Need help: Remedying gritty action on stainless steel Endura (no disassembly, no screws at all!)
Re: Need help: Remedying gritty action on stainless steel Endura (no disassembly, no screws at all!)
I just think if it's a big concern, if you follow the principle of "like dissolves like" to remove the more-toxic solvent with a food safe oil, and finish any solvent regime with soap and water followed by isopropyl you're going to get nearly anything off the blade that hasn't chemically reacted with it, or elsewise formed super strong bonds. At that point, if it's bonded so well that solvents followed by surfactants followed by volatile low-molecular-weight solvents doesn't remove it, neither is your food going to.
Hey Gernot, the tip up, down and sideways debate rages. Ah, hahaha!
Either ways, I can’t quite make sense of what you write (above) and it doesn’t matter at all mate.
Here are my two most used folders. Both designed by Mr Glesser as it goes.
Can you see what they have in common and how they differ from most other Spyders and others?
No intention to participate in a "clip position debate", my friend!Bloke wrote: ↑Fri Jan 14, 2022 5:08 pmHey Gernot, the tip up, down and sideways debate rages. Ah, hahaha!
Yeah, my comment was a bit confusing I guess:
All It tried to say is this:
- Uncovered holes for the clip screw do only matter in the tip down placement when it comes to letting dirt to the pivot, cause, well, that´s where the pivot is
- Open holes in the tip UP position don´t matter at all imho when it comes to keeping the pivot clean, cause they are almost as far as possible away from the pivot area
That´s actually something I´ve never even heard of, thanks!
Just not too many gun shops here in Salzburg /Austria / Europe, but there are still two I think - though more for hunting rifles than hand guns, but that won´t matter in this regard I guess
Doc Dan wrote: ↑Thu Jan 13, 2022 11:28 pmTry this: Get some old fashioned white toothpaste. Fill the knife pivot and lock area with it and work the blade, lock bar in contact with the tang. Work it, fill with more paste, and work it some more. No water. It should feel very rough and gritty. After a hundred or so openings and closings, rinse out the knife really well and oil it. It will likely be like butter, after all of that.
Thanks, Doc, I´ll try this today just like you and Spoonrobot suggested!
I didn't see his (her) post on this. Toothpaste is a mild abrasive so it may take a little while of doing this. It is not aggressive, at all. However, it is very easy to clean out with just water once you're done.Wartstein wrote: ↑Sat Jan 15, 2022 1:33 amDoc Dan wrote: ↑Thu Jan 13, 2022 11:28 pmTry this: Get some old fashioned white toothpaste. Fill the knife pivot and lock area with it and work the blade, lock bar in contact with the tang. Work it, fill with more paste, and work it some more. No water. It should feel very rough and gritty. After a hundred or so openings and closings, rinse out the knife really well and oil it. It will likely be like butter, after all of that.
After backpacking trips getting the action of my pinned Delica 3 gritty, I would throw it in the dishwasher.
I like Vivi's method of submerging it in a bowl of water and working the action.
Tetrachloroethane or perc was used as a metal degreaser. Once it evaporates, there is no residue left on the metal. You wont find perc or its cousin trichloroethane in any over the counter products anymore as they have been replaced with less toxic alternatives.
Benzene is found in gasoline. You better not fill up your car or you're gonna die.
I have been working as an environmental professional for over 30 years, and the fear mongering of industrial chemicals and products and lack of understanding of exposure pathways by unnamed members here is truly mind blowing.
As they say, stay in your lane.
Jewelers also have ultrasonic cleaners.
Ultrasonic cleaners are also not overly expensive. Many home units are light duty, but how often will you use it? One a week, once a month?
Superflex wrote: ↑Sun Jan 16, 2022 10:59 amJewelers also have ultrasonic cleaners.
Thanks! Tbh I did not even know that something like such cleaners actually exist....
Superflex,
Sorry, off the subject,but !!!
In the mid 1970's I owned a Ford Falcon (351) GTHO and used to add a couple of gallons of Methyl Benzine to prevent
"pinging". Also previous to that I owned a hotted-up Morris Mini and added M/Benzine for the same reason.
Worked fine , no damaged valves etc.
Definitely a small ultrasonic cleaner for home isn’t expensive, though an endura might be a tight fit, closed. I can also suggest a steam cleaner to blast steam in the pivot and heat up/ break up / blast away the crud you have going on in there. Both a small steam cleaner and an ultrasonic cleaner are invaluable tools to have.
Good luck, and as a side note, my SS SE Endura II is my first ever Spyderco purchased in 98, and it still cuts like a chainsaw. I carry it quite regularly, so it’s great to see another one being used.
VWTattoo wrote: ↑Mon Jan 17, 2022 7:04 am..... I can also suggest a steam cleaner to blast steam in the pivot and heat up/ break up / blast away the crud you have going on in there. Both a small steam cleaner and an ultrasonic cleaner are invaluable tools to have.
Thanks for your help! :)
/ So yours does also still have the hollow sabre grind?
For me the "hollow" - thing makes for a huge difference to "just" sabre. It is actually a great cutter, and the tip somehow the "best of both worlds" - not as thin and potentially fragile as in ffg, but also not that overly sturdy (and by that imho less useful) as on a true sabre grind.
I wonder if it is galling? If so, no amount of flushing and lubing will really help. It can happen if a knife is completely stripped of all lube and opened and closed. It doesn’t always happen, but it can cause a gritty feel.
Perchloroethane is hexachloroethane. If you mean perchloroethylene (= tetrachloroethylene), it is still widely used as brake parts cleaner. See the MSDS for this product which I buy regularly:Superflex wrote: ↑Sun Jan 16, 2022 10:58 amTetrachloroethane or perc was used as a metal degreaser. Once it evaporates, there is no residue left on the metal. You wont find perc or its cousin trichloroethane in any over the counter products anymore as they have been replaced with less toxic alternatives.
https://www.crcindustries.com/products/ ... z-306.html
They make a non-chlorinated version too (a mixture of methanol, toluene, heptane and acetone), which makes a great general purpose solvent spray, but for brake jobs I use perc. Neither leaves any residue (a basic requirement for a brake part cleaner).
