Show your mods!
- Manixguy@1994
Re: Show your mods!
Re: Show your mods!
Lookin good Dan! That is such a cool model.
- Manixguy@1994
Re: Show your mods!
Delica was gifted to me and clip had been stripped of top layer of coating on top of clip giving it a gray color . I took it off and applied heat to top and bottom and changed color to a very dark gray with a bit of shine . MG2MNOSD 0002 / Do more than is required of you . Patton
Re: Show your mods!
I wonder if that would affect the springiness of the steel.Manixguy@1994 wrote: ↑Mon May 02, 2022 5:44 amDelica was gifted to me and clip had been stripped of top layer of coating on top of clip giving it a gray color . I took it off and applied heat to top and bottom and changed color to a very dark gray with a bit of shine . MG2
"Some call me...Tim?"
- Manixguy@1994
Re: Show your mods!
Never has been an issue . MG2Paraguy wrote: ↑Mon May 02, 2022 9:56 amI wonder if that would affect the springiness of the steel.Manixguy@1994 wrote: ↑Mon May 02, 2022 5:44 amDelica was gifted to me and clip had been stripped of top layer of coating on top of clip giving it a gray color . I took it off and applied heat to top and bottom and changed color to a very dark gray with a bit of shine . MG2
kirilpetkov
bearrowland
Re: Show your mods!
I agree
Barry
Bonne Journey!
MNOSD member 0032
Bonne Journey!
MNOSD member 0032
- Manixguy@1994
Re: Show your mods!
Fade job on Manix 2 clip . DanMNOSD 0002 / Do more than is required of you . Patton
Re: Show your mods!
That would look good on the DLT purple PM2 exclusive.
- Manixguy@1994
Re: Show your mods!
Yes it would look very nice against the scales . I have a Lynch on my Crucarta so I won’t be doing that mod !
bearrowland
Re: Show your mods!
That turned out very nicely Dan!
Barry
Bonne Journey!
MNOSD member 0032
Bonne Journey!
MNOSD member 0032
- Manixguy@1994
Re: Show your mods!
Beautiful scales to all very inspiring. My wheels are turning ! MG2
- Manixguy@1994
Re: Show your mods!
This an early clip mod done years ago when working at Caterpillar. I had this clip put through a Wheelabrator to remove black finish. It left a grippy texture but not a pocket eater . DanMNOSD 0002 / Do more than is required of you . Patton
Re: Show your mods!
Looks cool Dan. Like a bead blasted finish.Manixguy@1994 wrote: ↑Thu May 05, 2022 4:04 pmThis an early clip mod done years ago when working at Caterpillar. I had this clip put through a Wheelabrator to remove black finish. It left a grippy texture but not a pocket eater . Dan
bearrowland
Re: Show your mods!
I agree. It really transformed it.
Barry
Bonne Journey!
MNOSD member 0032
Bonne Journey!
MNOSD member 0032
- Manixguy@1994
Re: Show your mods!
I did this shot blast myself in my best friend’s garage years ago . Notice the finer texture . I mulling over trying a wire clip next , may try today . DanMNOSD 0002 / Do more than is required of you . Patton
- apollo
Re: Show your mods!
Nice job. Looks way better then the og black paint.Manixguy@1994 wrote: ↑Fri May 06, 2022 9:08 amI did this shot blast myself in my best friend’s garage years ago . Notice the finer texture . I mulling over trying a wire clip next , may try today . Dan
- Manixguy@1994
Re: Show your mods!
Thank you Apollo , call me Danapollo wrote: ↑Fri May 06, 2022 2:51 pmNice job. Looks way better then the og black paint.Manixguy@1994 wrote: ↑Fri May 06, 2022 9:08 amI did this shot blast myself in my best friend’s garage years ago . Notice the finer texture . I mulling over trying a wire clip next , may try today . Dan
