »
JRinFL wrote:
Thu Jul 14, 2022 6:11 pm
I probably mis-worded my observation. The finger guard works okay for me, I just don't feel I need it because the handle itself works so well. When I grab the knife in a grip I would actually use, my hand doesn't touch the nub at all. I feel the same about the Mule's guard. The handles are so good (for me) that the guard seems unnecessary.
This conversation made me check my knife drawer, and I discovered I have very few knives with finger guards or nubs. If I were using the knife harder than I usually use knives, or stabbing with it, I would probably find a finger guard valuable.
attila
#132
Post by attila »
Coastal wrote:
Thu Jul 14, 2022 6:07 pm
agreed
With regard to deep vs not deep carry, I like it sometimes, but I REALLY like having a stiff and sleek clip on my nice Ti P.I.T.S.
Now, a thing that needs to be mentioned:
I had to file the RGT clip to fit the blue P.I.T.S. and then file it again to fit the new P.I.T.S.
The the gap between the surfaces that fit into the wire clip slots is not wide enough. I had to file inside surfaces of the keys to 0.061-0.62” wide to fit into the clip slots, but it was still a little snug. I’ll provide a photo pointing to one of the two surfaces that needed filing in MY case.
I would think that there’s very little variation in either the P.I.T.S. or RGT clip dimensions, but I don’t recall others describing having to modify the clips to fit. I don’t know if this is a common issue or unique to my limited sample size.
Hopefully, this helps.
Coastal
#133
Post by Coastal »
Thanks for the tip. I sure don’t mind filing to fit, if I get this clip. Their website acknowledges that the clips may not fit the P.I.T.S.
#134
Coastal wrote:
Thu Jul 14, 2022 4:07 pm
I consider the nub to be "finger insurance". It is especially useful here, because the blade does not have a half-stop. Without the nub you could inflict a nasty cut when you disengage the "lock" if you don't pay attention.
Molle Ninja
#135
Post by Molle Ninja »
Excited to receive mine today.
Freediver
#136
Post by Freediver »
Buddafucco
#137
•• Beau
JRinFL
#138
Post by JRinFL »
I hope some of our friends in the UK & Europe are able to get some of these.
ChrisinHove
#139
Post by ChrisinHove »
Are GoingGear reliable? PM if a public reply is inappropriate!
Thanks in advance!!
Matus
#140
Post by Matus »
Buddafucco wrote:
Fri Jul 15, 2022 10:07 am
National Knives... https://www.nationalknives.com/spyderco ... um-handle/
Lamnia and AltonaerSilberWerkstatt will be offering the PITS and honesty I expect that KnivesAndTools will have some too. This model is legal in Germany so I expect interest in spite of the rather high price. But I am also expecting the stock to be very limited
