Build your own dream Spyderco
brancron
Post by brancron »
Rules:
1. It has to be based on an existing model, current or historical. Anything from the C01 Worker onwards.
2. You can designate the materials, including blade steels and handle materials/inlays.
3. You can designate the grind type and serrations (if any).
4. You can choose the clip type and position.
I’ll go first: My dream knife given these parameters would be a C25 Frank Centofante (first gen) in Magnacut steel, a titanium body with Westinghouse micarta inlays, plain edge (full flat ground), a wire clip, tip-up right hand carry.
apollo
Re: Build your own dream Spyderco
Post by apollo »
This is fun.
In my dreams i want a c95 Original manix lockback made in golden.
With the full steel liners so it makes the Manix the bomb proof knife it should be.
It would have a cpm-s90v plain edge blade , The dark forrest green g10 handle like the pm2 s45vn sprint run. A stonewashed hourglass clip.
And a pivot screw like the original Rubicon but the ring around the screw should be bigger and made of CF. And just for fun it would come in the leather pouch with our forum names on the pouch :zany
standy99
Post by standy99 »
Pretty much a GB1 in Magnacut……..Done
Urkilnmesmalls
Post by Urkilnmesmalls »
My dream would be a stonewashed magnacut kapara with forest green micarta. I think that’s what it would take to displace my regular kapara with the RGT python micarta scales I put on it.
Urkilnmesmalls wrote:
Tue May 17, 2022 4:27 am
Add a linerlock and you may have just made my dream spydie.
standy99 wrote:
Tue May 17, 2022 2:34 am
All above only left hand liner lock . ;) Dan
Post by The Deacon »
C83 Schempp Persian, bolstered like the original, with a full flat ground plain edged Odin's Eye Damasteel blade with a 14mm Spyderhole, a matching Odin's Eye lockbar with no Boye dent, mammoth ivory scales with mosaic pins, and no provision for a pocket clip.
Alternately, a straight spined Stretch the size of the original SS/Kraton Stretch, with a bolstered handle like the prototype I have, and all other specs the same as above.
stonewashed magnacut manix with skeletonized liners and textured green micarta handles and copper or brass ball cage
ticn ladybug hawkbill salt in se h1 with red/black zome handle (the ladybug ladybug)
This blade change on an Autonomy 1, in MagnaCut (assuming it plays nice with SE, if not then LC200N or H1), non DLC, and I think I'd like some peel ply carbon fiber on the handle. I also think I'd like it changed over to a standard hourglass clip, I haven't really had any issues with the wire clip keeping it in my pocket but for a knife of this weight I'd just feel better with an hourglass clip, and let's make it raw titanium and non deep carry (makes it easier to get out of my pocket with work gloves on).
The more I use the Autonomy, and the more other models I compare it to, the more I think it may just be The One for me, I'd just like a bit more versatile blade shape in the Autonomy 1 handle.
Evil D wrote:
Tue May 17, 2022 5:44 am
Home run Evil D . !
prndltech
Post by prndltech »
Tue May 17, 2022 5:19 am
:exploding-head
So much logic here… Surely this is already in the works?
- Shannon
MNOSD 0006
Hopweaver
Post by Hopweaver »
"I have a dream that one day every valley shall be exalted, and every hill and mountain shall be made low, the rough places will be made plain, and the crooked places will be made straight; and the glory of my *Dream Spyderco* shall be revealed and all flesh shall see it together."
My dream Spyderco is a larger and manual version of the Embassy.
Something about the blade shape of the Embassy that calls to me. Plus I've found the Embassy to be the best knife I own to open and tear down boxes. Now we just need a manual opening version that I affectionately call The Ambassador!
:bug-red Make time for the important things in life, and learn to enjoy the little things more. :bug-red
prndltech wrote:
Tue May 17, 2022 5:57 am
:exploding-head
I’m sure it is, DLT has been inevitably heading in that direction. I just hope it’s a regular Ladybug blade shape and not a hawkbill.
To that point, I’d love to see some “mushroom” Zome FRN handles! Red scales with white dots, model doesn’t matter. ;)
-Nick :bug-red
Urkilnmesmalls
JSumm wrote:
Tue May 17, 2022 4:32 am
I wouldn’t turn it down with a liner lock but I am really partial to the compression lock. Especially since I put micarta on it. It was a little slippery with the carbon fiber.
twinboysdad
Post by twinboysdad »
Up coming Lil Yojimbo, FFG Cruwear and Back lock
Original Green Lil Temp leaf and Rhino. Better pocket clip like a PM2, would prefer a back lock as well. Keep it green
:exploding-head
it's been brought up a few times. not to derail... here's a topic i made if you want to comment on it more.
viewtopic.php?f=2&t=90271
Easy.
Chief Salt.
:unicorn
Spicy Suplex
Post by Spicy Suplex »
Pretty easy! Para 3 LT Salt. Gimme yellow FRN and DLC to offset, throw any salt steel in there, give it teeth. Done.
ZrowsN1s
Post by ZrowsN1s »
Plain Edge Hawkbill Dragonfly
Teal G-10
K390
DLC Blade and Hardware
Chisel Edge
I want the chisel edge so I can keep an acute edge angle with the Sharpmaker. It's hard to sharpen small hawkbills on other systems, and I like K390 around 12DPS.
Tue May 17, 2022 6:57 am
Yeah, I need to one day pull the trigger on Micarta for mine. I think that would help a lot. The linerlock would help with the current beautiful but slippery scales.
