Just cuts
spydergoat
Re: Just cuts
Post by spydergoat »
Mon Mar 21, 2022 3:30 pm
I guess this is my favorite knife now. The pivot has smoothed out a bit, but still a little more play than the H1 version. Edge holding has improved a ton with a coarse edge vs polished. Used it for a mid hike snack.
Vivi- how did you reshape the spine for this? I would love to try a Pac Salt with more acute tip.
Re: Just cuts
spydergoat wrote:
Thu Apr 21, 2022 5:54 pm
https://www.harborfreight.com/1-in-x-30 ... 61728.html
works better for my uses
Re: Just cuts
Cut a hole in a bucket to try to grow an upside-down tomato plant.
https://youtube.com/shorts/5MhNdhSluoo?feature=share
Re: Just cuts
trimming a trail in the woods with my Chief
https://streamja.com/NVEme
Re: Just cuts
delica-204p vs fruits
Dragonfly 2 pd#1. Endura 4 vg10s. Delica 4ss. Sage 5salt magnacut.
Librarian
Re: Just cuts
Post by Librarian »
- Spyderco delica zdp-189 14dps, regrind ~ 0.2 mm bte
Finish Grinderman SiC b1000vk(FEPA)
Finish Shapton 5000 grit (JIS)
The Meat man
Re: Just cuts
Post by The Meat man »
PeaceInOurTime wrote:
Fri Apr 22, 2022 11:50 am
:thumbsup: ;)
- Connor
Librarian
Re: Just cuts
Post by Librarian »
REGRIND Vs. STOCK
- Dark Green delica - zdp-189 regrind bte 0.005" 17dps VS blue delica vg-10 stock bte 0.03" 17 dps
Giygas
Re: Just cuts
Post by Giygas »
Librarian wrote:
Wed May 11, 2022 5:59 am
REGRIND Vs. STOCK
Those are some pretty impressive videos. Is your rolled up magazine video a fresh edge, or was that after the wood cutting?
Librarian
Re: Just cuts
Post by Librarian »
Giygas wrote:
Wed May 11, 2022 6:03 am
The knife was after sharpening. But after woodworking, usually, the knife becomes a little dull and it would be enough for cutting a magazine.
Spyderco Urban k390 ~16dps, bte ~0,45 mm
Finish Grinderman (SiC) b1000vk (FEPA)
Chuck James
Re: Just cuts
Post by Chuck James »
Got a piece of glass in my finger. Used my manix2 with cruwear to slice under the glass and pop it out.
18* per side bevel, polished to .5 micron with 21* per side micro bevel sharpened to 2200 grit diamond.
ZrowsN1s
Re: Just cuts
#32
Post by ZrowsN1s »
Cutting some BESS Test media with my S30V Shaman.
Slightly sharper than a utility razor.
15DPS Sharpmaker Diamond, CBN, Medium, Fine, Ultrafine. Stropped with KnivesPlus Strop Block.
Re: Just cuts
#33
ykspydiefan
Re: Just cuts
#34
Post by ykspydiefan »
dan31
Re: Just cuts
#35
Post by dan31 »
That delica ZDP-189 regrind is a beast. That blade eats wood. Geometry is everything.
huyfishin
Re: Just cuts
#36
Post by huyfishin »
SHORT SHORT clip
I Play With Salt Knives / instagram huyfishin
