Pardon my ignorance, but what did you Dremel?metaphoricalsimile wrote: ↑Mon Apr 11, 2022 4:45 pmAlso check out my dremel job for using the Sharpmaker Precision Adjust with spyderco knives. I cut out one side of it and left the other factory. The knife is just as easy to center in the jaws but being able to hold the blade like this means the bevel angle is more consistent front to back.
Community Sharpening Journal
- kennethsime
Re: Community Sharpening Journal
metaphoricalsimile
If you look at Tkok83's picture of the CRK in the worksharp precision adjust, you'll notice the side plate on the clamp has a small V cutout to help center the knife in the jaws of the clamp. It looks like that on both sides from the factory. I dremeled out a slot on one side to let spyderco blades fit deeper into the jaws.
I personnally just put it sideways and clamp it as hard as I can. I think I'm gonna use the dremel too, thanks for the idea @metaphoricalsimile !
MNOSD member 004* aka Mr. N5s
Robert Ptacek
- bbturbodad
The corners on the diamond or CBN rods are the best way to reprofile an SE edge. You need to take your time and use very light pressure or they will wear out quickly.Robert Ptacek wrote: ↑Tue Apr 12, 2022 10:55 amPlease school me.I thought somewhere I read(heard) that they didn't advise using the corners on the diamonds or am I misrememberiing.
-Turbo
- kennethsime
Ahh, gotcha! I have the same sharpener, may have to try this.metaphoricalsimile wrote: ↑Mon Apr 11, 2022 11:05 pmIf you look at Tkok83's picture of the CRK in the worksharp precision adjust, you'll notice the side plate on the clamp has a small V cutout to help center the knife in the jaws of the clamp. It looks like that on both sides from the factory. I dremeled out a slot on one side to let spyderco blades fit deeper into the jaws.
That crowned spine on the Sebenza doesn't do many favors with the clamp in this system. Thankfully it clamps enough that I haven't had any issues with the knife moving during sharpening. Still working at that knife, lost a bit of motivation the past few days though!
metaphoricalsimile
Here are closer pics of my WS PA clamp mod. The advantage is that it's easier to set up the edge on tall spyderco blades a consistent distance from the pivot of the sharpening stone slider, hence giving your bevel a more consistent angle across the whole blade. I found that leaving the blade sort of half-out-of-the-clamp made the system too flexy for my liking, considering it's already a fairly flexy sharpening system.
I like that. May need to copy it. Great Improvement!
Robert Ptacek
Gotcha,Thank You.bbturbodad wrote: ↑Tue Apr 12, 2022 11:44 amThe corners on the diamond or CBN rods are the best way to reprofile an SE edge. You need to take your time and use very light pressure or they will wear out quickly.Robert Ptacek wrote: ↑Tue Apr 12, 2022 10:55 amPlease school me.I thought somewhere I read(heard) that they didn't advise using the corners on the diamonds or am I misrememberiing.
Just bought myself a 220 DMT Dia Sharp.
I have some 220 and lower with venevs and work sharp, but I wanted a bigger stone to try some stuff out.
I'll make a 220 edge on one of my folders (or the MC Mule if it needs sharpening fast enough).
Soanso McMasters
Which one is the 220? I have a coarse/fine and a fine/extra fine currently and I have a coarse/extra coarse on the way.
I have the coarse/extra coarse stone myself and that thing is awesome. Extra coarse side when new, I'd break it in with a cheap knife first. When I used mine the first time, the knife was hopping on the stone with very light pressure.
The extra coarse is the 220. They even have a extra extra coarse code (silver color) wich is 120 grit, but I don't know if it exist in their diasharp line, I have their small 4" whetstone in 120 grit and 8000 grit ^^.Soanso McMasters wrote: ↑Fri Apr 15, 2022 3:08 amWhich one is the 220? I have a coarse/fine and a fine/extra fine currently and I have a coarse/extra coarse on the way.
I like double sided stones, but I often use the diasharp stones in my hand close to my face, I like to have the smooth side under it ^^
Bit of a tip to make the Worksharp PE less flexy during use:
Purchase a V-Clamp support to hold it up. I purchased the one linked below, but any of a similar design will do the trick. Made a HUGE difference in consistency and stiffness on my system, and I'm able to get much better apexes. Only downside is that it takes longer to flip the knife over because you have to remove the support before rotating the clamp. A worthy sacrifice IMO for increased stability.
https://www.gritomatic.com/collections/ ... ion-adjust
s: MT22 RWL34, MT07 Damascus, MT33 REX 76Re: Community Sharpening Journal
Yep it's pretty useful to have something supporting it ! I personnally use commemorative coins from the soccer world cup of 1998 and a stiff eraser
Just picked up a DMT 10x4 DuoSharp in Coarse/Extra Coarse. I have had the Fine/Extra Fine for some time and really appreciate the extra real estate on these 10x4 DMTs.
cholla_remover
Loving this Precision Adjust Dremel mod.
I got a Worksharp clamp adapter from Gritomatic, it fits a KakBritva clamp - wide with a split in the middle and a bolt on each side for adjustment. Holds the FFG blades perfectly. It does put the blade out farther from the sharpener, so you have to use an angle finder.
Soanso McMasters
I used my benchstones to sharpen my Stretch 2 K390 and was really pleased with how easy it sharpens. The burr formed quickly and removed quickly on the stones. Stropped up very sharp.
